Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-15-2014, 07:13 PM   #276
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: post latest 1/4 and 1/8 mile times and 60ft.
. Very nice 60 foot 330 is moving But the MPH should be in the 91-94 mph not 69. MPH is very low for that run.
Here is my truck run best to date. Have new stuff to try.. like both kits on line with a full bottle HA HA . and the new convertor.. That was not a great 60 footer street cars drving through the water box.
.020 reaction
1.69 60 foot
4.76 330
7.308 1/8 mile and 98.19 MPH
GMR-PERFORMANCE is offline   Reply With Quote
Old 07-15-2014, 08:12 PM   #277
flamingbig10
6.0 powered square
flamingbig10's Avatar
It was 90mph that pass is on a 75shot spraying off the line
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-23-2014, 08:03 PM   #278
dinnut
dinnut's Avatar
Been working on a new combo. Dart 308 iron eagle heads ported. Victor jr. Hp1000. Lunati voodoo 60234 solid roller. 255/263 .680/.680 110. We swapped in 4.56 gears. Truck has a 30" drag radial on it. Carb still needs some work but here is the current best
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 08-01-2014, 09:09 PM   #279
smallblockchev
Don't laugh at my sad times but it was with an open rear end my first night testing with new motor. 15.02 at 98.8 mph in the 1/4. Tried as hard as I could but it was all smoke until about the 330ft line
2007 Chevy 2500HD all stock
1985 Chevy Blazer- sold
1971 Chevy c10- The Mistress
2014 Ford Interceptor SUV
smallblockchev is offline   Reply With Quote
Old 08-16-2014, 04:23 PM   #280
flips72
flips72's Avatar
my new best, left side
flips72 is offline   Reply With Quote
Old 08-16-2014, 05:18 PM   #281
GMR-PERFORMANCE
Looks like a great run.. MPH is lower than most for that ET.. I ran a 7.3 at 98... WHat gear do you have?
Old 08-16-2014, 09:38 PM   #282
flips72
flips72's Avatar
thanks, i'm running a 4.10
Old 08-18-2014, 04:24 PM   #283
flamingbig10
6.0 powered square
125 shot off the line
Aaron
Old 08-20-2014, 08:49 PM   #284
flips72
flips72's Avatar
[QUOTE=flamingbig10;6806926]
125 shot off the line[/QUOTE are you still running a truck 12 bolt?
Old 08-21-2014, 04:52 PM   #285
flamingbig10
6.0 powered square
Yes with 373 and a girdle cover
Aaron
Old 08-30-2014, 12:23 PM   #286
flips72
flips72's Avatar
finally broke into the 6,s last night, cant understand why my mph isn't picking up though, any ideas? my time is the one on the left. best 60 foot ever
Old 09-01-2014, 07:55 AM   #287
Scoop1
Scoop1's Avatar
Here's my best all around so far. Something still not just right.
.883 RT (took a little nap)
1.908 60ft.
8.047 594ft.
8.602 1/8th
80.94 mph
69 swb
454 + .30
ZZ502 roller cam, roller rockers etc. mallory distr. 3.73 eaton posi 12 bolt. 295/65 15 MT drag radials.
TH 350 w/ 2200-2500 stall (I suspect this may be alittle tight should be higher)
Scoop1 is offline   Reply With Quote
Old 09-01-2014, 07:09 PM   #288
flamingbig10
6.0 powered square
125 shot sprayed at the 60 ft it was about a 100 out during the day
Aaron
Old 09-03-2014, 06:17 PM   #289
flips72
flips72's Avatar
flamingbig10, are you on slicks or drag radials?
Old 09-04-2014, 12:50 AM   #290
flamingbig10
6.0 powered square
e/t street drag radials 295/55/15
Aaron
Old 09-04-2014, 08:13 PM   #291
flips72
flips72's Avatar
wish i could get a tire with that big of a foot print under mine, on a good day (not a 100 degrees) do you hook good, if you do what air pressure are you running and what kind of a burnout do you do? hope I'm asking to many questions, just trying to get these radial figured out.
Old 09-04-2014, 08:47 PM   #292
Super73
Super73's Avatar
Flip,
What radial do you have?
What size wheel?
What pressure you running?
What about shocks and springs?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-04-2014, 09:03 PM   #293
flips72
flips72's Avatar
Originally Posted by Super73 View Post
Flip,
What size wheel?
275/60/15 m/t pro radial, 8 inch wheel, seems to hook the best at 16 psi, shocks are just Monroe gas , and springs are 4 inch lowering springs from ccp on the rear, and Monroe gas with drop spindles and 1 inch lowering springs in the front, basically stock suspension. not relly a drag truck but we do take it to a lot of test and tune nights mostly street driven.
Old 09-05-2014, 04:31 PM   #294
flamingbig10
6.0 powered square
It hook decent on a prepped track I dead hooked on a 125 shot, 18 psi, a small burn out seams like it works
Aaron
Old 10-19-2014, 05:52 PM   #295
69restomod
Just ran this past thursday to get a baseline with my new gears and before i put on my new cnc ported afr 210s and port matched super victor
r/t .122
60' 1.79
330' 5.172
1/8 8.02
mph 85.62
1000 10.51
1/4 12.642
mph 105.85
69restomod is offline   Reply With Quote
Old 10-19-2014, 10:48 PM   #296
radar1
I've got some more tuning to do, but this was the first time out to test and tune. 30 over 454, Comp cams extreme energy xe-268, Performer intake, Q-Jet, Headman full length headers, 700r4, Cal-Tracs, 3.42 10 bolt, with a gov-loc, running on Cooper street tires 275/60-15's. Car number 51, all three right columns, ignore the first column its the other guys.
radar1 is offline   Reply With Quote
Old 10-20-2014, 12:47 PM   #297
Wasted Income
Boosted Member
Wasted Income's Avatar
10 psi, 4500 lb race weight, E85
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 04-06-2015, 03:51 PM   #298
383 Stroker
383 Stroker's Avatar
Ran a 6.86@103mph last time at the track...
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 05-01-2015, 08:34 PM   #299
dinnut
dinnut's Avatar
150 shot nitrous outlet stinger on a digiset. New cam and converter for this year. Progressive and electric water pump next
70 longbed
496/th400/Ford 9"
Old 06-22-2015, 06:47 PM   #300
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
New fastest ET this Saturday
60'-1.565
1/8-7.182
1/4-11.383
MPH-115.47
68 C-10 KID is offline   Reply With Quote
