Old 03-30-2013, 11:00 PM   #251
McMurphy
McMurphy's Avatar
Re: 66 c10 first timer build
Here it is:
http://67-72chevytrucks.com/vboard/s...d.php?t=548234
Manny's 65 ls build.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 03-31-2013, 08:39 AM   #252
williamsboys
williamsboys's Avatar
Williamsboy
williamsboys is offline   Reply With Quote
Old 05-04-2013, 07:46 PM   #253
williamsboys
Well I finally got time to clean and repaint my rad mounting bracket and got it all installed with some stainless hardware
[/IMG]
[/IMG]
[/IMG]
Williamsboy
Old 05-04-2013, 07:47 PM   #254
williamsboys
http://
Williamsboy
Old 05-04-2013, 07:49 PM   #255
williamsboys
http://
http://
Williamsboy
Old 05-04-2013, 07:49 PM   #256
williamsboys
Also put all new rubbers on top and bottom
Williamsboy
Old 05-04-2013, 08:27 PM   #257
shortbed70
shortbed70's Avatar
When you start to tackle the rust you will have to cut the bottom of the door pillar off because the inner rocker is spot welded to the cab support! And I you have any rust where the wire channel runs between floor and rocker then buy the extended floor pans. Rigs looking good btw!!!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-04-2013, 08:37 PM   #258
williamsboys
[quote.=shortbed70;6052222]When you start to tackle the rust you will have to cut the bottom of the door pillar off because the inner rocker is spot welded to the cab support! And I you have any rust where the wire channel runs between floor and rocker then buy the extended floor pans. Rigs looking good btw!!!
Posted via Mobile Device[/quote]
Thanks, yea thanks for heads up on rust. I'm just Learning as I go. But can't wait to start on the body
Williamsboy
Old 05-04-2013, 08:47 PM   #259
williamsboys
Also was piddling with grill supporthttp://
I started to beet that creese out but the whole side seems bent up, any suggestions on how to straighten it out.http://
Williamsboy
Old 05-04-2013, 08:48 PM   #260
williamsboys
http://
Williamsboy
Old 05-05-2013, 05:07 PM   #261
McMurphy
McMurphy's Avatar
Originally Posted by williamsboys View Post
http://
Do you have the link to where you got your radiator, and its dimensions?
I am about to buy one like Coulter got, but I want to make sure I am not making a huge mistake.
I am looking at this:
KMJ Performance
19 X 26" Universal fit Race Pro Aluminum Radiator. This is a GM style with 1 1/2" top filler neck and 1 3/4" bottom filler neck. This is a 2 row radiator with 1" Dual tubes. Tanks are 3" wide. Radiator has no Epoxy and is 100% Tig Welded.
Thanks man
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 05-05-2013, 05:48 PM   #262
williamsboys
Mcmurphy, you can check them out at championradiator.com it's year specific,3 row, and cools up to 700hp. A lil over kill but what ever. There pretty good quality. I'm happy with it. I know it's not running yet but as far as fit and look it's good. Also has the trans cooler on bottom but I just capped it cuase I want a separate cooler for the trans. Not at home right now so don't have exact measurements but they will on website.
Williamsboy
Old 05-05-2013, 09:06 PM   #263
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
I just bought one of those from Champion for my LT-1, as I had a great mishap last week. I had made all of the adaptations to fit the 96 Camaro radiator into my radiator support...Then while searching through boxes of parts on the mezzanine of my Dad's barn, I totally knocked my radiator off the edge, falling onto the box of my truck & crashing to the ground...Got the new radiator & looks great, but still gotta fix my truck box...
Modges'66 is offline   Reply With Quote
Old 05-05-2013, 10:11 PM   #264
williamsboys
Dang! Hate when that happens.
Williamsboy
Old 05-18-2013, 12:24 PM   #265
williamsboys
Well pushed it out of the garage today to sweep so I thought while it was out I would wash it down. Im waiting on a rear mount gas tank and front sway bar, that's what I'll be working on next. Heres a few pics.
http://
http://
http://
http://
Williamsboy
Old 05-19-2013, 11:13 AM   #266
1966FLEETSIDE
1966FLEETSIDE's Avatar
you need to take rear cover off count the number of teeth in the bigger gear then count the number of teeth in the pinion gear mark one tooth on each gear so u wont screw up.then divide the two and that should give you the gear ratio.by the way the bigger number into smaller one hope that helps fellas
1966FLEETSIDE is offline   Reply With Quote
Old 05-19-2013, 04:01 PM   #267
williamsboys
Thanks. I did that when I had the rearend rebuilt. I appreciate it. It's a posi with 3.73
Williamsboy
Old 05-20-2013, 08:59 PM   #268
williamsboys
Does anybody know if the yolk on the stock drive shaft will fit the 700r4? It's at my dad's so it will be a while before I can check. Also this might be a dumb question but when I install drive shaft do I need to make sure the trans is all hooked up as in the shifter and all just to make sure it's in park and it don't try to run us over. Still learning guys so thanks so far on all the advice
Williamsboy
Old 05-21-2013, 08:05 PM   #269
williamsboys
What length is the stainless steel rad overflow tanks I see a lot of people using. I got a 50 dollar coupon to cpp and there's a 13,15, and 19 I think. What yall got? Pics would be great
Williamsboy
Old 05-22-2013, 10:58 AM   #270
Bomp
Bomp's Avatar
Frame and motor are lookin sharp.
Not sure about the yolk. The radiator overflow..... I asked the same question for my white '67 Camaro. People asked, "what can you afford?" and "how much room do you have"?
Bomp is offline   Reply With Quote
Old 05-22-2013, 01:44 PM   #271
williamsboys
Thanks dude. I appreciate it. It's a long expensive learning experience
Williamsboy
Old 05-22-2013, 07:59 PM   #272
williamsboys
Anybody have any input on yolk or overflow tank?
Williamsboy
Old 05-23-2013, 06:23 PM   #273
williamsboys
Bump
Williamsboy
Old 05-23-2013, 07:53 PM   #274
williamsboys
Well the yolk don't fit
Williamsboy
Old 06-01-2013, 10:39 PM   #275
williamsboys
Saw this one today at a local bbq place, it was pretty nice.
http://
http://
Williamsboy
