Old 05-11-2015, 10:41 AM   #251
bnoon
Re: Project Mr. Green Jeans (now 5.3 LS turbo build!)
Trying to fix it.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 05-11-2015, 02:40 PM   #252
bnoon
Shows as public now...
Old 05-11-2015, 03:33 PM   #253
68Timber
I know the pieces fit
68Timber's Avatar
Awesome! I lol'd a little over your reaction, but only because I get that way too.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-11-2015, 04:32 PM   #254
bnoon
Yeah, it was a true "yay" moment after the Friday night I had at work. Was supposed to be a half hour maintenance window for our server that turned into a 5 1/2 hour mad thrash, that then killed half of the day on Saturday to sleep. Sleep pattern was still a little off last night too.
Tonight I can tune it and remove the VATS that kills the truck after a second or so now (I left it in on purposed in the video, just didn't have time to fire up the laptop yet). And I also need to mount/wire up the fans, and tape up the harness... Then I can maybe test drive it.
Old 05-12-2015, 09:32 AM   #255
bnoon
I went to program the truck last night and no fuel pump prime with key on. Verified power to the fuse block and ECU through the PSI harness. Looks like my ECU died. Used/verified one from Ebay seller coming by Saturday. Delays delays...
Old 05-12-2015, 10:18 AM   #256
rajincajintj
eff that
that is ****ty news man. computers are a pain sometimes
76 c30 3+3 Camper Special - 12V 5.9l 6BT Cummins and 47RE
rajincajintj is offline   Reply With Quote
Old 05-12-2015, 01:23 PM   #257
bnoon
No doubt.
Old 05-18-2015, 03:19 PM   #258
bnoon
Well Friday I got the used PCM from Ebay seller. Plugged it in, worked fine. Pulled the stock config, removed VATS, downstream O2 sensors, and reprogrammed it. Fired right up. Then, as I was topping off the coolant with it running, the dang thing dies and no fire on restart again. Killed another one. Something is wrong with my wiring... I had thought that I had caused it with loose battery and ground cables the first time since I had left everything loose just in case I needed to rip off the wiring really quick for fear of fire or something, but apparently I really did wire something incorrectly. Another used PCM is on its way from the same company and tonight I will be going pin by pin checking for power where there shouldn't be, ground where there shouldn't be, or dead shorts. Ugh.
Old 05-18-2015, 05:04 PM   #259
rajincajintj
Ugh.
im not sure you're allowed to tell us how you really feel.
but we feel you.
best of luck
Old 05-20-2015, 08:31 AM   #260
bnoon
but we feel you.
best of luck
Yeah, it comes up with stars and punctuation marks on the forums.
I went through pin by pin and found ground where there were supposed to be grounds and power where there was supposed to be power, nothing out of place. The only thing I was seeing that was questionable was about a 1 volt difference from keyed ignition power vs. power direct from the battery through the junction block, so I'm thinking that the 1 volt difference may be back feeding through the PCM somehow and killing it. I'm going to move all other keyed ignition powered items off to their own feed, power the ignition feed to the PCM through a relay to get full battery power, and upgrade the grounds to the frame and body and bring them all to one point to eliminate any voltage differences.
Old 05-20-2015, 09:48 AM   #261
rajincajintj
sounds like the "non-running" state is OK. how much running time do you get before the PCM dies? do you have enough time to make the same ground and voltage checks while its running?
Old 05-20-2015, 03:07 PM   #262
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Wow, the quick start up sounds really healthy! That sucks about the ecm fry-ing issue. It's always some small PITA problem. Good luck with it Brad!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-21-2015, 08:57 AM   #263
bnoon
The first one only had a few split second test fires on it for running time, the rest was about 20 minutes total of "key on" time while I was checking the fuel pump for prime pressure/etc. The second PCM had about 8-10 minutes of "key on" time and 8-10 minutes of run time, so similarly a 16-20 minutes total with the keyed power turned on. It's a power issue, not just while running.
Thanks man! The 5.3 with this LS9 cam is very mild compared to the built 350 that used to be in there, but the power brakes will sure thank me for that LOL! The 5.3 with the 4L65E will be quicker too with the steeper first gear I'm thinking, then comes the boost...
Old 05-22-2015, 09:18 PM   #264
bnoon
Runs and drives wahoooooo!!! I still have to go bleed the brakes and install the fans and tune tune tune, but it's alive!!! Slow drive through the neighborhood points out the rich condition right now, but to have it MOVE under its own power... So nice!
I put the power feed to the pcm on a relay and separated the other power feeds to the speedometer adapter on a different lead as well as the fuel pump all as I stated before. The second PCM even still works! Now I can burn my final tune to my third PCM and have a true spare. Ahhhhhh I feel so good right now.
Old 05-22-2015, 10:24 PM   #265
bnoon
I couldn't wait until tomorrow. I went out and vacuum bled the brakes and took it for a test drive for real! Wahoooo! Now I can concentrate on the tune and fans tomorrow.
Old 05-26-2015, 09:45 AM   #266
rajincajintj
congrats man, i know that feeling, especially after some adversity.
good luck steering with that raging boner!!
Old 05-26-2015, 09:08 PM   #267
Dieselwrencher
That's awesome you got it fihured out and were able to take it out on a drive!
Ryan
Old 05-27-2015, 09:22 AM   #268
bnoon
Still need to work on the tune badly. Idle is OK, but startup and driving are still messed up. My VE tables are nowhere near where they need to be and I'm still wiring up things left and right and need to wire loom everything. Thinking of farming out the tune to Lund out in Adel, but I'd hate to give it up for a few days and lose out on the time on other parts of the build. I hate it when a timeline shrinks too fast!!! And I have to change the power steering pump out now because I didn't notice before that the shaft on this one is bent and makes the pulley wobble. That will cause the belt to wear prematurely and may kick off at higher revs. Uggggggggh!!!
On the good side, the 90's Areostar van electric fans are mounted up.
Old 05-29-2015, 11:28 AM   #269
bnoon
Tuned it some last night and it's running better, still a ways to go though. I have one fan trigger that's not working and the wire itself tests good and the spare pcm tests the same way. For now, both fan relays are triggered at the same time from fan 2 lead. Going to double check the pin out for that wire for fan1 since there's no ground when triggered now.
Old 05-30-2015, 12:25 AM   #270
Dieselwrencher
Brad, are you trying to get it done to take it on power tour next week?
Ryan
Old 06-01-2015, 04:32 PM   #271
bnoon
Yes sir! Mostly ready right now. I have a few issue remaining that are intermittent (lifter tick and warm restart). Both come and go. I've ordered adjustable rockers to see if I'm having a net lash issue like many have reported and I will have those tomorrow. Easy to install. If that goes well, the truck will be going. If not, it may have to wait for next year. The warm start issue isn't bad enough to keep me from going, just embarrassing when it pops and bangs really loud, then starts fine as if nothing had happened.
Old 06-04-2015, 08:50 AM   #272
bnoon
I've been driving back and forth to work this week and no issues yet that would keep me from going on Power Tour. Working on the tune and cleaning a few other little things up like wiring/etc. tonight after work. We leave in the morning for Madison, WI!!! VIP baby!!!
Old 06-04-2015, 07:45 PM   #273
Dieselwrencher
Have fun on the trip and good luck as well!
Ryan
Old 06-16-2015, 04:13 PM   #274
bnoon
I ended up not taking it on Power Tour this year. We looked at the weather predictions for the stops along the way, and combined with a slight stumble that developed in my tune, we made the decision to drive my Mustang instead. Worked out fine though. I got to auto-x the Track Pack and see just how good I was compared to the rest of the crowd. I did a 24.2 seconds as my best and that was a second and a half better than this kid in a 4th gen LS1 Camaro that had RE11 tires, upgraded suspension (sways, panhard rod, camber plates), harnesses, and full cage... His jaw dropped after my final run when I was just starting to get used to the layout. Heheheheh!
Now, back to Green Jeans... Tuned out the stumble by smoothing out the transition areas of my VE tables (between part throttle and coasting/idle, I had too big of a jump in air) and also calmed down my idle surge by limiting the RPM adder spark and RPM error limits. Now, to get the 80# injectors installed and switch to E85, then go after WOT fuel/spark on a dyno!
Turbo ordered today. I ended up going with a GT45 88mm Billet wheels .96 ar with a T4 flange. Up to 1000 horse, though I will settle somewhere in the 600-700 area. Installation and fabrication coming soon.
Old 06-16-2015, 10:59 PM   #275
Dieselwrencher
Sorry to hear you didn't take the truck, but at least you had the stang to take and have fun in still! That turbo should more than get the job done!
Ryan
