#251 |
![]() Join Date: Apr 2009
Re: Buildin my 88 Crew Cab long bed AKA STRETCH!
thats really good to know
#252 |
I'll See what i can do
WillieloRidez Drive em in Drag em out! Projects: 1956 Chevrolet 210 2dr post 58 chevrolet 2dr delray 58 chevrolet belair 4dr hardtop 1965 Chevelle big block 4spd 88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=388445 Last edited by WillieloRidez; 11-14-2010 at 05:52 PM. |
#253 |
thanks man! what a cool mod for the 81+ guys... great tip!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#254 |
Did you see the bare Crew just the Cab for sale on CL moundridge Ks
Posted via Mobile Device |
#255 |
Ya i saw it out there. Doesn seem like much of anything but i have seen people start with a lot worse. Could be a good deal i guess. Are you still looking for one?
WillieloRidez Drive em in Drag em out! Projects: 1956 Chevrolet 210 2dr post 58 chevrolet 2dr delray 58 chevrolet belair 4dr hardtop 1965 Chevelle big block 4spd 88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=388445 Last edited by WillieloRidez; 11-16-2010 at 01:21 PM. |
#256 |
Real Projects never die
bg you got a link to that add? i really want a crew.
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
#257 |
WillieloRidez Drive em in Drag em out! Projects: 1956 Chevrolet 210 2dr post 58 chevrolet 2dr delray 58 chevrolet belair 4dr hardtop 1965 Chevelle big block 4spd 88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=388445 |
#258 |
Well i think i have some doors located for my truck. The guy told me he just put all new window motors in before he pulled them off. I am going to go look at them tonight!
#259 |
Well i picked up the doors! They are a lot better than the ones on my truck. Anyone no how to put power doors on a non power truck?
#260 |
Nice Score Willie!!
first of all, I hope these doors have the wiring plugs intact? also there should be some large grommets on the front door wiring. All you need is the power harness from a 'burb or crew cab. It will include the power lock relay which mounts under the steering column. there are only 3 wires to hook up under your dash. Switched 12V, all time hot 12V, and a ground. There should be places on your fuse block to plug the hot wires into and the ground hooks to the ground buss to the left of the instrument cluster. If you look closely on your trucks A and B-pillar you will see small indentions for where you need to drill holes for the wiring to pass through (you will also find the same indentions on the inside of the kick panel kinda high almost behind the dash, you will need to drill holes the proper size for the grommets to fit in. the rear will have access holes already). It is pretty simple, you will need some hole saws and I used self drilling screws to attach the accordion boots to the cab. Be sure to drill the pass-through holes with the doors off, makes it much easier. fell free to ask if you have any specific questions or if I didn't make it clear ![]()
#261 |
Perfect, was going to ask the same question here soon....as I will be doing the same thing to my 89 Crew.
Thanks!!! |
#262 | |
#263 |
I bought some new wheels i think i might put on this. They are boss 335s 20x8.5 and 22x9.5. What do you guys think
#264 |
I like em!
#265 |
Me too!
Very nice! Posted via Mobile Device
#266 |
Nice!!!
#267 |
Thanks fellas! Now i need some tires
#268 |
#269 |
I havent really thought about it. I would probably sell them if someone was interested.
#270 |
consider me somewhat interested. Email me all the details brownr@inetlink.ca , size offset some better pictures of them on and with or without tires, tread depth etc.
Shipped to 58329 I might be considering converting my crew to a 5 bolt/1/2 ton here yet. Or at least till I get the 4 link figured out. Have to see what transpires yet, I change my mind like my underwear. And yes that is at least once a day.....again, depending....lmfao! thanks! Last edited by Devillusion; 12-02-2010 at 11:48 PM. |
#271 |
Ok i had to do it! I bolted a 20 on the front just to see what its going to look like!
#272 | |
#273 |
Very nice!!
#274 |
Those will look good on there
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
#275 |
Thanks guys. I think since the truck is in the garage and i got my chevelle back to drive its going to get torn apart!
