04-19-2014, 07:53 PM | #251 |
Vintage 4x4s
Re: 1971 K20- project just get driveable!!
Thanks guys, appreciate all the positive feedback.
Thinking I need 285/75/16 meats on there. The tires on it are about 10 years old and 1/4 of full tread left
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
04-19-2014, 08:32 PM | #252 |
Or 255/85/16 tires. What size wheels are you planning?
As an example Toyo suggests 6.5-7.0-8.0 for the 255 and 7.5-8.0-9.0 for the 285 with both tires being right at 33.2-3" in the M55 series.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-20-2014, 12:29 AM | #253 |
Vintage 4x4s
Hi Tim,
i'm running 7" rims and agree with the guys here that 70 series and up are ok on that rim with a 285 and narrower tire. Going to price out those toyos though. http://67-72chevytrucks.com/vboard/s...d.php?t=582186
04-20-2014, 01:40 AM | #254 |
Found them looking for C30 tires that would live at maxc. GVW. They are commercial all season tires. The 285s are E rated at 3700lb and the 255s are also E at 3400lb. Expect to pay about $300 a corner IIRC.
06-06-2014, 05:31 PM | #255 |
6>8 Plugless........
Jud, how's the truck treating you?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
06-09-2014, 12:41 PM | #256 |
Vintage 4x4s
hi Ryan, I have been wanting to post an update but too busy parting a couple trucks and making pickup box trailers
A few weeks back I swapped a different rear hatch on the topper and put on an ochre tailgate. new lift cylinders on hatch too. Havent driven it much at all since it had driveability issues. 1). it pulled hard when braking. That sealed the deal that i might as well rebuild the front axle that I never got around to before. I figured as long as the hubs are coming off, it getting new dust shields, bearings, rotors, calipers, caliper mounting plates, ball joints, tie rods, seals, lugs, everything but gears and bearings on the carrier. issue 2). is it stumbles alot accelerating. I checked the timing and found the vaccuum advance isnt working. Theres a new distributor sitting here waiting for me to install.
06-09-2014, 08:45 PM | #257 |
I hate to say it, but right now is a perfect oppurtunity to ditch that gasser and small D44. You have the donor pieces on hand, right?
06-09-2014, 08:51 PM | #258 | |
Vintage 4x4s
And if those wer'nt big enough hints, the Sm465 trans sticks going into second gear... I've got a getrag/205/gearvendors sitting here with the 12V and D60....... If the Dana 60 didn't need rotors and seals, or was 4.10, I'd swap it in. Also, I keep thinking the frame on the K20 needs to be beefed up first or I should just find a C30 or longhorn!
06-09-2014, 09:00 PM | #259 | |
06-09-2014, 09:12 PM | #260 |
Vintage 4x4s
While on the topic, I did pick up some more "parts" a few weeks ago. '93 with Spun bearing in engine, body has rust, but chassis is solid and this truck was maintained and has overdrive A518 so thinking maybe I will fix and use this as a winter tow rig, then in 5 years when I'm on my second 12v conversion, harvest these parts.
Trying to figure out if I want to swap in the other 12V from the '90 white truck or try to stab in new bearings with the engine still in the truck???
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 06-09-2014 at 09:22 PM. |
06-09-2014, 09:19 PM | #261 | |
Vintage 4x4s
Below is the '90 getrag, 5spd donor, 3.54 D60 totally shot body and chassis is rusty too. I'm running it now with a D60 rear I rigged up for it. Wouldn't mind trading one of my 3.54 Dana 60's for a 4.10 one.
06-10-2014, 03:49 PM | #262 |
Jud, chances are if it spun a bearing, the crank will need polishied and the rod could need resized. It might be easier to swap engines for now and rebuild this one for your next project.
06-11-2014, 12:02 AM | #263 |
Vintage 4x4s
You think its worth pulling the oil pan in the truck to check it out? Or are the odds of it being good so low, I should just swap engines?
06-11-2014, 03:39 PM | #264 |
It's been a while since I've worked on a 1st gen engine in a 1st gen. I can't remember if there's room to get the pan off without picking the engine up or not. If you have to pick the engine up to remove the pan, you might as well yank it IMO. You're half way there. And if you have my luck, there will be more issues than a light spun bearing.
06-22-2014, 05:54 AM | #265 |
Very nice ochre build.
06-29-2014, 12:22 PM | #266 |
Vintage 4x4s
Overdue for an update. Needed brakes and I figured as long as the hubs are coming off, it getting new dust shields, bearings, rotors, calipers, caliper mounting plates, ball joints, tie rods, seals, lugs, everything but gears and bearings on the carrier since that seems good, fluid was good, and it only spins a fraction of the time anyways. Lots of PART$
06-29-2014, 01:00 PM | #267 |
Proprietor of Dale's Corner
It's gonna drive like new
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-29-2014, 02:44 PM | #268 |
its a good feeling to get the front back in good order. driving something that is nice and tight in the front makes a big difference in your attitude towards the vehicle.
06-29-2014, 03:46 PM | #269 |
GEARHEAD
Hard to believe how quick all those new parts add up. I did the front suspension rebuild on my C10 this winter and without the brakes spent a few hundred. And that was after bargain shopping for a while. There won't be much left to overhaul on this truck soon. Great job as always.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
06-29-2014, 04:11 PM | #270 | ||
Vintage 4x4s
I hope so Dale, really curious to test out the rear brake conversion with proper brakes on all 4 corners!
With a proper front end, it will be interesting to see how good/bad the stock steering box is. My only real experience with a roadworthy K20 was with an upgraded AGR variable ratio box.
06-30-2014, 07:52 PM | #271 |
Nice looking pile of parts. It's never ending it seems.
08-12-2014, 09:49 AM | #272 |
Vintage 4x4s
Pics of front end when i was working on it.
working on distributor replacement now. vacuum advance wasnt working at all. Hope that solves the chugging while accelerating.
08-12-2014, 01:33 PM | #273 |
Vintage 4x4s
Pic for above post plus one of a test fit on 32' trailer. Plenty of room, a 30' would work
08-12-2014, 06:16 PM | #274 |
Making a trip soon Jud?
08-13-2014, 09:30 AM | #275 |
Vintage 4x4s
Ryan, no trips with it this month unless i get time to part a couple trucks and make time for a scrap run. I was either faced with replacing the axles on the tandem with heavier ones but the price was getting up to 1600 just for axles with brakes and hubs so i thought it may make sense to get another trailer, then i saw this older but well maintained 2 place for about the same price and couldnt pass it up. Now i really need to get that diesel going or do the cam/tune/headers on the lq4 At least the unloaded weight is fairly low on this one, and its pretty low so drag will be less. Feels about the same weight as my tandem empty (3600), maybe a tad lighter.
