#2901 |
![]() Join Date: Mar 2021
Re: What did you do to your truck today.The 3rd chapter
Agreed Mike, I'm on this forum everyday looking for info .......
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
#2902 |
![]() ![]() Join Date: Jan 2005
The 15x8 rally wheels I had on the front of my truck were rubbing on the fender openings when I'd hit a dip in the road. Lolife recommended Stockton Wheel to have them reduced to 15x7, so that's what I did. They cut the centers out of a set of 15x8s and welded new USA-made hoops on them. Took them one week. Finally installed them today.
#2903 |
Installed the 99 Tahoe seats after replacing the leather with something in black. Still need to smooth the leather, but love the look.
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
#2904 | |
![]() Join Date: Nov 2018
#2905 | |
I was out at the C10 Nats a couple of weeks ago and I was showing people your dummy gas cap neck that I have on my 72 C20 and everyone liked it. Hopefully it will get you some sells on them. Keep up the good work!! |
#2906 | |
#2907 | |
![]() Join Date: Mar 2013
#2908 |
I went with 3-7/8", which is the same as the 15x8 6-lug rally rims. I did that because I knew they would clear my lower control arms without trimming them.
#2909 |
Started the stake side for the 68 anniversary truck . Some of the slab leftovers I usually cut up for firewood . These are hickory I’m going to just but a slab on each side . Also will have to bow tie some of the end cracks before I finish sand them this week all I did today was send them through the planer.
#2910 |
![]() Join Date: Oct 2016
I've got a few different projects going on with my truck at the moment. Replacing inner/outer rockers is one of them. I noticed the cab wasn't lining up with the bed at all a few days ago. DS was ~1 low, PS was fine. I was worried something moved while I had the cab cut up. A few days later I went out and measured the body mounts on both sides, they were identical (~2" for the rears). As I was scratching my head I walked around the truck and noticed the PS was now ~1" low as well.
New body mounts fixed it right up but I'm still a little puzzled why both of the rear cab mounts collapsed ~1" while sitting in my garage after 54 years of driving around. Seems unlikely, but I looked at some recent photos, and they seem to confirm I'm not losing my mind. It was sitting just fine a few weeks ago. In other news, I finally got catainfab's booster mount and PS frame adapter installed. Both of those items were $ well spent and I'm sure saved me a lot of work & head-scratching.
__________________ '68 K10 496/465/205 |
#2911 |
![]() Join Date: Feb 2009
Finished installing the body, moldings and inner fenders. She's close to done, but no sign of windows yet.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#2912 |
Test fit the new bed, ready to remove/disassemble and paint.
1972 C10 Step Side short bed |
#2913 |
![]() Join Date: Oct 2013
#2914 |
![]() Join Date: Jan 2016
#2915 |
More of a polished but yes they do.
#2916 |
Yes its all Keyparts with a Mar-K white oak wood floor. Went together okay but you have to assemble and put it on the truck before any paint, I had to re drill a few holes and I still need to elongate a few after I take it apart. Not bad but I would have been upset if I would have painted everything first.
#2917 |
#2918 |
I just them off ebay, search New Clear Lens Deluxe Side Marker Light Set W/ Trim For 68-72 Chevrolet C10.
It was like $30 for two
#2919 |
I'm not really getting off to a fantastic start with my brake lines. I spent about 4hrs making the two short lines that connect the master to the prop valve. And yes, I did forget to put the fitting on once, and then put the wrong size on the next try. Decided it was time to cool off and try again another day.
#2920 | |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
#2921 |
We've all done it BASE, no shame in that
#2922 |
I fabbed up some 3point seatbelt mounts that just clears the gas tank and tucks the ratchet mechanisms snug in behind the bench seat.
Posted via Mobile Device |
#2923 |
Blue 67
![]() Join Date: Apr 2004
I finally swapped my C20 heavy duty spring to just 1/2 ton coils and replaced the shocks in hope of a little softer ride.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
#2924 | |
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
Don't ask me how he did it. But he did. He got in a lot of trouble for that one. And of course we all made fun of him.
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
#2925 |
Worked on the stakeside boards this is why projects take me so long I get carried away . I could have epoxy glued the cracks but no not me . Ended up doing bow ties out of black walnut . Two coats of spar urethane so far .
