#276 | ||
69' Chevy Stepside
![]() Join Date: Mar 2008
Re: 1969 Chevy Stepside Restoration/Build up
![]() Quote:
Thanks guys! But there is one flaw in the SPID.... ![]()
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
#277 |
69' Chevy Stepside
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 11-29-2010 at 03:13 AM. |
#278 |
![]() Join Date: Aug 2010
Beautiful truck!!! I hope my swap turns out as well.
67 5.3L Build |
#279 |
Nice I have a lq9 in mine and am very interested in doing the head/ intake swap. Do you know how much power difference there was over your 5.3? Do you know your compression, deck heads or not, ptv clearance? I like your solution to the throttle cable. Very clean truck I can definatly appriciate the time and money put into it.
#280 | |
69' Chevy Stepside
#281 |
Truck and auto performance nut
wow.....sweet build! Love the motor!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#282 |
Still Learning
Your motor sounds great! Love the video!
#283 |
69' Chevy Stepside
Thanks!
![]() Thanks! ![]()
#284 |
great build! very nice
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... |
#285 |
69' Chevy Stepside
#286 |
69' Chevy Stepside
Installed the AEM Wideband O2 Sensor into the exhaust system today, bank 1 on the drivers side exhaust pipe after the header and before the Y pipe. I haven't decided if I want to permanently mount the gauge yet so it just sits in the cup-holder. The aux output of the gauge is feeding into the EGR Sensor position on the PCM so I can log it with HP Tuners. Should work great for dialing in the tune.
#287 |
So are you going to monitor only one side?
#288 |
69' Chevy Stepside
Yes typically from what I've heard Cylinder #7 (band 1, drivers side) is famously the leanest cylinder so that's why I'm only monitoring that side. It's not necessary to monitor both. The factory O2's do that.
#289 |
Sure, I was just curious as to why it would be there instead of in the y-pipe. In my situtation...I need to know what both sides are doing. I'd love to add FAST's (or was it Innovate?) newest 4 channel system.....allowing a/f readings on every cylinder (w/8-02 sensors) with just 2 boxes linked together... and I think maybe even set alarms for specific parimeters on each channel?
#290 |
sweet!!!
#291 |
69' Chevy Stepside
#292 |
sounds great, u have came a long way with this build & keep up the hard work. The truck has turn out really nice, keep on truckin''
#293 |
69' Chevy Stepside
Well I got bored tonight and I was icing to do something with my truck. Originally earlier in my build I used CPP 2" front drop springs, the problem with them is they didn't really seem to lower my truck at all what so ever it was the exact same height basically as stock. So I still had the stock spring so I cut a coil off of them, sand blasted and painted them and these where the results. (Note I need to take out some homemade rear spring spacers on my rear 3" drop springs)
![]() ![]() Original spring cut and installed. ![]() The CPP Springs sitting next to the cut off parts of the original front springs. ![]() BEFORE: ![]() AFTER: ![]() It's hard to see in the pictures but the truck is probably sitting about 3-4 inchs lower in the front, next I'm planning to add sway bars and drop out my lift blocks I added to the rear to level the truck with the too high front springs and the drop springs in the rear. Front Fender to ground, 30-30.25 inchs ![]() Rear Fender to ground, 32.25 inchs ![]() I'm very happy with the results, tomorrow I'll get the rear lowered back down and install the CPP adjustable trac bar I've been meaning to install for ever. ![]() ![]()
#294 |
Looks great!
Eric ![]() ![]() ![]() ![]() 1995 Ford F-250 4x4 Powerstroke, 342k "Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known." -Ronald Reagan |
#295 |
69' Chevy Stepside
#296 |
69' Chevy Stepside
I continued on with the lowering project late into the night last night! Pulled out the lift blocks I had made and dropped down the back end, wow what a difference in the way the truck looks, just amazing! I also managed to finally remove the seized in trac bar/panhard bar, the bolt where it connects to the frame was fuzzed to the bar so I had to cut the bolt out of there with a sawzall what a pain.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 01-13-2011 at 06:47 PM. |
#297 |
![]() Join Date: Jul 2010
Just finished reading your entire thread in one sitting. Man I'm inspired. I want to put a LS engine in my 69 but I know absolutely nothing about computer controlled engines or wire harnesses. Is it as complicated as it looks? Sharp truck bud!
#298 | |
69' Chevy Stepside
#299 |
69' Chevy Stepside
Well when I restored my truck I bought a 2/4 spring drop kit from CPP, anyways I'm not sure if since I have a aluminum headed LSX motor that its much lighter than a SBC 350 or what but the front of my truck with the 2 inch front drop springs sat way too high while the rear was nice and low. This was an issue so at the time I just jammed some lift blocks under the rear springs to bring it back up. I finally decided fixed it!!!
So I found my original front springs, and cut off a loop, sand blasted and painted them and removed the lift blocks in the rear, and installed the adjustable CPP panhard bar. This is a before shot: ![]() This is how it turned out after I cut the front springs and installed the rear CPP springs without the spacers: ![]() ![]() ![]() ![]() Keep in mind the front tires are smaller but from the top of the wheel well to the ground its 30.25 in the front and 30.75 in the rear. Some teaser engine pics, I absolutely can't wait for the month of May to come around so I can take the truck for a drive with the new motor! ![]() ![]() ![]() ![]()
#300 |
Lookin' great and I really like those GMPP LSX valve covers!
