Old 04-01-2016, 01:34 PM   #251
aotte1
Re: 64' K10 Project Long Bed
Front Dana 44
Got a bunch of the front '79 Dana 44 rebuilt and gears changed out. Did bearings, seals, u-joints, and 3.73 gears. The gears got set on third try.
The main axle was powder coated gloss black, and spindle, backing plates semi-gloss. (the backing plates were originally gold cad with black paint on them). Using Warn Premium hubs, as they look kind of original '64 ish, per 61K10 build. Working on rebuilding calipers next.
Note: The last photo shows the original '64 Dana 44, that is stored away, to be reinstalled later.
aotte1 is offline   Reply With Quote
Old 04-01-2016, 04:18 PM   #252
61K10
61K10's Avatar
Les--the later brake hoses must mount different as they are only a little less than 19". so look on rock auto as they have pics and the specs.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-01-2016, 04:23 PM   #253
61K10
61K10's Avatar
forgot a pic of mine
1961 chevy K10
Old 04-01-2016, 06:54 PM   #254
aotte1
Kimble,
Thanks for measurement, will check out rock auto photos for ' 61 and '64.
Photo too.
Les
Old 04-02-2016, 12:20 PM   #255
aotte1
Jr West Coast Mirror Differences in Arms
Have two pair of GM Jr West Coast Mirrors with different arm length that extends from the cab. Do not know why the differences. Have checked three other trucks and they have the shorter arms. Will check truck that had longer arms. It may be a Forest Service Fleet truck, special order? Except for arm difference, the whole mirrors are exactly the same, the arms are both consructed exactly the same. They both also have the thin rubber film on the inside of the clamp that attaches to them.
1/2 vs 3/4 ton?
Old 04-02-2016, 12:21 PM   #256
aotte1
Another photo.
Old 04-02-2016, 02:14 PM   #257
60-66
60-66's Avatar
Les , 1963 , 1964, 1965 are the short arms. 1966 is the longer arm mirror. Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 04-02-2016, 02:27 PM   #258
aotte1
Jon,
Thanks!
Les
Old 04-10-2016, 09:34 PM   #259
aotte1
Got two more pick-up loads of powder coated parts. I like the process used to clean the parts as it does not open up the pores on the metal, like abrasive methods. Still have the frame and cab to pick up, along with a few other parts, like the BA hood. Just my option, for powder coating, really like the quality you get from commercial/industrial companies. Believe their equipment and quality control is good.
Old 04-10-2016, 09:41 PM   #260
aotte1
a few more photos. Maybe get the frame and cab later this week. Working on the bolts, brackets, clips this week, along with parts that did not get powder coated, because the have rotating/moving parts, that are difficult to take apart.
Old 04-10-2016, 10:11 PM   #261
aotte1
On the non powder coated parts, ones that move, using a very thin ceramic film/coating, that is very hard along with high abrasion resistance.
Old 04-10-2016, 10:22 PM   #262
RANDY COX
RANDY COX's Avatar
WoW I see lot'sa new parts lookin good...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 04-11-2016, 07:56 PM   #263
aotte1
Randy,
Thanks, things are getting much better, now that most of the parts are clean.
Les
Old 04-19-2016, 09:46 PM   #264
aotte1
64 K10 Front Spring Frame Rear Shackle Removed
One of the front spring rear shackle bolts was stuck in the frame bushing, and now have it removed. Used Kimble's advice for how he removed a stuck one from his '61 K10. Lube it with penetrating fluid, and keep doing till it loosened up. I used Kroil oil, along with two grade 8 bolts bottomed out on the treads, socket covering both and long breaker bar. Not sure how many foot-lbs of torque used on breaker bar, probably between 80 and 100 ft-lbs. Just kept applying force in one direct, then the other. It finally started to move a little, more back and forth, and it finally came out. All the time adding Kroil oil on the threads and through the internal port.
The next to last photo shows the oil used, and internal port in the bolt/pin.
The last photos shows the threaded frame bushing and the threaded bolt/pin that fits inside the bushing. Will show detailed photos of whole front spring shackles soon as put back together.
Old 04-19-2016, 09:58 PM   #265
aotte1
Big day bringing the frame, cab, and other parts home from powder coating.
Old 04-19-2016, 10:23 PM   #266
aotte1
'64 K10 Frame
A few more photos of the frame to follow, below the frame at the start of the rebuild.
Old 04-20-2016, 01:25 PM   #267
61K10
61K10's Avatar
Looks good Les!! I wish i could of had my frame power coated, but had no trailer to trans port it, and too cheap to rent one lol. glad you got the shackle pin out, mine was the same way. after i cleaned the sleeve that the pin screws into, it was in good shape. It had the same amount of movement as the new pin and sleeve. I did use a new pin though.
What rear bumper are you going to use?
kimble
1961 chevy K10
Old 04-20-2016, 11:00 PM   #268
aotte1
Kimble,
Rear bumper will be a dealer installed step bumper. It is from a North Texas Chevy dealer, with their name embossed into it. Bob Tedford Chevrolet in Farmersville, near Dallas, Greenville and McKinney, TX. Only know this from internet search. When truck is done will have to send them a photo. I found the bumper here in KY, from a person stationed at Ft Knox.
On the front spring rear shackle did the same as you. Original bushing/sleeve cleaned up nice, and did use two new pins in the frame.
Les
Old 04-20-2016, 11:19 PM   #269
chevy.c10
chevy.c10's Avatar
Sweet looking bumper! Mines similar but from a different dealership.
chevy.c10 is offline   Reply With Quote
Old 04-20-2016, 11:20 PM   #270
aotte1
A couple of photos of the front spring, rear shackle and bushing assembly.
Photos below;
1). just overall image of spring parts;
2). the front spring rear shackle parts, it shows the pin installed in the threaded bushing/sleeve that goes in the frame. Mine were ok so did not replace them. The parts are the pin/bushing, rubber gasket, lock washer, nut, and two shackles. Note: the pin has tapered shaft where the shackle fits on it, and the shackle holes are tapered too, to fit the pin.
3). show the pin partially screwed into the frame bushing. Will try to work on my photogaphy to eliminate glare!!
4). shows the pin installed; and
5). shows the rubber gasket installed.
Next the metal shackle is installed onto the pins tapered shaft, followed by lock washer and nut.
Old 04-20-2016, 11:39 PM   #271
aotte1
In the front spring rear eye, installed all the parts on one side, as this allowed me to use the nut as a way to turn the pin into the spring eye threaded bushing. Next placed the spring with shackle onto the frame pin, installed lock washer and nut. Through out the install used lots of grease on both threads, along with lots of grease through the grease fitting. Making sure the bushing and pin threads were full of grease, to ensure minimal wear of these parts. Regular greasing will be needed as truck is driven.
Old 04-20-2016, 11:52 PM   #272
aotte1
C10,
Nice bumper from Texas too.
Les
Old 04-28-2016, 09:08 PM   #273
aotte1
[SIZE="4]Rockwell T221 Transfer Case '64K10[/SIZE]
Worked on duplicating the color for the T221 transfer case, and came up with a mixture of two paints that matches the original color. First three photos are of new paint job.
The below photos show other transfer case mounting parts.
Old 04-28-2016, 09:17 PM   #274
aotte1
A couple more photos of TC mounts and U bolts.
Old 04-28-2016, 09:28 PM   #275
aotte1
Transfer Case frame area photos.
