06-18-2022, 08:28 PM | #2951 |
Re: What did you do to your truck today.The 3rd chapter
Installing NOS door handles with the gaskets got from Seth and restored vent windows from Rodger. I don't remember who I got the handles from, sorry!
06-18-2022, 09:48 PM | #2952 |
fit tested last night dropped off for paint this morning .....used the 55 grocery getter to transport
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
06-18-2022, 11:11 PM | #2953 |
I've gotten some time off untill I start my new job so I started putting the disc
brakes and power steering set up on my '69.
Ain't no way in the world I'm going out that front door. 69 SWB Fleetside 327/5spd 76 blazer 383/700R4 95 2Dr Tahoe 5.7 4x4 LT |
06-19-2022, 09:39 AM | #2954 |
Nice! I converted my 69 as well
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
06-19-2022, 11:30 AM | #2955 |
Who Changed This?
Went to a meetup in a nearby town and met 72sb in person. That is one really nice little pickup he has! Wandered around looking at vehicles. About 70 years worth were represented. Everything from Model T Fords to '80s Corvettes. What I have yet to do today is go and trouble shoot the truck. It started running lumpy on the way home from the meetup.
06-20-2022, 05:49 PM | #2956 |
Dropped mine off at the shop for an alignment at 8:30, picked it up at 11:00. Drove it literally about three blocks and dropped it at the glass shop for a windshield. Hope to get a call tomorrow or Wednesday to come pick it up again.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-20-2022, 07:47 PM | #2957 |
Who Changed This?
Checked the truck out, yesterday. As I suspected, it's loading up a little. Gonna get a carb kit. Looking for a plating kit, while I'm at it. Gonna make it look close to new, I hope.
06-22-2022, 07:09 PM | #2958 |
Who Changed This?
Rebuilt the carb. $280 for a plating kit, that ain't happening. I have a couple of adjustments to make, but they're going to wait until tomorrow. I can't take the heat under the hood when it's already in the '90s. At least the flooding condition is fixed.
06-22-2022, 09:58 PM | #2959 |
I drove it until my back hurt, then had to drive it back.
06-25-2022, 09:20 PM | #2960 |
Got the b&m transmission cooler mounted & plumbed
06-26-2022, 01:15 PM | #2961 |
Cleaned up and painted some of the little screws for the heater box and found a couple other things to get done up.
06-26-2022, 08:27 PM | #2962 |
Took 72 to Friends shop to start teardown of motor
1979 350/4 bolt main, bought it with 80,000 on it, lol put another 7500 on it in 3 years going with Edelbrock Performer manifold to match the Edelbrock Carburetor had a set of 202 heads machined and ready to go taking the block to Same Machine shop in a couple days 30 over , probably going with rv cam, new oil pump and water pump while motor is out, clean up frame and engine bay a little more this is a before picture of engine bay
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
06-26-2022, 09:06 PM | #2963 |
Who Changed This?
Fixed the wiring on my kickdown switch. I rebuilt the carburetor earlier in the week and then the kickdown didn't work. There was quite the mousterpiece of a wiring job from a previous "mechanic". Looking good, now. I'll reinstall everything in the morning. I don't work well in the heat anymore.
06-26-2022, 09:06 PM | #2964 |
Laid out my new aaw wiring harness to kind of get an idea of what's involved. Then I cut up my old harness and used the old plugs to hook up my windshield wiper motor to the battery to make sure it works, then I put the arms on. Now I'm working on getting the windshield washer pump working. Then I can put the cowl back on for the last time (hopefully). I don't want to have to go under that dash to change out the wiper motor or the washer pump later
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
06-27-2022, 04:20 PM | #2965 |
Well, the alignment shop went great but the glass shop not so much. When my old windshield came out I got some rust repair to do before a new windshield can go in. Got the truck hauled home and started cutting the bad out on the lower driver's side over the weekend and cleaning up the pinch weld all the way around. Going to take advantage of the cooler weather and work on it in the evenings this week.
06-27-2022, 05:42 PM | #2966 | |
06-27-2022, 07:09 PM | #2967 |
70+ ( Old Skool Club )
Started 3 years ago buying the a used uncut block and crank and now gettng close to finish. Today 2 coats primer, 2 coats Chevy orange and 2 coats clear.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-27-2022, 08:50 PM | #2968 |
Test fitting the Champion CC369 radiator .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-27-2022, 09:08 PM | #2969 |
Hopefully fixed the real slow leak in my ac . Last year I retrofitted it to r134 worked great but when I used it the other day it wasn’t as cold as it should have been . Did the uv and it lit up around the hose end Had to replace a clamp on the low side hose . Pulled a vacuum and it held so I juiced it up and it’s crispy cold
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 06-27-2022 at 09:19 PM. |
06-28-2022, 01:11 PM | #2970 |
Well.......I finally got some things done in the engine compartment. Replaced the heater core, changed out the alternator, power steering pump, water pump both wire harnessess, flushed out radiator, painted up some pieces.
06-29-2022, 12:53 PM | #2971 |
Still touching up some little things. Filled the antenna hole, swapped rear tires with fronts. Long story, fronts were 75s backs 70s. A friend saw that and called me out on it. Logged my 150th mile since the build. I'm happy with it so far.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
06-29-2022, 03:55 PM | #2972 |
Hope you have many more happy miles with it. Lookin good
07-06-2022, 09:43 PM | #2973 |
Who Changed This?
Pulled the seat out. I have foam and the covers to redo the upholstery. I'd better start taking pictures. There are some wires in the corners that I'll need to remember later where they go, and the old memory ain't what it used to be.
07-09-2022, 03:24 PM | #2974 |
Got the strips painted for my wood bed today
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
07-10-2022, 04:48 PM | #2975 |
Installed my bumper. (finally)
