Old 03-10-2013, 02:17 AM   #251
NEWFISHER
NEWFISHER's Avatar
Re: 1949 Chevy 3600 into a daily driver
Originally Posted by Coach529 View Post
Desperate times call for desperate measures. New tires and rims sitting here......and know body can mount and balance them until Monday. Ha.......I have done close to a thousand moto tires.....how hard can it be??
Easy....about 5 min per tire.
Nice clearance at full lock.
Do you still have some front leafs pulled in the last pic?
NEWFISHER is offline   Reply With Quote
Old 03-10-2013, 10:14 AM   #252
Russell Ashley
Russell Ashley's Avatar
Your truck is coming along nicely. I was wondering how long you would look at those new tires and wheels before you decided to try mounting them yourself, LOL. It's actually not that hard.
Russell Ashley is offline   Reply With Quote
Old 03-10-2013, 10:40 AM   #253
Coach529
Coach529's Avatar
Yes, the two smallest leafs are pulled.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 03-10-2013, 04:49 PM   #254
focusedontheprize
focusedontheprize's Avatar
How'd the rears come out boss?
Hopefully you have some good weather today to pull out Henry and get a full shot of him.
focusedontheprize is offline   Reply With Quote
Old 03-10-2013, 05:15 PM   #255
Coach529
Coach529's Avatar
Actually headed to the garage to work on the rears right now......
1949 Chevy 3600
Old 03-10-2013, 09:41 PM   #256
Coach529
Coach529's Avatar
No dice fellas. I got the rears mounted but could not get them to take air. Tried all the tricks I know and gave up.
1949 Chevy 3600
Old 03-10-2013, 09:48 PM   #257
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Wrap a ratchet strap around the tread, all the way around the tire and hook it to itself. Then crank it down tight. The strap being in the center of the tread all the way around will tend to push the sides out to where they will seat on the beads.
Also take the valve core out of the valve stem. That will give you better flow through the stem until you get the bead seated.
Old 03-10-2013, 10:19 PM   #258
Chris.
Did you try the last resort....... lighter fluid and fire?
Chris. is offline   Reply With Quote
Old 03-10-2013, 10:20 PM   #259
Tx Firefighter
I've always used ether and fire when it gets that tough.
Old 03-10-2013, 11:14 PM   #260
NEWFISHER
NEWFISHER's Avatar
Ratchet strap works, remove core first. Carbon cleaner and a match, remove core first.
Old 03-10-2013, 11:44 PM   #261
Dan in Pasadena
Dan in Pasadena's Avatar
Henry looks like he's stepping out and is now "Hank"
Dan in Pasadena is offline   Reply With Quote
Old 03-11-2013, 09:26 AM   #262
Coach529
Coach529's Avatar
A ratchet strap trick would not work.......tried it numerous times.
Tonight.......fire.
1949 Chevy 3600
Old 03-11-2013, 12:30 PM   #263
Old Crow
Old Crow's Avatar
Tonight.......fire.
VIDEO...we want video!
Old Crow is offline   Reply With Quote
Old 03-11-2013, 12:34 PM   #264
Coach529
Coach529's Avatar
If I get a burn mark on my new WW I will be pizzed.....
1949 Chevy 3600
Old 03-11-2013, 01:08 PM   #265
focusedontheprize
Ha I would think. I thought you said someone could mount them today?
Old 03-11-2013, 01:43 PM   #266
Coach529
Coach529's Avatar
Yea, I can haul them to the repair shop......but now it almost seems like I am giving up.........
1949 Chevy 3600
Old 03-11-2013, 02:00 PM   #267
Chris.
You won't. Just put that side down and get that side as tight to the bead as possible, then put your lighter fluid around the back side of the bead and make fire. haha.
Old 03-11-2013, 02:04 PM   #268
NEWFISHER
NEWFISHER's Avatar
If these guys can do it...
http://www.youtube.com/watch?feature...&v=_meTPTpdkZo
Old 03-11-2013, 02:07 PM   #269
Russell Ashley
Coach, lightly spray some soapy water on the bead of the tire and rim. Stand behind the tire, hold the tire near the top, and take your foot an push on the center of the the rim. Do this all the way around. You won't be able to seat it but try to get the tire to stick on the bead. Keep it verticle, turn it around, and lean it backward slightly so the the rim tends to fall toward the rear. Try to put air in it with one hand while pushing the rim toward the rear. Push it from the center. If it comes loose from the rear bead, repeat until it works, LOL. I mounted my cokers a couple of weeks ago on eight inch rims, so it can be done at home.
I'v heard of the fire method, never tried it though. I paid $980 for my tires so I would not be comfortable trying that..
Old 03-11-2013, 06:27 PM   #270
Coach529
Coach529's Avatar
No proof exists of the event.....but fire worked.
1949 Chevy 3600
Old 03-11-2013, 07:50 PM   #271
Chris.
Good deal mam
Old 03-11-2013, 08:20 PM   #272
Coach529
Coach529's Avatar
pictures tonight!!
1949 Chevy 3600
Old 03-11-2013, 09:25 PM   #273
NEWFISHER
NEWFISHER's Avatar
pictures tonight!!
I'm skipping dinner and waiting anxiously for them
Old 03-11-2013, 09:50 PM   #274
Coach529
Coach529's Avatar
After some carb cleaner and some fire (on the backside of the tire) the rears seated easily.
Bolted them on and am ready to rock and roll.
First impression......wow they look awesome.
Second impression....damn they look tall. 28" with 40 PSI in them......about 1" taller than advertised.
Love the look though. Still waiting on my Shannon cones.
Measurements show I will need some wheel spacers to clear the box sides. Probably 2" to fill up the wheel well as much as possible.
1949 Chevy 3600
Old 03-11-2013, 09:58 PM   #275
wood1
Looking good, will look great with the bed on....
wood1 is offline   Reply With Quote
