#251 |
Re: Vintage Air Sale
#252 |
Summer is coming and it is time to update your truck with the greatest Ac kit in the world.We have some great prices on all Vintage air parts.Let us know what you need and we will take care of you.
#253 |
![]() Join Date: Jul 2011
Justin,
I have a question...."Vintage air makes a set of A/C controls that will fit in the original AC/heat control space". Someone posted this in my thread. Is this controls electric so I could use a genII model ac. And do you have a pic...
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
#254 |
Will have your info on tue.We are at a show this weekend
Justin Posted via Mobile Device |
#255 |
Hey Sir -
I was wondering if I could get a quote for a Gen-4 sure fit kit for a 64 C-10 with a 454 and a long water pump, v-belts.. Also, is there an option for circular vents (trying to stay with a classic 60's look). Also could you tell me what size the vent lines are (incase I have to find circular vents from other places). Thanks for your help! Alex Last edited by Arekusu; 05-29-2012 at 03:26 PM. |
#256 | |
justin |
#257 |
Hello! I have a 72 C10, factory A/C Cab, but I have removed the controls from the dash, as well as all of the old guts from the dash (defrost and dash vent tubes -they were full of dust and worn out). 350, Automatic. Currently no a/c components installed save for the big plastic box on the firewall. Can you share my options? I live in Atlanta, GA - and it tends to get hot. PS - I am running electric fans - do I need anything else? They blow around 1100 CFM if I recall correctly. Thanks in advance.
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#258 | |
Justin |
#259 | |
#260 | |
Justin |
#261 |
Damage Inc
can i get a price on a vintage air setup for my 68 stepside. ac cab
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
#262 |
motor exploder
Hey Justin,
Can I get a quote on kit #944170 shipped to 72120? This is for a '69 C10, factory air cab, 454 w/late model (90-94) small block serpentine belt setup. Not sure if the Sanden compressor will work with this, I believe Vintage Air makes a bracket to adapt the Sanden compressor in place of the R4 that originally came with this belt setup. *Edit* - found that bracket part #, it's 141805. Thanks!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 05-31-2012 at 11:38 AM. Reason: part # info |
#263 |
#264 | |
Justin |
#265 |
![]() Join Date: Dec 2008
Was wondering on the pricing for my 1970 c10 with an ls.
1. front runner system 174011 With Power Steering (Includes Pump) (this is the black coated for ls) 2. gen iv system[/INDENT]3. a nice inside controller (brushed 3 or 4 knob not oval) thanks |
#266 |
Could I get a price for a 71 non-ac blazer.
#267 | |
Justin |
#268 |
#269 |
Looking for a gen II setup 68000-VUZ-A,or 66005-VUZ-A.
#270 |
#271 |
Knuckle head
I am deployed and can't look at the vintage air site. Can you tell me what is available for a 1971 C10 with a '05 GEN III 6.0. I would like A/C and heat and whatever else I can get with it.
Thanks, Adam
Adam '71 SWB/Step ![]() 2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC '00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed '09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD) 1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785 1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis. ![]() |
#272 |
Vintage air has a direct bolt in kit to your truck and you can use your factory ac comp on the motor you have if you would like to.On your truck now was your truck a factory air or non factory air?
If your truck was not factory air and you have the heater controller you can use this in your truck with your new ac kit from VA If you truck was factory air and you have the ac controller in the dash you can use this in your truck with the new ac kit from VA Let me know on this and I will send you over a price on what you will need to get you all taken care of Justin Last edited by Scottshotrods; 06-06-2012 at 10:13 AM. Reason: add |
#273 | |
Knuckle head
My truck did not have factory air and I'm not sure if this matters but I was completely replacing the firewall before I left. There will not be any of the original holes when it is completed. Adam
#274 |
#275 |
Knuckle head
Thank you as well. I am even more excited to get home now.
If anyone has question, Justin is the man to talk to. Very knowledgeable and incredibly helpful. Thanks, Adam
