#276 |
I have 3 1 tons now.67 (in progress) 81 wrecker,and my homemade 1ton 4x4
On the 67 frame.does someone need the dually rear,front susp.cradle complete,this is a 67 GMC chassis. the rear is a 4.56 and is the narrow type,no wider than the cab.the wheels are 18" ones,split orignal GMC wheels,they can go with the rear/front too. Let me know. I am running a late model dana 70 4.10 gears and 87 dually front susp. This 67 has the aux 3 speed trans ,behind the granny 4 spd. Very cool.Twin stick setup.. Last edited by bisquik65; 04-02-2005 at 12:31 PM. |
#277 |
I have a radical idea!
Erick,
Do you have any pics of that twin stick set-up. Are the 3 additional speeds lower or higher gears?? Does this offer a OD for the highway? Thanks! BTW, was you still needing that Monza stuff, I never got a call.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#278 |
Currently Blazerless
Here's a couple pics of my 1 tons.
1969 Custom/30, 383, th350 & np205, dana 60 front with 4.56 gears and Trac-Loc, 14 bolt rear with Detroit locker [ axles from 5/4 ton M1008: Tactical Cargo ], 9.00 x 16 directional super traction tires. 1970 GMC 3500, 292 6cyl, 4 speed and 4.10 rear, 157" wb.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#279 |
Blazerman, Great trucks. That '70 is a very nice truck. How does that 292 run/pull with those 4.10's?? My '67 has the 292/SM-420/5.14's and seems like you are driving a tractor rather than a truck!!
#280 |
7GMC2,that green flatbed in post#252 was for sale about 5mi.from my place last year.I checked it out.Nice truck,think it had buddy seat.
#281 | |
#282 |
bisquik65
I would like to see some Pics also. I think I have one of these Aux 3 speeds, kicking around in my shop. I would like to try and use it, but I don't have any specs, model No., RPO, etc. or how it mounts. I will take some pics of mine. The only info that come close that I have found is a Spicer 5831-B. Any help would be Greatly Appreciated.
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ Last edited by Truckstuff; 04-03-2005 at 11:25 AM. |
#283 |
Here are the Pics.
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ |
#284 |
i got pics sive me a few minutes.
#285 |
Here they are,the tag says watson transmission,mfd by spicer.model 43
#286 |
#287 |
No not on this one,thats part of the case...This truck was biult by Glendale truck and equipment co in calif. It had an alumn box on it,Like a moving truck..
#288 |
![]() Last edited by 7gmc2; 04-03-2005 at 05:38 PM. |
#289 |
new pic of my 76 1 ton
1968 C20 292/sm465 1990 C3500 dually 454/th400 1991 sonoma 4.3/700r4 1994 K1500 burb 350/4L60e 1954 belair, 1991 corvette, 1972 chevelle, 1995 LS swapped impala SS |
#290 |
67_C-30, I have not drove it myself yet, my son took it to try and get it inspected but just drove it a few blocks. This truck had 5.14s but joe swapped in the 4.10s, it should make it a little easier to drive on tha highway. My old Stude 1-1/2 ton was geared in the 7s , that was fun to drive.
7gmc2, not real sure what I'll do with it, I had thought about a 4x4 conversion. As for the bed I was going to build a steel bed for it but steel prices right now are really up there. My neighbor is checking into some aluminum, he built one for his 1 ton and it came out really nice.
#291 |
Here is my 1985 Chevy Truck-M1008
#292 |
keller
hears my 83 I just got
83 1ton 4door dually, 350/700r4 99 S10 2.2/5speed bagged. traded for the dually 91 S10, 2.5/5speed juiced 87 3/4 4x4, 350/4speed 89 S10 long bed , 2.8/5speed 65 chevy short bed stepside, 327/3speed 97 neon acr, 2.0 dohc 5speed DD Last edited by KdawgS10; 04-04-2005 at 02:41 AM. |
#293 | |
72 C30 Trailer Queen
http://www.6066gmctrucks.org/spicer-5831-b.htm I was going to use one of the spicer boxes in the 72 C30 in my avatar, but ended up finding a Doug Nash overdrive unit for a TH400. It bolts on the trans in place of the tailshaft, and is electrically shifted in and out of overdrive. Its overdrive ratio of .80 will turn my 4.10 rear into 3.28 which should make for nice highway cruising with the 402 big block. Last edited by Chris H; 04-04-2005 at 09:43 AM. |
#294 |
Here are some pics of the truck with all the trim rings and center caps.
Bisquik , Chris H & Truckstuff, Thanks for all the info on the Aux transmissions. That is a very cool set up! I know where a salvage yard that has a lot of Med duty trucks. I am going to try to find one. Blazerman, those 4.11's should be a lot more highway friendly than these 5.14's!! My '67 C-50 has a 2 speed rearend, and in low range, I think it is is the 7's or 8's. We're talking 2-3 mph, wound out, in 1st gear!!
#295 |
Those rims look real good, if you see another set on ebay let me know, I have had no luck looking around locally.
#296 |
I found these on Ebay. The straing bid is $50 + $15 S/H. They are the only GMC ones I've seen. They end in 13 hours, so you may want to check them out pretty quick. I sent you a PM also.
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 04-05-2005 at 11:01 PM. |
#297 |
Pics of the fleet
Here a few pics I snapped today of my fleet. The pics are of my '67 C-30, 67 C-50, and 69 C-30. I have a '70 C-10, and a 70 GMC C1500, but these are the ones I am using, fixing up, and keeping. I hope I can get the body work done on the '67 within the next few months, and hopefully I can get the 2 67's painted at the same time. I want a very good paint job for the '67 C-30, but I could handle just a decent paint job for the C-50. With some of the places I have to get in to get cars, I would scratch up the paint on it in no time anyway.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 04-06-2005 at 10:34 PM. |
#298 |
I spotted this in the local trader.
http://www.auto-rv.com/ 1969 CHEVY C3500. 350 ci, manual trans., awesome red finish, 38,000 orig. mi., custom flatbed, gooseneck and Reese hitch, show ready, already won truck load trophies. $14,500 OBO. Battle Ground, IN. (765) 564-3027 CI3010278
68 K-10,79 K-10,80 C-30 57 chevy convertible 79 Z28 Last edited by 687980chevy; 04-09-2005 at 01:25 AM. |
#299 |
Seeing as though mine is done yet I will have to post a pic of our old dodge work horse, this truck is amazing for pulling. Its got about 450,000 km on a 5.9l cummins. It even pulled the load in the second picture like the trailer was empty.
#300 |
67_C-30, Thats a tough looking fleet you have, do you run a salvage yard, tow service? or just use them for yourself?
