06-07-2019, 02:22 AM | #251 |
It's a catastrophic success.
Re: Show off your Wheels
Ridlers
06-08-2019, 12:29 PM | #252 |
Sweet ride sneakysnake.
06-09-2019, 04:41 PM | #253 |
04-22-2020, 06:54 PM | #254 |
Chrome smoothies 16x8 with 235/60 16 tires all around.
05-02-2020, 05:49 PM | #255 |
With trim rings and without trim rings:
1951 Chevy Panel Truck |
05-02-2020, 09:19 PM | #256 |
I kinda like it without . How about you?
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
05-03-2020, 09:42 PM | #257 |
Thanks, I left them off. It looks more utilitarian, like a panel truck should.
05-03-2020, 10:33 PM | #258 |
I went from rally wheels in full trim to rally wheels with no rings to steelies with stock 72 caps on my '67 just in the last year.
05-03-2020, 10:39 PM | #259 |
Here's a recent pic . I know it's not a 47-59 b b but I couldn't help myself.
05-04-2020, 10:36 PM | #260 |
15x8 chrome rally’s 235/75-15 all around
05-04-2020, 11:11 PM | #261 |
18x8 and 18x9.5
05-05-2020, 01:59 PM | #262 |
Lotta good lookin trucks and wheels in this thread! Here's mine, with a few tire/wheels combos I have had. This truck has a '79 Camaro front clip, done the "No Limit way". It has the 10 bolt rear axle out of the same '79 Camaro
First picture: 18" Foose Legend wheels, 18"x7" in front (4" BS) with 225/40-18 tires. 18"x9" rear (5.25" BS) 275/40-18 BFG G-Force Sport Comp-2 tires. If you corner hard, there's no way that these would fit in stock tub opening. They'd be too close on inside and outside. With my '79 Camaro 10 bolt axle, I have good clearance to fender lip, but rubbed on bedside on both sides. Second picture: 17" Boyd Coddington Junkyard Dogs, 17"x8" front and rear, 4.5" BS. 225/45-17" up front, and 255/45-17 Cooper tires. These fit, but rubbed while cornering hard. I found that out when I saw burnt paint on the inside of the bed sides. 1/4" spacers would have resolved this. Third picture: 15" Cragar Chrome Smoothies. 15"x6" up front, with 3.5" back spacing. 15"x8" in rear, with 4.25" BS. BFG Radial T/A's 205/60-15 in front and 245/60-15's in rear. I bought a set of 275/60-15 tires, but would have needed a 1/4" spacer to make them fit without rubbing. This front wheel/tire combination is the only one that I have had that has not rubbed at all.
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
05-10-2020, 02:36 AM | #263 |
Curious if your wheels rub and would like to know the backspacing BUT... I guess that wouldn't tell me anything unless I knew what rearend it has and the width of it along with what front suspension it has.
Looks nice though. I really considered those for mine.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
05-10-2020, 11:47 AM | #264 | |
truck gets tons of compliments on the wheels the lip and offset look great. http://67-72chevytrucks.com/vboard/s...d.php?t=796833 Im located in tustin not far from you in you ever wanted to swing by and bolt them on |
05-10-2020, 04:02 PM | #265 |
My 51 GMC, Wheel Vintiques 6x16 front, 8x16 rear , powder coated in red with stainless steel trim rings and smooth baby hub caps,
05-10-2020, 09:26 PM | #266 | |
05-10-2020, 09:59 PM | #267 |
What you heard is inaccurate. There are many, many choices of tires in 16".
It's 15" that have limited choices. |
05-11-2020, 02:32 AM | #268 | |
to get the tyre size/ratio that I wanted, |
05-23-2021, 05:36 PM | #269 |
I saw this truck at a show recently, had Keystones on it. Fifteen inch front and back, not sure of the rim width. Can’t say I’ve seen many Keystones on truck, but it looks good.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch. |
05-24-2021, 01:45 PM | #270 |
Changed from my chrome smoothies (posted back in 2019) to these spoke style. Went from a 16x8 to 17x8 (235/55 17 tires).
05-24-2021, 06:27 PM | #271 |
Detroit Steel 20x8
05-24-2021, 10:06 PM | #272 | |
I bought some 17x7 & 17x9 smoothies I will be painting and using with '51-'52 car caps and narrow ribbed beauty rings. I need to test mount the to see how they fit first.
05-25-2021, 01:01 AM | #273 |
American Racing wheels
20x8 245/45-20 20x9.5 275/40-20
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
