Old 07-22-2011, 03:41 AM   #251
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: Finally starting the 68swb fleet
looking forward to pics, I put the motor and tranny in, the parts store shipped the wrong rocker nuts and harmonic so I'm still at a stand still, I'll post pics tomorrow
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 07-22-2011, 04:13 AM   #252
67chevy1series
67chevy1series's Avatar
if i heard you correctly you said you ave the engine and tranny in the frame?
67chevy1series is offline   Reply With Quote
Old 07-22-2011, 04:34 AM   #253
tantrumpipeline
well it is but it isn't, the tranny is just temporary for mock up, headers won't work without a real restrictive bend off the collectors so they'll be replaced pre start up and as always, I was shipped wrong parts so I'm at a stand still there and my electrician has been so swamped he hasn't had a chance to get the welder in yet, gives me a chance to clean the garage out though The holes in the frame could allow me to run these headers by moving everything back, but I will know when I mock up the driveshaft tomorrow, my teardown pics look to have everything where it is now, the monte carlo/chevelle style shorty headers look like the right fit for my dilemma if not and I should be able to sell these and break even up here so not to worried
20 Duramax tow pig
52 short project
Old 07-22-2011, 12:23 PM   #254
Slammed66
Needs a Big Block
Slammed66's Avatar
I ran hooker 4266. Shortys a few times , but I was using 73+ engine mounts, They fit awesome and were a breeze to run the exhaust tucked up into the frame looking sweet buddy!!
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 07-22-2011, 02:34 PM   #255
tantrumpipeline
thanks, I may do the same, but the swept style shorty's may be the best way to flow with the crossmembers I have etc, going to see what offers I get locally on my shortys and if I come close to breaking even I will upgrade to ceramic coated as well to save on starters and plug wires
20 Duramax tow pig
52 short project
Old 07-22-2011, 04:37 PM   #256
Slammed66
Needs a Big Block
Slammed66's Avatar
Sounds good!! Those hookers I mentioned are a 3/4 length swept shorty , I had em on a bagged shorty ( my 64) And ran the exhaust up in the frame that being said ,get this thing fired uppppppp!!!
1964 Short box
1972 K10
Old 07-22-2011, 06:05 PM   #257
tantrumpipeline
outta money lol dammit Starting work again tomorrow though, may have some parts sold etc to cover a carb and the rest of the motor parts so we'll see, hoping to do some bodywork for the time being once my welder is setup
20 Duramax tow pig
52 short project
Old 08-13-2011, 11:40 PM   #258
DCoffey
DCoffey's Avatar
Can't believe you even though a out selling,
Who doesn't like an endless money pit and no garage space. And by the way i can tell that you Are logged in. That means you are not working in the garage.
67' Shortbox build thread:http://67-72chevytrucks.com/vboard/s...=1#post4281123
DCoffey is offline   Reply With Quote
Old 08-13-2011, 11:48 PM   #259
tantrumpipeline
waiting on a day off now to wire in the welder and order some more parts, had a mishap with my right hand though so not in a rush, hoping to get everything in next sunday and start on the cab though, gonna learn to weld left handed if thats what it takes, they make grinders and flap wheels for a reason Yeah it was close to going up for sale, but the sun finally came out to play so I am back to work, woulda been a fight to the bitter end had it come to that, the joys of being in business for yourself
20 Duramax tow pig
52 short project
Old 09-05-2011, 11:57 AM   #260
tantrumpipeline
I have been too busy to work on it lately but I just picked up the wire needed to hook up my welder and I'm looking at a few 60gal compressors, going to sit down and make an order list for my intake pipe plugs, rocker nuts, alternator,and water pump sp hopefully I can give it a test run, and weld up the cab before the snow comes.
20 Duramax tow pig
52 short project
Old 09-08-2011, 09:42 AM   #261
67cheby
67cheby
67cheby's Avatar
just my 2 cents ....if you are going to do body work you need atleast an 80 gal compressor the 60 gal ones i have had wont keep up with air sanding tools, you will be very annoyed waiting for the compressor to keep up !! now maybe it was my compressors that i tried they were new BlackMax compressors, when i switched to the 80 it worked great
67cheby is offline   Reply With Quote
Old 09-10-2011, 12:11 AM   #262
tantrumpipeline
thanks I'll look into one
20 Duramax tow pig
52 short project
Old 09-10-2011, 12:38 AM   #263
hgs_notes
GEARHEAD
hgs_notes's Avatar
My 60 gal worked well for me. 80 is better, but not sure the added cost justifies the expense for most home shop users. The 80's are usually a 2 stage pump and much more expensive. BTW, I inspect these things for a living and worked at a plant that builds them for a few years. The key is the pump. A good 60 gal should have a good 2 cylinder pump. They won't build the pressure of a 2 stage, but have good capacity. Also, most air tools don't need the full tank pressure, so using a line regulator set to around 100 psi will generally help the air usage. The only time I had air pressure problems was when I was sand blasting or running the random orbital non-stop. I usually had to stop to change sanding disks etc. anyway, so not a huge problem.
Hope this helps.
hgs_notes is offline   Reply With Quote
Old 09-25-2011, 07:42 PM   #264
tantrumpipeline
thanks I will keep that in mind, this project is somewhat back on the shelf, too busy and a lot going on, maybe get back into it this spring, if anything changes the pics will continue
20 Duramax tow pig
52 short project
Old 05-10-2012, 12:16 AM   #265
tantrumpipeline
back from the winter, rear fenders and step plates should be in within a week, cab is going back to sandblast to get the inner and outer floors blasted to remove whatever coating was sprayed on so I can re coat with POR15 and repair a few minor spots, electrician is tentatively lined up to have the welder setup next week, we have heard this before though, and I should have a week or two off starting monday so this thread will once again be active, I'm hoping to have the cab repaired, smoothed firewall, and back on the chassis by the end of may long, the weather is nice at last, as always the pics will be plentiful, also have a binding issue with the steering I need to get squared away
20 Duramax tow pig
52 short project
Old 05-10-2012, 01:49 AM   #266
NewType72
NewType72's Avatar
great progress man lovin how good the chassis looks and motor is comin along nicely
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 05-10-2012, 06:01 AM   #267
67cheby
67cheby
67cheby's Avatar
Awesome looking forward to the progress
Old 05-10-2012, 10:57 AM   #268
tantrumpipeline
Thanks guys, the time away from it has got me motivated again, maybe one more snowmobile trip then it's all truck until wakeboard season
20 Duramax tow pig
52 short project
Old 05-10-2012, 11:31 AM   #269
JON70CST
JON70CST's Avatar
I'm definitely subscribed! Living in AB maybe I'll get to see it in person one day! Keep up the great work!
JON70CST is offline   Reply With Quote
Old 05-17-2012, 05:31 PM   #270
tantrumpipeline
Slacking pretty hard on this build but I hope to have it on the road one day, this forum is a blessing and a bad distraction with all the other builds you drool over you end up changing and adding all the time Got a delivery from AMD with my rear fenders step plates and braces, now I'm waiting to hear back from a local blaster to hit the bottom and inner floor of my cab so I can get to repairing issues and smoothing out the firewall
20 Duramax tow pig
52 short project
Old 05-17-2012, 06:09 PM   #271
67chevy1series
nice bunch of parts! .... you have been slackin.... HARD lol get back on the ball tyler! lol
Old 05-17-2012, 06:15 PM   #272
tantrumpipeline
hahaha I'm trying, now the issue is nobody in town wants to blast for me due to the nature of the job and issues with warping, hopefully hear back soon
20 Duramax tow pig
52 short project
Old 05-19-2012, 04:32 AM   #273
67chevy1series
hopefully!
Old 05-25-2012, 10:21 AM   #274
tantrumpipeline
Stripping old undercoating is tedious crappy work, sandblasting in GP is ridiculous right now, backlogged til early July and my A.D.D. won't let me wait til then and the cab really isn't in bad shape so I am at it with grinding/stripping/and wire wheels
20 Duramax tow pig
52 short project
Old 05-25-2012, 10:41 AM   #275
67cheby
67cheby
67cheby's Avatar
nice work, keep it up !
