02-25-2017, 09:34 PM | #2801 |
Re: PO has me PO'd
Not quite, decided to get a set off of Wes, sometimes you just have to bite the bullet, and say "Honey, I need another set of fenders", and she'll say "you just bought that set" and I'll say" you know that new kitchen I just put in, and the leather sofa and new dining room set, we just bought"....
well we'll see where this goes, probably not well for me
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-25-2017, 09:54 PM | #2802 |
Re: PO has me PO'd
seems like we all have had that conversation at some point .....if the fenders are as good as they look in the pics this is no coincidence that they are 15 minutes up the road and priced right... grab the core support too ... your 67-68 stuff is worth more than what your paying for the 69-72 stuff if i didn't have another 68 nose in stock id make you whole ...heck your grill is worth at least 150. ill shut up now, I gave more than my 2 cents good luck on negotiations
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-04-2017, 07:18 PM | #2803 |
Re: PO has me PO'd
Picked up my cowl panel from the paint shop
[url=https://flic.kr/p/SsuiSx]20170304_111242 working on the top bar off of a GMC, might work yet, without buying fenders. Having a problem with my hood to cowl seal, mine is formed with a 90 degree bend and pushes up on the hood, seems like I need a seal that is formed with a 60 degree bend, after market is not always what they are cracked up to be, search continues [url=https://flic.kr/p/SpENEa]20170302_124457
03-05-2017, 12:16 PM | #2804 |
Re: PO has me PO'd
03-05-2017, 06:52 PM | #2805 |
Re: PO has me PO'd
My seal was like that also, but the hood actually will push the seal over because the hood comes down at a rearward angle. I would fit the hood then install the seal.
03-05-2017, 07:33 PM | #2806 |
Re: PO has me PO'd
thanks for the advise, will give it a go....
03-14-2017, 07:50 AM | #2807 |
Re: PO has me PO'd
This might work, yet! need to adjust eyebrow trim, and get mounting clips, and modify my 68 grill
[url=https://flic.kr/p/RE5yaY]20170314_071255
03-14-2017, 02:49 PM | #2808 |
Re: PO has me PO'd
also got the black pc 8" shifter from lokar, just have to trim cable
[url=https://flic.kr/p/ST6MPf]20170314_092056
03-16-2017, 02:35 PM | #2809 |
Re: PO has me PO'd
03-18-2017, 12:40 PM | #2810 |
Re: PO has me PO'd
03-18-2017, 01:15 PM | #2811 |
Re: PO has me PO'd
03-18-2017, 07:16 PM | #2812 |
Re: PO has me PO'd
thanks Jess for checking in, now I have to fool with my dreaded headlight buckets hate it always struggle and they don't come out right. Maybe I should read the FAM
found a great place in our area to do soda blasting, the grille was done by them.found a really cool site, while buying my hood adjustment bolts company name is Au-ve-co products. They have all kind of new OEM parts for our trucks. Saw rubber plugs for the glove box and ash tray
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-18-2017 at 07:21 PM. |
03-19-2017, 10:18 AM | #2813 | |
Re: PO has me PO'd
I'd like to come buy when the weather gets better catch up with you and your progress since my last visit....check out the soda blaster and parts house Jess Ps looking at another 72 ......local in barn 20 years ........shhhh
03-19-2017, 07:07 PM | #2814 |
Re: PO has me PO'd
Jess any day is good except Sundays, Jer comes home and we like to spend the day with him. Good luck on the new truck
03-22-2017, 11:02 AM | #2815 |
Re: PO has me PO'd
Just waiting on Wes to send new eyebrow molding to see how I have to modify clips
[url=https://flic.kr/p/RTFaBy]20170322_105103
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-22-2017 at 07:10 PM. |
03-24-2017, 07:21 PM | #2816 |
Re: PO has me PO'd
[url=https://flic.kr/p/SDpZ3j]20170324_112729
finally figured out how to mount my stone guards, and put the fender side trim on
03-27-2017, 11:29 AM | #2817 |
Re: PO has me PO'd
03-28-2017, 09:13 AM | #2818 |
Re: PO has me PO'd
Was talking to LKS DCVN the other day and he was asking about my stone guards on my Halogen lights, so I found out that they fit inside mounting rings with a little mod., had to cut two wires that were interfering with the glass protrusions on the sealed beam. Just used my small dremel with a cutoff wheel, you can see it at the third horizontal row. The third one sits directly on a space in the mesh
they sit tight with about 1/4" space to the head light [url=https://flic.kr/p/S5ygQH]20170327_112131
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-28-2017 at 09:18 AM. |
03-28-2017, 03:34 PM | #2819 |
Re: PO has me PO'd
[url=https://flic.kr/p/Tmu9Pz]20170328_152657[
gonna try and solder this up myself, can't be to hard...flux, solder, and heat. Right?
03-30-2017, 08:03 PM | #2820 |
Re: PO has me PO'd
[url=https://flic.kr/p/Sbbv8c]20170330_195645
what a PITA, I hope I never have to install another GMC eyebrow for the rest of my life. Clips were impossible At least the tank was easy, couple hours [url=https://flic.kr/p/SbbBXz]
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-30-2017 at 08:09 PM. |
03-30-2017, 09:50 PM | #2821 |
Re: PO has me PO'd
looks great Jim, patience is a virtue....skill is learned, you have both
03-30-2017, 11:36 PM | #2822 | |
Re: PO has me PO'd
so, the front is finished, once I get the hinges bolted up
04-03-2017, 04:14 PM | #2823 |
Re: PO has me PO'd
04-03-2017, 04:15 PM | #2824 |
Re: PO has me PO'd
04-14-2017, 01:14 PM | #2825 |
Re: PO has me PO'd
That front clip looks good, I like the rock guards as well...one of those things that might not get noticed by many folks but really sets the front end apart.
