09-05-2011, 12:03 AM | #2751 |
Re: What did you do to your truck today!
20 x 8.5, come in polished, black, or as shown gray and polished lip. IIRC backspacing on the 8.5s is 5.25. Direct bolt on, not hub clearance or dust cap clearance issues. I bought them off eBay from Ron's wheels and they were shipped straight from showwheels. There are a few small imperfections in them , but you have to be examining them to find them. I didn't pay Coy prices and didn't expect a flawless wheel.
I'd buy them again in a heartbeat. I'll be putting 10" wide ones with 295 tires on the back. showwheelsusa.com I found them when another member posted (red 67 c10 out in California, with a really nice build, I forget his handle), posted a thread with them.
www.tomthetruck.blogspot.com <-- Aka build thread. |
09-05-2011, 12:01 PM | #2752 |
Yesterday I started taking my doors apart to replace the inner bottoms and outer door skins. Sorry forgot to take pictures.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
09-05-2011, 03:05 PM | #2753 |
Got mine into it's permanent primer paint job Came out pretty good for "paint it in the driveway" paint job. Wheels, tires, and a lot more soon to come!
ImageShack.us |
09-06-2011, 08:45 PM | #2754 |
Ordered a MileMarker winch today... And, I should get a visit from the UPS fairy with some stuff from LMC tomorrow.
Its still 104 outside. I was hoping to get a little bit more done today, but doesn't look like thats going to happen. |
09-06-2011, 08:49 PM | #2755 |
FINALLY, I got the paint work done all but the hood.
A USED TRUCK IS A LOVED TRUCK! |
09-06-2011, 08:51 PM | #2756 | |
67 5.3L Build |
09-06-2011, 10:00 PM | #2757 |
I went and bought new wide trim rings for my 8" ralleys and put them on my wheels .It will be a while before the truck is home from the body shop for me to put the wheels on the truck .I cant wait to get the van rallys off and get the 8" rallys on as that will mean new paint on the truck.
09-06-2011, 10:04 PM | #2758 |
I've got a lot done in the last two days! Many things have been checked off the list. I had to scar my rattle can paint job to do it but thats what the paint job was for. Click on the link!!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
09-06-2011, 10:05 PM | #2759 |
Junior Member
Monday we started doing sheet metal work on my '67 swb stepper cab. I have never done any sheet metal work myself so my son was showing me how to do it. We removed the inner and outer rockers using hammers and screw drivers, not a fun way I don't think.
I cut off the old cab corners and cut and fitted the new ones, my son tack welded them. Also he cut, fitted and tacked the driver's side floor pan. We removed the '73 454 from my '71 along with the SM-465 to prep them to put in the '67. I helped one of my grandsons take apart the front clip off the '71 I gave him. Today I ordered the seals and gaskets for the SM-465 from Rock Auto. It felt good to finally start working on the '67 and since I gave the '71 to one of my grandsons I will be able to concentrate on the '67.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-07-2011, 12:16 AM | #2760 |
Started block sanding the last coat of primer on my cab. I've sprayed 2 gallons of primer on the cab and swept up at least one gallon from my garage floor. sealer and paint are next!
09-07-2011, 01:05 AM | #2761 | |
09-07-2011, 02:05 AM | #2762 |
Sheetmetal Psycho
Filled it with wood from Lowes. Store is a few blocks away and I managed to drive alot further
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
09-07-2011, 10:53 PM | #2763 |
RAT1968 '68 Cab/'71 Parts
Picked up my Electric Window stuff from ECE today.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
09-08-2011, 05:32 PM | #2764 |
Old member
I ordered this kit today from "No Limit" a vendor here!
09-08-2011, 07:52 PM | #2765 |
PROJECT 7DEUCE
I installed a chevy only sticker on my back window today does that count as anything???
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-08-2011, 09:00 PM | #2766 |
Keep your head out of them window openings when rolling them up Magwakeener. They're pretty quick. Jim
09-08-2011, 09:16 PM | #2767 |
Will do, Eagle.
Unless I'm ready to end it all.
09-08-2011, 09:35 PM | #2768 | ||
'69 Chevy SWB
Looks someone was mighty thirsty before they started the paint process.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
09-08-2011, 11:06 PM | #2769 |
Finished prepping and got the first coat of Por-15 Chevy engine orange enamel on my small block. Top end goes on Saturday, if I can get a second coat on tomorrow night. I'll be picking up my March Track Serpentine kit saturday afternoon too!
09-09-2011, 07:19 AM | #2770 | |
I broke down and ordered a few parts, proportioning valve and..... a Plasma Cutter from Eastwood. |
09-11-2011, 02:37 AM | #2771 |
Finished sanding the last coat of primer on my cab today. Built a paint booth in my garage with hi-tech 3-fan power ventilation. Paint tomorrow, I'm jazzed>
09-11-2011, 01:39 PM | #2772 |
laying low
Andy this is the first I've seen of this. That looks like a much more effective shock angle than the other upper shock relocators give on lowered trucks.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
09-11-2011, 02:03 PM | #2773 | |
Old member
http://67-72chevytrucks.com/vboard/s...d.php?t=477839
09-11-2011, 02:25 PM | #2774 |
laying low
I know you will feel the difference in ride too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 09-11-2011 at 02:38 PM. |
09-11-2011, 03:10 PM | #2775 |
Old member
Man I sure hope so! It has to be better than now.
Here is another addition I did. New radio installed. Has HD stations, CD,SD and USB and Aux all. I have over 400 songs so far between the SD & USB. Best thing it was less than $90.00 shipped for free.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 09-11-2011 at 05:22 PM. |
