Old 07-08-2021, 03:26 PM   #251
EagleChief
EagleChief's Avatar
Re: Doing LS Swap - I have no idea what I'm doing!
Looking at my crank, it has the part number for the 5.3. I am going to pull a plug this evening and use my new inspection camera to look at the cylinder heads. The camera arrived this morning, so hopefully I'll know something tonight.
I guess, once I determine what I have and assuming it's a 5.3, then I need to check my injectors to see if they are flex fuel type, or the other. The VIN I have from the salvage is definitely a 2003 Tahoe, 5.3L Flex Fuel (L59), 2WD.
I'll report back as soon as I look at the cylinders.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 07-08-2021, 03:44 PM   #252
Thealien
Thealien's Avatar
Most if not all of the flex fuel engines had stainless steel fuel rails.
That doesn’t mean someone couldn’t of changed it.
Old 07-09-2021, 01:38 PM   #253
EagleChief
EagleChief's Avatar
Alright, cylinders are dished, so that, along with the crank, verifies the motor size - 5.3 motor. Ran the TAC module number and it comes up as a '03-'05 part number. Programmer was a little concerned due to some discrepancies of PCM and TAC modules not working together.
Anyway, got that stuff worked out and he's ordered the harness and will get the PCM flashed and ready to go. It's now a waiting game for the harness to come in! Due to supply issues, it could be a couple of days - or, it could be weeks... who knows.
Old 08-02-2021, 09:25 AM   #254
EagleChief
EagleChief's Avatar
Got the call this weekend! My harness arrived at the tuner and he was finishing up my tune. Going to pick it up sometime this week. Hopefully, I can start working on the fuel system install. Want to get the tank mounted and start running the fuel lines. To do that, I'm going to have to cut out a couple of cross-braces - one Z-style crossmember on the frame, and one of the bed braces. I grabbed a piece of 1-1/2" angle from work to use as a mount/support for the tank. I'll fit it onto the frame rails and drill it to bolt into the frame, then I can drill the mounting holes for the tank.
Question - you guys that have done the Wrangler tank, did you use any tank straps to help support the tank? Or, has it been ok to just use the tank flanges to support the tank?
Old 08-03-2021, 04:23 PM   #255
EagleChief
EagleChief's Avatar
I need to cut this brace out to install my gas tank. Any ideas? I started the cut on either side, next to the frame. I'm thinking I'm just going to run along the top - as close as possible. Then, see if I can bend that out of the way and cut the other side of it, and hope that I have enough room.
Old 08-04-2021, 12:44 AM   #256
Richard
I am not a fan of using flanges on the tank to mount it. I have never seen one mounted that way from the factory. Seems like an easier less costly route. Must be a reason cars do not come that way. My thought is it may be okay for a rigid boxed or tube frame. But for an old frame that flexes and moves a bunch, not a good idea to me. A lot of people do it. Most if not all aftermarket tanks are made with flanges, which is one of the reasons I avoided aftermarket. Just my opinion.
Getting the rivets out can be a pain, but not really any harder than cutting the crossmember.
Richard
Old 08-09-2021, 10:51 AM   #257
EagleChief
EagleChief's Avatar
I've been debating making some tank straps, or buying some, to help hold the tank in place. The tank I bought, actually has mounting holes on each corner of the tank flange, so I'm guessing that's what they are for. Now, it is only a 15 gallon tank - which I know will still be heavy when full, but, shouldn't be too bad.
Old 08-09-2021, 11:18 AM   #258
ls1nova71
ls1nova71's Avatar
You haven't looked back far enough. Fords, and I'm sure most other manufacturers from about 1932 til around 1948 all had flange mounted tanks. They were notably smaller though so that may be a factor to consider.
Personally I would put straps on a tank in a truck just for the fact that if you put the flange on top of the frame, you wouldn't be able to drop the tank if need be.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-10-2021, 02:58 AM   #259
Richard
You are correct that I had not looked back that far. Vehicles were still in their infancy back then so I still stand by what I said.
Richard
Old 08-25-2021, 03:49 PM   #260
EagleChief
EagleChief's Avatar
Had a little time to cut on the truck a little more last night. I was able to cut some of the bed crossmember out. I still need to get some more of it, but trying to get my Harbor Freight grinder w/ cutoff wheel up under the bed is a tight fit. I may try my Sawzall next to see if it works. I didn't get pictures - will try and get some next time I'm under there.
Old 11-30-2021, 12:24 PM   #261
EagleChief
EagleChief's Avatar
So, it's been quite a while since I've been around, or done anything to the truck. Most of the family came down with Covid, and we lost a family member recently. But, we've been talking about getting after it again - 3-4 months later. Since most of my free time is late at night, I thought I might start trying to lay out the wiring for the motor. I don't where to start. Do I start by mounting the computer somewhere, or do I start hooking stuff up and then mount the computer to where-ever it will reach?
I ended up having a harness made and it's labeled for each connection. It's actually a PSI harness, so I'm not sure how much extra wire is there for the cpu mounting location. I haven't really looked at it too much to try and lay it out.
Old 11-30-2021, 12:53 PM   #262
jjzepplin
jjzepplin's Avatar
Sorry for your loss. These are difficult times. Maybe working on the truck will help keep your mind busy. Good to see you back at it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-30-2021, 01:07 PM   #263
A1971Blazer
A1971Blazer's Avatar
sorry about the family situation...life happens
as far as the harness is concerned...I would make all the connections, clean up and loom the wires as best you can, then see how much slack you have left going to the PCM and relays
that will determine where to place them...the relay and fuse block should be somewhere accessible for servicing if the need arises....
if you are going to have AC....that limits the amount of room there is behind the dash.
I'm still debating where to put mine on my '67 build , I'm also adding a cruise module...so there's another component to mount....somewhere?
good luck with it...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 11-30-2021, 05:58 PM   #264
LS short box
On my 68 LS swap I mounted the ECM behind the glove box along with the relays. The fuse block which has CEL light I just screwed it to heater box just low enough so I could see it from the drivers seat. I had to section the paper board glove box liner to make room for the ECM. Still had a pretty decent glove box.
LS short box is offline   Reply With Quote
Old 12-01-2021, 12:13 PM   #265
EagleChief
EagleChief's Avatar
I took a look at my harness last night. It does have a grommet on the main harness to allow for entry through the firewall. Maybe there is enough wire there to mount inside the cab? I'm lost at electrical stuff. Luckily, the guy I dealt with labeled every connection and wire on the harness. The harness was made by PSI Conversion. Everything is already covered in wire loom and ready to go. I just have to figure out where to start as far as hooking things up and running the wires.
Old 12-01-2021, 02:09 PM   #266
biketopia
Find the area of the harness with the coil and injector connectors. Make sure you have them on the correct sides and then just kind of lay the harness there. then move wires around seeing where they go and just have it kind of where it's going, then make adjustments accordingly.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 12-02-2021, 10:15 PM   #267
Low Elco
I did the wrangler tank adn built a frame around the flange, then set it on rubber. It's set up so the front rides on top and the back bolts up, so when you pull it, you can jam the front in and swing the back up. Useless pic here- http://67-72chevytrucks.com/vboard/s...=501131&page=6
and here http://67-72chevytrucks.com/vboard/s...=624310&page=7
Ah, here's a better one- http://67-72chevytrucks.com/vboard/s...=624310&page=9
Hope it helps!
Low Elco is offline   Reply With Quote
Old 12-03-2021, 12:17 PM   #268
EagleChief
EagleChief's Avatar
I like that idea! I'll probably steal that for my install. My other option was to just bolt the angle I have onto the frame and bolt the tank to that angle. That way if it ever does have to come out, I can just undo the piece of angle and take it out that way.
Old 12-05-2021, 08:38 PM   #269
clay68c10
clay68c10's Avatar
My vote is to put the PCM under the hood if your harness will allow it. GM did it that way, it can handle the heat. The under dash is so tight that it’s hard to find extra room without compromising something else.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-08-2021, 10:15 PM   #270
Factory Guy
Factory Guy's Avatar
For anybody interested this guy JR has a youtube channel where he walks you through how to do a LS swap into a squarebody. From pulling the donor engine at a junkyard and how to rig up the fuel system...
He has all kinds of info.
Here's a link to one of his playlists for a LS swap.
https://www.youtube.com/watch?v=dhVZ...WvfqpMN8YkO9ZY
Scotty Baccus has a great guide on what to do and look out for when doing a LS swap his article is at:
https://tejassteelworks.com/wp-conte...uide-73_87.pdf
Factory Guy is offline   Reply With Quote
Old 12-12-2021, 12:40 PM   #271
Jdubs71
Jdubs71's Avatar
I loverJR’s content…..”Buy once cry once” LOL
Jdubs71 is offline   Reply With Quote
Old 03-14-2022, 11:08 AM   #272
EagleChief
EagleChief's Avatar
Well, haven't had much to post about lately - or, at all for that matter. I haven't had time to get to the truck with family time. I did spend about an hour in the garage the other night (Friday night) after everyone was asleep.
I put the exhaust manifolds on, the new dipstick tube (Super hard, I know), and started laying out the wire harness. I hooked up all the connections I could easily get to on top of the motor (injectors, alternator, coolant sensor).
I still need to verify some of the locations for the other stuff and try and get to the rear and under the motor to hook up the rest of the connections. Anybody know of a diagram that shows where all the connections are located?
Old 03-14-2022, 08:21 PM   #273
kev2809
low n' slo
kev2809's Avatar
I don't know if I missed it, but what tank setup are you using?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-15-2022, 01:16 AM   #274
Accelo
Accelo's Avatar
Here is a picture of where my ECM ended up. Yes it's connected, the wiring comes up between the fender well and the cab. I plan on painting it black but haven't got around to it yet. Factory holder behind it with a wire bail keeping it in.
My harness was a conversion, not custom, so I had only so much wire to work with.
Accelo is offline   Reply With Quote
Old 03-15-2022, 09:15 AM   #275
biketopia
Progress is progress!! I've been trying to get my Camaro fired up so I can get the truck moved in before my first kid is here in June, never enough time! As far as "where all the connections are located?" what all are you looking for, engine sensors, truck connections, others??
