Old 03-01-2012, 10:35 AM   #251
made2drag
made2drag's Avatar
Re: 86 squarebody made2drag
im still trying to figure out how to mount rear shocks. im going to use stock front shocks which i think are 8-9 inches compressed. i dont want anything between my notches, so i need to mount the shock bolts on the tire side up high and the axle with 3 or 4 inch weld on bracket plates. i still need to look at the bed mounts and see if i have any other options with the bed on.....kind of like the No Limit triangle mounts i saw on his 72...theres a nice feature on Rob's truck in the newest street trucks starting on page 48.....unfortunately the shocks will be last right before i mount my bed. im trying to only put im bed on once and i hope i never need to remove it again...another reason why im mounting my smc valves and compressor under the hood and most likely using hydraulic line from tank to under hood.
made2drag is offline   Reply With Quote
Old 03-01-2012, 02:43 PM   #252
Leedogg
Originally Posted by made2drag View Post
i see your in AL...let me know if you know of any truck shows coming up...and do you have a build thread on your bagged 4 door?
Again nice progress!
As for truck shows- The only ones I know of it Scrapin The Coast in Biloxi, and the Spring Fling in Panama City FL...but I've never been to either. My Trans Am is my show off ride...I usually check out cruizin the coast in Biloxi. I think "Scrapin" should be coming up soon.
As for my truck...it is a 'Future' Bagged project.LOL Right now it is my tow pig. But I do now have the bed off, and am working to get a fabricating friend of mine to do the rear frame notch and trim the frame under the cab in the next month or so. Only doing a 6/8 static drop for now- but building the frame work for bags. I have other issues(like powerplant) to work out before finishing the suspension.
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline   Reply With Quote
Old 03-01-2012, 03:50 PM   #253
made2drag
made2drag's Avatar
ok, cool...ive been to both shows and i try to go to scrapen every year. ive also been to showfest twice when it was held in greenville ms and still like scrapen better. scrapen is well worth the ride! i'll be checkin in on your project every once in awhile.
Old 03-02-2012, 10:30 AM   #254
N2TRUX
Happy to be here
N2TRUX's Avatar
Now I see the cut off leaf. I still feel you would be better off with that replaced rather than the helpers. The upper leaf may not flex as much in the front, but its still prone to fatigue in the rear.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-02-2012, 05:13 PM   #255
made2drag
made2drag's Avatar
i agree, i may end up doing that if the bags put too much flex on the mains near the shackle. do you have any advice on where to place the upper bag mounts vertical wise...in other words, should i have 3 people stand on the bumper til the notches touch axle (to mimic the bed being on), then compress my 2600 and screw a plug in it to hold it in at that position, then mark where the upper bag bracket needs to be?...im not sure if the bag should be compressed or half way compressed or what. i have heard the best ride was with the bag aired around 70% which should be 7 inches on this bag. starting with a compressed 2.8 that would give me 4.2 inches of lift for ride height and my axle will be about 4 inches from hitting the notch... somewhat where the axle is unloaded....if you have any other method for setting up the ride hieght it will be appreciated especially since you have experienced pressure readings and know where you used to run your leaf bags ....and feel free to post all you want on here. im not really worried about alot of discussion "taking over" my build thread....it will help me and/or another reader looking for answers from the more experienced...thanks
Old 03-02-2012, 07:59 PM   #256
stepside83
stepside83's Avatar
Ya id also like to know how to figure out where to place the upper bracket, im running a 2good link with a pan hard bar, so not sure if that will be any different, and also using a c notch instead of a step
stepside83 is offline   Reply With Quote
Old 03-05-2012, 10:33 AM   #257
made2drag
made2drag's Avatar
moved my steering column closer to the dash 2 inches....man what a difference...im 5' 11 inches and now i can drive with my arm extended and not bent and the whole new position feels more natural.
Old 03-05-2012, 10:34 AM   #258
made2drag
made2drag's Avatar
Old 03-05-2012, 12:18 PM   #259
stepside83
stepside83's Avatar
Looks sweet wat did you do to move I t closer move the mounting location on column? I always wondered if this was possible since im 6'1" 2 inches more away from me would make a huge improvment
Old 03-05-2012, 12:33 PM   #260
made2drag
made2drag's Avatar
i collasped the shaft between the rag joint and the firewall 2 inches but i recommend only doing 1 3/4 since it gets really tight on the cab side firewall. and yes the column bracket mounting location has to be dealt with.
heres my link on how i did it but caution you'll have to work the bugs out on everything that is moved and reattached....very minimal but still the fitment is still an issue.
heres the link: http://67-72chevytrucks.com/vboard/s...=511745&page=3
Old 03-05-2012, 12:37 PM   #261
made2drag
made2drag's Avatar
it seems to be able to be done without taking the column out....loosen everything and pull the steering column away from the rag joint enought to drill the 2 plastic plugs out of the shaft. tap it in 1 3/4 then push your steering wheel until your rag joint is back in place. tightn it up at the rag joint then modify your column bracket and tighten it and the firewall nuts and bolts....i did it the hard way so im not sure but it looks like you can do it without removal. dont forget to take your dash bezel off and your orange shifter needle loose or it will break...theres a spring and a peice of thread attached to the column that needs to be unhooked then re-hooked when done
Old 03-05-2012, 12:56 PM   #262
Leedogg
I've been wondering if you could move the steering wheel forward...cool. I'm just fat...every inch helps.
Old 03-05-2012, 01:11 PM   #263
made2drag
made2drag's Avatar
it's one of those "oh man, i hope im not messing up im truck thing" when i was doing it, but it ended up working out. make sure it's really what you want to do before you tap the shaft in...theres no turning back after that.
Old 03-05-2012, 01:54 PM   #264
Pop's C-10
Pop's C-10's Avatar
yea..i pulled my colunm too..but afterwards i seen i might have not needed to do it..lol
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-05-2012, 03:14 PM   #265
watahyahknow
watahyahknow's Avatar
nice i keep my eye on this one
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-07-2012, 12:20 PM   #266
made2drag
made2drag's Avatar
thanks
Old 03-08-2012, 09:39 PM   #267
made2drag
made2drag's Avatar
Old 03-17-2012, 09:05 AM   #268
made2drag
made2drag's Avatar
i'm trying to decide if i want to put 80's-90's audio in my truck or go new....these are a couple things i've saved over the years
Old 03-17-2012, 09:06 AM   #269
made2drag
made2drag's Avatar
Old 03-17-2012, 09:07 AM   #270
made2drag
made2drag's Avatar
alpine 7904
Old 03-17-2012, 09:07 AM   #271
made2drag
made2drag's Avatar
kenwood 8020
Old 03-17-2012, 09:48 AM   #272
cochino12
It followed me home?
cochino12's Avatar
that alpine deck is awesome!!!!
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-17-2012, 11:00 AM   #273
91Subbed
Havnt seen an alpine deck like they in years!!! Keep it old school!
91Subbed is offline   Reply With Quote
Old 03-17-2012, 11:57 AM   #274
Leedogg
Funny- I have an old school 1.5 din Alpine I am thinking about running in my CC with a pair of 90's style GS Redline Subs. Just spent 3 Grand putting a nav system with 15's in my Daily Driven passat- gonna keep the truck as simple as I can.
Old 03-17-2012, 02:08 PM   #275
watahyahknow
i just run a bleutooth radio (handsfree phone) and a tomtom navigation
the navigation could be put inside the dash too if you do a little fabricating and remake the round clip on mount so you can fasten it in the hole of the dash schould be a lot cheaper and you can use the nav even when youre using the phone
i had a loud JL alpine system in my first car but the high soundpressure got tiring on driving long stretches and it used a lot of boothspace
i now just use upgraded speakers in the stock locations (ok i drive a modern car they usually have better thought out speakersetups/placements anyway ) and a little hideaway woofer under the rearseat for some extra power , its enough
