Old 03-03-2016, 10:17 PM   #2801
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
that's when he drew blood!!!
FINALLY!!! thought it would never happen, ha ha
Gregski is offline   Reply With Quote
Old 03-03-2016, 10:18 PM   #2802
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then we ran home to cry to mama
Old 03-03-2016, 11:45 PM   #2803
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
I can't tell you how many times I have drawn blood and not had a clue as to how it happened. Just working away and then all the sudden stuff starts turning red and your like, wtf?! Did I cut myself somehow? When? On what?
The flip side is there have been a great many times where I busted a knuckle or something and instantly thought, wonder how much blood is going to pour out of this one!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-03-2016, 11:46 PM   #2804
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by y5mgisi View Post
i can't tell you how many times i have drawn blood and not had a clue as to how it happened. Just working away and then all the sudden stuff starts turning red and your like, wtf?! Did i cut myself somehow? When? On what?
The flip side is there have been a great many times where i busted a knuckle or something and instantly thought, wonder how much blood is going to pour out of this one!
true!
Old 03-04-2016, 01:34 AM   #2805
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
I remember working on the exhaust under a G20 van years ago. I began wondering how and why the transmission was leaking down my shirtsleeve to my elbow when I wasn't under the darn thing.
The answer? It was me leaking red stuff from a pretty nasty gash in my arm that didn't bleed immediately when I bashed it on something sharp . It wasn't Dexron II.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-05-2016, 01:59 AM   #2806
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Day Three of Engine Removal
picked up this Two Ton Load Leveler from Harbor Freight (aka the Cheap Chinese Tool Store) for about $45 bones, its a step above their 3/4 ton yellow one, fingered I am pulling the engine with the boat anchor SM465 Muncie, might as well get this one
man, the Harbor Freightians sure have a sense of humor, they give you the [single use] plastic red handle with a grade 3 bolt for this TWO TON jack, LOL, needless to say we mucked up the threads on that piece of junk on first use, other than the handle, the leveler held up, and no one Got Dead!
Old 03-05-2016, 02:05 AM   #2807
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
after disconnecting the drive shaft and the transmission from the cross member, we put the engine hoist and the new leveler to good use
we left the starter on and the oil filter, and maybe if we was to do it again we would have removed these two aparatie to prevent them from catching on the engine mounts
Old 03-05-2016, 02:06 AM   #2808
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and we have Lift Off
Old 03-05-2016, 02:09 AM   #2809
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
down boy, good boy!
Old 03-05-2016, 02:10 AM   #2810
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and this Divorce is Final
Old 03-05-2016, 02:14 AM   #2811
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
always wanted to git an engine up on this type of engine stand like they do on all them TV shows and tear it down
Old 03-05-2016, 03:09 AM   #2812
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then it was time to commence with The Tear Down ceremonies
first the valve covers and the intake manifold came off, this revealed a decent leak proof set of beads on the Great Wall of China, both in the front and the rear of the block, nice
Old 03-05-2016, 03:11 AM   #2813
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Off with his head!
Old 03-05-2016, 03:13 AM   #2814
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the lifter extraction proved to be a challenge - had to resort to vice grips and liberal use of PB Blaster to [ahem] persuade them out - fortunately we is replacing them with brand new ones
Old 03-05-2016, 03:16 AM   #2815
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the crank pulley came off next, which allowed us to pull off the harmonic balancer
Old 03-05-2016, 03:19 AM   #2816
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the timing cover was do to come off next, in hind sight, might be more better to remove the oil pan first as the bottom of the timing set cover has a lip that protrudes and overlaps the oil pan, oh well
Old 03-05-2016, 03:22 AM   #2817
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
that revealed the timing set, and the chain which had way too much stretchability
Old 03-05-2016, 03:24 AM   #2818
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then I pulled out the camshaft, make sure you remove the fuel pump rod to allow it to slide out
Old 03-05-2016, 03:26 AM   #2819
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
pulled the crank gear next
Old 03-05-2016, 03:27 AM   #2820
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
removed the water/coolant plugs out of the block on each side, and nothing came out, had to poke in there with a small flat screw driver to get a decent waterfall
Old 03-05-2016, 03:30 AM   #2821
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
dropped the oil pan, removed the oil filter and the starter and decided to call it a night
The Russian Judge rated the Fun Level at 9 for the evening, sighting that it was exhilarating yet messy
Old 03-05-2016, 08:07 AM   #2822
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
I know you mentioned you were doing a top end job, Do you plan to tear it down further?
May need cam bearings and I would look at the crank bearings.
Jake Wade is offline   Reply With Quote
Old 03-05-2016, 10:41 AM   #2823
enaberif
Re: Restoring Rusty
someone has done a timing chain change on that motor. gm used nylon coated upper gears for many years which ended up cracking.
my original chain was way more stretched than yours.
enaberif is offline   Reply With Quote
Old 03-05-2016, 11:21 AM   #2824
y5mgisi
y5mgisi's Avatar
Re: Restoring Rusty
Fun! Only a level 9?! Lol that's a good feeling!
Old 03-05-2016, 11:53 AM   #2825
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
No, I already went further than planned by removing the bell housing, clutch, and fly wheel
I am just going to pretend all that is just good, ha ha
