Closed Thread
Old 09-03-2011, 07:57 PM   #2726
mdaven@aol.com
Re: What did you do to your truck today!
Rewired the starter, had to adjust brake light switch so brake lights would not stay on, minor adjust to carb, fired it up for first time since last November. Drove around the yard, aired the tires, installed new plates and registration. Need inspection and then road test for reliability. Long time coming.
mdaven@aol.com is offline
Old 09-03-2011, 08:26 PM   #2727
wilbilt
wilbilt's Avatar
The factory tint door glass from eBay arrived. Unfortunately, the window run channels did not. I installed the driver side glass anyway, since there was none previously. It could rain tomorrow, who knows?
Installed the el cheapo seat cover I bought after augmenting the remains of the original foam with bits and pieces scrounged here and there. It looks like crap, but will do for now.
Still fighting an idle problem, the 350 acts like it has a vacuum leak. Idles all over the place and dies when put in gear. I verified the timing is correct, but have to turn the idle up and richen the idle mixture to keep it running. It has an Edelbrock (Carter AFB) carb on an adaptor plate (Q-jet manifold). Installed new gaskets above and below the spacer, no improvement. I have a rebuild kit for the carb, but didn't feel like diving into that today. Maybe tomorrow. Irritating.
Cleaned and de-rusted (polished) the drivers side chrome channel that holds the door panel. Since there is no door panel, it seemed convenient.
Cleaned and polished the PRND2L lens. I can almost see through it now, a great improvement! Onward and Upward.
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline
Old 09-03-2011, 08:36 PM   #2728
kcsa75
kcsa75's Avatar
New front brake pads. That squeak was driving me nuts!
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline
Old 09-03-2011, 09:54 PM   #2729
chevypoint
chevypoint's Avatar
Finally got some time to work on the trucks today. My brother came by and helped me and my son pull the engine and trans out of the parts truck today. I will try to finish stripping the truck down tomorrow.
71 c20, 350/automatic
71 K5 Blazer, 350 3 speed (really my 16 yr old sons)http://67-72chevytrucks.com/vboard/s...d.php?t=686111
71 GMC build thread; http://67-72chevytrucks.com/vboard/s...d.php?t=468765
47 Chevy Aerosedan, 403 Olds/350 turbo
69 Camaro, 307/powerglide
06 Silverado Z71
chevypoint is offline
Old 09-03-2011, 09:57 PM   #2730
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
drove it
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline
Old 09-03-2011, 10:42 PM   #2731
windmill
windmill's Avatar
got my 3 inch lowering rear leaf springs in friday, got to put them on today and the shackles too,,, bolts would not go through the eyelets so had to drill them out some.. but worked out well.... guess i need to get some pics put up too...
72 swb pickup
http://i124.photobucket.com/albums/p...k/100_0958.jpg
1967 chevelle ss
1966 mustang getting a l33 ls motor
1969 chevy dump truck
1989 mustang 6.0 ls best time of 1.29 at 5.91
https://www.youtube.com/watch?v=JtbooZoGZmQ
windmill is offline
Old 09-03-2011, 10:53 PM   #2732
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today!
I put the trickle charger on mine today before I left for work.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 09-03-2011, 11:31 PM   #2733
67Slider
67Slider's Avatar
Installed a new 1 inch, phenolic, 4 hole spacer in between the edelbrock performer intake and the 1406 carb. seems to have stopped the hard starts after it warms up. Drove it about 60 miles today with my two boys. They dig cruising in dads old truck.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 09-03-2011, 11:48 PM   #2734
Tmwoodall
Got my fronts in from UPS, mounted balanced and on the truck.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline
Old 09-03-2011, 11:49 PM   #2735
purple gas
well, I was out in the garage working on this furniture project, kept looking at my truck feelin all guilty that it hasn't turned a wheel in I don't know how long. Then an Indiana Jones movie came on the TV, So I had a beer and well,,,, maybe tomorow
I got a bench seat baby, you don't have to sit over there.
purple gas is offline
Old 09-04-2011, 12:07 AM   #2736
red71c10
The Red Menace
red71c10's Avatar
Took the kick panel vents apart so I could vacuum out the the dead leaves. Cleaned and oiled everything before putting them back together so they open and close easier and quieter. Very nice on a hot day to be able to open those vents without being blasted by bits of dry leaf!
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline
Old 09-04-2011, 01:07 AM   #2737
RossRinSD
RossRinSD's Avatar
I ran into a very similar problem with my lift kit. I could not get the bolts back out of the rear of the front leaf springs. I had to slide my sawzall in there and cut them out. There was no metal sleeve in there and the bolts had rusted/melted to the rubber.
I couldn't get my bolts through the new sleeves either, and installed everything without them.
RossRinSD is offline
Old 09-04-2011, 01:20 AM   #2738
Andy4639
Old member
Andy4639's Avatar
Are those the Boss wheels? Looks great against the black frame.
Andy4639 is offline
Old 09-04-2011, 01:56 AM   #2739
laplander
Since I'm gimped out from work right now, I'm relying on my 16 year old to do most of the work. He got the 2" dropped coils put on the front and and 4" dropped in the rear almost done. That and the new car style rallys change the whole look of the truck. Next week I hope to have the dropped spindels and lowering blocks ready for him to put on. LOL
laplander is offline
Old 09-04-2011, 03:04 AM   #2740
Tmwoodall
No. Very similiar, they are like a cross between the Coys and the Boss wheels. Straight bolt on, no modification needed with good B.S. Showwheels Streeters, bout the same maybe a bit less than the Boss setup.
Only potential downside to them is the brand is carved into one of the spokes, but I don't mind it, especially for the price.
Old 09-04-2011, 09:25 AM   #2741
rob32472
Love the wheels. Can you give more info on them?
rob32472 is offline
Old 09-04-2011, 09:43 AM   #2742
hjewell2
hjewell2's Avatar
Finished the paint on the cab today, put wedge plates on the rear axle to readjust pinion angle, finished the frame rails.
hjewell2 is offline
Old 09-04-2011, 10:23 AM   #2743
sboris
sboris's Avatar
Had a wedding yesterday...UUg. Blew my saturday. Rushing out to start stripping cab
and if my help arrives I`ll get the box off today to see what I got.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline
Old 09-04-2011, 10:36 AM   #2744
prairewolf
resized newer pictures of truck, .... yep,.. that one hole in passenger floorboard has to be Rifle bullet hole. ... exited close to dead center of tire, ... might explain why truck only had 3 original steelies when I baught it.... I had never noticed or thought about that hole till just the other day when I saw it........ I baught new oil for it and need to get rear lights to quit blowing fuse.
perfect weather to work on truck or to blow it off for another day. time will tell.
p.s .. the dual floor consoles cost 120$ .... on sale at 79$ closeout.
p.ss. it has good oil pressure, the key was just on for a second to get picture.
eat,work,spend,sleep,repeat.
prairewolf is offline
Old 09-04-2011, 11:06 AM   #2745
wilbilt
wilbilt's Avatar
My nephew killed his Ford Ranger several years ago with a 30.06. Why the rifle was loaded in the cab, I don't know, but the round went through the floor, took out a transmission line, hit the frame and fragments went through an A/C hose, the radiator and the A/C condenser. It was an expensive day for him.
wilbilt is offline
Old 09-04-2011, 01:55 PM   #2746
jeff's 72 4x4 K20
Well, I haven't accomplished much today, last week I did get about 90% of the entire underside of the ole '72 coated with POR-15, one header installed and working on the other between the rain bands from Tropical Storm Lee, I am also working on relocating the clutch tube with the linkage due to header tube interference.
jeff's 72 4x4 K20 is offline
Old 09-04-2011, 07:23 PM   #2747
ItsRandy
ItsRandy's Avatar
Bought paint (on Friday), a close friend came over on Saturday and we block sanded my cab before the last coat of primer (only close friends will come over and help block sand). We only found a few spots that needed spot putty, we filled those and I am heading out into the garage to finish those in a few minutes. Tomorrow morning (before it gets hot) I am spraying the final coat of primer and hopefully, next weekend I will be spraying color on my cab. I have been sanding/filling/sanding/priming/block sanding/filling/priming/ block sanding etc., etc., and so on and so on for about about 8 weeks. I hope to show you all the results of all of my (and my close friend's) labor very soon.
ItsRandy is offline
Old 09-04-2011, 09:51 PM   #2748
Danny Bost
Danny Bost's Avatar
Today (and yesterday) I removed the burned out cab and front end from my truck. I then removed the good donor cab and front end and got the cab mounted on my frame. Not a great amount, but it is a start at last. There are more pics on my build thread, Project Phoenix.
Danny
71 SWB
Danny Bost is offline
Old 09-04-2011, 10:42 PM   #2749
Mayo
Cool Truck
Mayo's Avatar
I put on a lighter set of tinted turn signal lenses. I made my other ones a little too dark.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline
Old 09-04-2011, 11:41 PM   #2750
ryanroo
ryanroo's Avatar
dragged it across colorado and finally unloaded in my garage.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline
Closed Thread
