01-31-2011, 05:43 PM | #251 |
Re: '67 5.3L Build Thread
no build tread but when i get the fittings i will get your e-mail address and send you pictures.
02-01-2011, 12:11 AM | #252 |
Wow, very clean engine compartment. Looks like it belongs there!
02-01-2011, 01:56 AM | #253 | |
Still Learning
Man that looks amazing! This is a swet setup....just looks like $$$$$ mucho bucks |
02-01-2011, 06:44 AM | #254 |
Sounds good, thanks. I'll be sure to post pics of my setup as well (whenever I get around to doing the AC system).
67 5.3L Build |
02-01-2011, 06:58 AM | #255 |
Thanks guys. I guess "mucho $$$" is different to everyone, but for a daily driver I am still WAY under a newer truck (that I would like as much).
67 5.3L Build |
02-02-2011, 04:34 PM | #256 |
Hello All, I have my frame cut down and dusted all the snow off of it and brought it back in the garage to start grinding some rivets off. What is everyone's experience with painting or powder coating the frame?? What do you think 67c10bub??
02-02-2011, 04:51 PM | #257 |
1965 Chevy C10, 2005 4.8L/4l60
are you going to drive this everyday? or just for parties?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-02-2011, 04:52 PM | #258 |
It won't be a daily driver but a driver.
02-02-2011, 05:10 PM | #259 |
I used a Sherwin Williams Exterior Industrial epoxy paint on my build... very happy with the results... however I have not started driving mine to see how it holds up to daily use. Powdercoat is usually a more durable finish... my only problem was I figured i would have to make slight modifications and there is NO way to patch or fix powdercoat.
With all that said.. I will probably try powdercoat on my next project.
"Love Affair" Build Thread |
02-02-2011, 05:12 PM | #260 |
67C10BUB... did you use the supplied header gaskets with your DT headers? I was told to buy new, better quality gaskets and not use the ones supplied. Just wanted your opinion. Also did you use the supplied hardware or something like ARP header bolts?
Thanks as always
02-02-2011, 06:35 PM | #261 |
I just wire wheeled, sanded, primed, and painted semi-gloss black with Rustoleum. I would have liked to powder coat, but it just wasn't in the budget. I am going for a more factory look than a show car look anyway.
67 5.3L Build |
02-02-2011, 06:38 PM | #262 | |
67 5.3L Build Last edited by 67C10BUB; 02-02-2011 at 06:39 PM. |
02-02-2011, 06:52 PM | #263 |
so is your truck a real panoramic 67?
02-03-2011, 06:42 AM | #264 |
The cab is a 67 c20 and the chassis is from a 71 c10.
67 5.3L Build |
02-03-2011, 10:32 PM | #265 |
sweet its nice to know it is actually a 67, got a rare cab !
02-04-2011, 12:25 AM | #266 |
Still Learning
I used to love driving my 67 (small window) around with all the thumbs up you get, but the blind spots are huge. I wish I still had it.
02-04-2011, 12:34 AM | #267 |
yes i love the small windows! but in a 60 66 i would have to have a big window! i guess im a wierd character right!
02-12-2011, 12:34 AM | #268 |
I got the exhaust done today by Ralph's Muffler in Fontana CA. I can't say enough good things about Gabe, the technician that did the install. I got 2 Magnaflow mufflers, 2 rolled lip tips, and full custom install with an H-pipe for $450 out the door. This seems like a killer deal to me and the welds/bends look absolutely perfect. He even installed 4 hangers with rubber isolators. If anyone is in the IE in CA I would strongly suggest looking into Ralph's. These pics are during the install before the H-pipe was installed. I'll try and get more of the completed system.
67 5.3L Build |
02-12-2011, 12:35 AM | #269 |
I came across this pic of my truck and just wanted to post it.
67 5.3L Build |
02-12-2011, 12:42 AM | #270 |
Damn! Looking good!... May I ask what kind of plug wires you ended up using for the DT headers?
02-12-2011, 02:03 AM | #271 |
johnny is right it is lookin good!!!!!
02-12-2011, 12:38 PM | #272 |
I used the MSD 32819 and they worked out great. The ends are bendable, so they can be moved around the header tubes as needed.
67 5.3L Build |
02-18-2011, 03:10 PM | #273 |
Here are a few of the completed exhaust.
67 5.3L Build |
02-18-2011, 05:06 PM | #274 |
Truck and auto performance nut
Looks nice!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-06-2011, 11:44 PM | #275 |
Truck is looking great man... hope mine turns out looking this good.
Question... can you post a picture of your oil dip stick install? you used a ED5008 (Lokar) stick right? Thanks man
