Old 03-18-2007, 10:33 PM   #276
Rokcrln
Rokcrln's Avatar
Re: LFD's low buck truck build!
Next I cut off the exhaust (welded on unit ), removed the 2 piece drive shaft, pluged the fuel lines and made sure everything was out of the way so I can cut the frame after work Monday. I removed the rear end as well so I can do the flip kit while the truck is down. I have decided to go with the ECE frame chanels and cut the frame at 45* angles instead of the step notch that I mentioned before. The main reason for this is because their is not alot of room to work under the cab and I can do a more accurate job this way. Plus I need new body mounts anyways so I will order it all at once.
I need to check with the drive shaft shop as to weather I will go with a 2 piece or a 1 piece. I would rather go with a 1 piece but it all depends on what kind of shape my 2 piece is in because it will be alot cheaper to just shorten what I have now. But if the joints are bad or any other peroblem than a 1 piece may come into range.
$5 for easy off, $5 in quarters for the wash and 4hrs work.
Kevin
LFD Inc.
$1127.64
66hrs
Rokcrln is offline   Reply With Quote
Old 03-18-2007, 10:40 PM   #277
72CSTC5
72CSTC5's Avatar
Go Go Go Go!!!!!!!! Chop Chop Chop!!!!!!!!!!!!!!
72CSTC5 is offline   Reply With Quote
Old 03-19-2007, 12:41 AM   #278
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
awesome thread....quick question, is there any special reason to bolt the rear cab mounts back in as opposed to just welding them back on?
milehightoyz is offline   Reply With Quote
Old 03-19-2007, 07:10 AM   #279
Rokcrln
Rokcrln's Avatar
Good question but I don't have a good answer other then it is just real easy to transfer 4 holes back 12" and bolt it up. Also with the leverage placed on these mounts you would need to do a fare amount of welding to make sure they stay were you wanted them as opposed o a few grade 8 bolts
Kevin
LFD Inc.
Old 03-19-2007, 04:33 PM   #280
skchevota
skchevota's Avatar
Originally Posted by Rokcrln View Post
No I am not. I have a line on a set of stock truck ralleys with rings and caps. I am running 8's in the rear and 7's up front.
I have never tried those colors before?
Sorry I like the more factory look with my own custom touches. Even my 71 SWB with the body drop, Z-step, LT1 and tilt front end. Once it is done it will look just like a 68 two tone with every piece of factory SS trim you can get. I used John's as inspiration. I have added the front fender and hood trim as well as al the tailgate trim to mine. I also had a set of vett ralleys built in 17's as well. Here is a pic of John's.
Kevin
LFD Inc.
Umm, Did you say tilt front end!!! Do you have any pictures. Is It all steel????
I neeeeeddddd more info....Please!
Shawn
skchevota is offline   Reply With Quote
Old 03-19-2007, 10:14 PM   #281
Rokcrln
Rokcrln's Avatar
Shawn
It is just a forward tilt hood. Check out "project slow build" and it will give all the info.
Kevin
LFD Inc.
Old 03-19-2007, 10:28 PM   #282
lytemup454
lytemup454's Avatar
pics of the frame chop please??????????????? lol
lytemup454 is offline   Reply With Quote
Old 03-19-2007, 10:33 PM   #283
Rokcrln
Rokcrln's Avatar
Well I am a big enough man to admit that yes I have a shorty! Acually I have a few
I layed out the frame and some control lines to adjust things by. The factory placed alot of layout holes along the frame and when used for measure points they work great. Their were two right along side the section to be removed so I used those. They are 20" apart and what I did was scribed a line right on the back edge of each one and double checked each one for the 20" dimention at the top and bottom.
Then I layed out the 45* cuts and stabilized the rear of the frame with some scrap steel and clamps.
Then I cut the frame section out and V'd the edges for the fillet weld's. Next I used two pieces of angle to clamp the frame back together and checked my 20" mark and it was now down to 8".
I made sure the frame bottom edge and side was flush and placed a tack weld on the outer corner to hold things in place.
Then I used the braces clamped to the rear of the frame to adjust things up or down (with my free Hammer) ever so slighty to get the 8" lines right at 8" top and bottom and then I tacked the top as well.
Now I will leave it like this untill I put new cab mounts in and place the bed on sor a test fit of everything.
In the next few days I will start on the rear flip kit, shock mounts and hidden hitch.
Kevin
LFD Inc.
$1127.64
68hrs
Old 03-19-2007, 10:35 PM   #284
Rokcrln
Rokcrln's Avatar
And a pic of shorty
Kevin
LFD Inc.
Old 03-19-2007, 10:45 PM   #285
lytemup454
lytemup454's Avatar
that was a little confusing but it looks sweet and once agin you make the rest of us feel stupid by dong all this work effortlessly. great job you a real motivator.
Old 03-19-2007, 11:41 PM   #286
72CSTC5
72CSTC5's Avatar
Looks good man. Easy fix for a long bed!!!!
Old 03-19-2007, 11:55 PM   #287
franky69c10
chevy runs deep
franky69c10's Avatar
x2
franky69c10 is offline   Reply With Quote
Old 03-20-2007, 02:00 AM   #288
watahyahknow
watahyahknow's Avatar
hmmmmmmmmmmmm the thought keeps popping intoo my head to chop mine too , but i doubt the guys from the roadaproval thingy will accept it
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-20-2007, 08:13 AM   #289
Ram-Man
Ram-Man's Avatar
I dont envy you having to work around the cab. It's hard enough to line it all back up when it's just a frame. Nice job!
Ram-Man is offline   Reply With Quote
Old 03-20-2007, 11:32 PM   #290
Rokcrln
Rokcrln's Avatar
Another 2 1/2 hours spent. I got the cab mounts on and the bed set into place and all lines up perfectly. So I then welded up the frame cut and had great penitration. The first two pics are of just my one out side weld and the penitration seen on the inside of the frame. I then welded up all sides and ground the out side weld about half way and I will leave it like this. I ground the inside ones flush then put a 3/16" fish plate on the inside of the frame.
I hope to start the flip kit on Wensday and I picked up a 84 blazer gas tank today for the rear of the truck. It is 25gal and will accept eather a carb or efi pick up. I need to figure out my mounts and a new rear cross member.
The only down side is that it fills from the passenger side but for $100 I just could not pass it up. What do you think?
Kevin
LFD Inc.
$61 in welding supplies and hardware
$1188.64
70.5hrs
Old 03-20-2007, 11:34 PM   #291
Rokcrln
Rokcrln's Avatar
Last two. But I forgot to add that I plugged welded al holes that the fish plate covered. I first C-clamped the plates to the frame then plug welded it then moved to the inside.
Kevin
LFD Inc.
Old 03-20-2007, 11:42 PM   #292
texanidiot25
Eat My Rust
texanidiot25's Avatar
Ive missed so much of this build
Its come a long way since I last saw it, good work.
texanidiot25 is offline   Reply With Quote
Old 03-20-2007, 11:53 PM   #293
GREASEMONKEY72
GREASEMONKEY72's Avatar
it looks cool with the bed the gray and the cab brown 2 tone, just paint the yellow part of the fender brown and leave it
and cant you flip the tank around so you can fill from the drivers side? or mod it so you can
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 03-20-2007, 11:59 PM   #294
GREASEMONKEY72
oh and i love the wheels by the way
-steven
Alte Seele S.S.
Old 03-21-2007, 12:01 AM   #295
Rokcrln
Rokcrln's Avatar
Yes but the detents in the sending unit would have all the lines facing the rear and the anlged part of the tank would face forward and not out back were it would scrape the ground on big dips. I could mod the tank but that adds extra time and money to the build and that goes against what we are trying to do. Plus the passenger side fill would through people off a bit
Kevin
LFD Inc.
Old 03-21-2007, 12:07 AM   #296
Dano69c10
Dano69c10's Avatar
I think that bronze color is cool, I've never seen a truck that color in person.
How about white top, bronze above and below mouldings and white in between the upper and lower mouldings? Since it is a "low buck build" leave the penny color and two tone with white.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 03-21-2007, 12:14 AM   #297
Rokcrln
Rokcrln's Avatar
Dano
It is all in bad shape and yes it is a Low Buck but it is still going to be a cool looking truck just for alot less than most. I want to make it nice enough to get it in one of th emags and give a link to this build for more site traffic
Kevin
LFD Inc.
Old 03-21-2007, 12:38 AM   #298
72CSTC5
72CSTC5's Avatar
Looking good Kevin. Glad to see you always keep safety in mind when doing these jobs so when people copy you they are keeping their safety in mind as well. On a side note, Damn you are keeping cost down on that thing.
Old 03-21-2007, 01:19 AM   #299
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Excellent thread! Since I'm doing a leaf to coil conversion on my '68 GMC...I was kind of hoping you were goin to work that in there!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-21-2007, 01:32 AM   #300
franky69c10
chevy runs deep
looking good...........
