Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-13-2013, 12:10 AM   #276
SS317
SS317's Avatar
Re: Power Steering Adapter Plates
Hello Captain. I need info on pricing for an adapter plate and the steering column shaft adapter/rag joint.
1966 C10, 350 engine.
Thanks,
Sean
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
Old 01-13-2013, 02:15 AM   #277
Captainfab
60-66 Nut
I'll send you a PM
Thanks,
Sean
Old 01-20-2013, 02:45 PM   #278
1955 mancave
1955 mancave's Avatar
man that adapter plate is the ---t i had the box mounted in like 15 min. and i'm sure the brake booster adapter will be the same, great job John and after seeing what problems others have had when using other peoples brakets , you have done your work and made it easy for the rest of us.
thanks.
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 01-20-2013, 11:37 PM   #279
Captainfab
60-66 Nut
Thank you for the compliment Henry
Old 01-23-2013, 07:29 PM   #280
nhr3
nhr3's Avatar
Captain please PM me with details. I would like to order the Steering Adapter plate, Rag joint coupler. Thanks
nhr3 is offline   Reply With Quote
Old 01-24-2013, 12:09 AM   #281
Captainfab
60-66 Nut
PM sent
Old 01-24-2013, 09:38 AM   #282
nhr3
nhr3's Avatar
Thank you for your quick reply,. Money has been sent. It is very nice dealing with a small business. Too many of the vendors for this project have gotten too big and customer service has suffered. I look forward to working with your creations.
Old 01-24-2013, 05:12 PM   #283
ikester
ikester's Avatar
Hi Captain,
I have a 68 K10 with the old 3 bolt manual steering gear. It looks like I'm going to need one of your adaptor plates for my Power steering conversion. Will you ship to Canada? Thanks
ikester is offline   Reply With Quote
Old 01-25-2013, 12:54 AM   #284
Captainfab
60-66 Nut
I replied to your PM
Originally Posted by ikester View Post
Hi Captain,
Old 01-27-2013, 02:47 AM   #285
Rotten62
Rotten62's Avatar
Captain, I would greatly appreciate it if you could email me info (rotten62@ymail.com) on how to purchase your steering adapter setup and one of your power brake adapters for a 62. Thank you in advance!
Rotten62 is offline   Reply With Quote
Old 01-27-2013, 11:02 AM   #286
1955 mancave
i thought i posted picures so now i will
thanks.
Old 01-28-2013, 12:00 AM   #287
Captainfab
60-66 Nut
Thanks for posting your pictures here Henry
Looks good
Old 01-29-2013, 12:48 PM   #288
MikeN
MikeN's Avatar
For you guys that have done this swap, what are you doing for hoses? I bought a presssure hose for a 73 C10, and no way it will work. The fittings are right (5/8" inverted flare one end, 11/16" inverted flare on the other) but the bends are just all wrong. Can't make it work.
I also tried fabbing a steel braided line with AN fittings at each end (which I have done many times on fuel lines and tranny lines) but it blew the fitting off the hose twice when I fired the engine. I understand the pressure is much higher in a power steering system, like 175PSI or something.
Anyway, I'm open to suggestion at this point. If anybody has a part number or application for a pre-bent hose/line that will work, I sure could use it.
The adapter plate and installation and everything was top notch otherwise though...very easy installation and I sure am looking forward to modern steering.
MikeN is online now   Reply With Quote
Old 01-29-2013, 03:16 PM   #289
64fleetside
IIRC I used hoses for a 71-72.
64fleetside is offline   Reply With Quote
Old 01-30-2013, 12:09 AM   #290
Captainfab
60-66 Nut
It's been many years since I've done a conversion, but I would think hoses for a '68-'72 should work. Of course this depends on what engine you have and what accessory drive configuration. By that I mean whether you are running a short water pump as used in the '68-'72's, or the long water pump. You should also be able to use braided hoses. I believe Alan's Classic used braided hoses on his truck. You might also check into having a hose made up at a shop that makes hydraulic hoses. You only really need the pressure hose made up, The return hose can just be clamped to the tubes.
Old 01-30-2013, 04:55 PM   #291
MikeN
MikeN's Avatar
OK, thanks. I'm using a short waterpump and power stump pump brackets by Alan Grove, which are very close to stock. Maybe I'll try a 68-72 pressure hose.
Old 01-30-2013, 06:39 PM   #292
jayoldschool
Moderator
Will 6cyl car pump brackets work on the 230 in the trucks?
jayoldschool is online now   Reply With Quote
Old 01-30-2013, 11:53 PM   #293
Captainfab
60-66 Nut
Yes. As long as they are for the early 230/250 with the seperate head and intake, and not the integrated head.
Old 02-13-2013, 01:38 PM   #294
gbrown
gbrown's Avatar
Originally Posted by Captainfab View Post
I haven't put one of these on a '60-'62, but I don't see why it wouldn't work. It's been a long time since I've looked at the frame on a '60-'62, but it seems to me like the area where the steering box is the frame is boxed. That being the case you would need some pieces of tube to go between the inner and outter frame, and some longer bolts.
Could I forgo the pieces of tube and longer bolts if I were able to just weld your bracket to my frame rail like you suggest doing in the 1st post? Also, does your bracket include directions regarding re-installing the steering shaft, etc? Thanks.
gbrown is offline   Reply With Quote
Old 02-14-2013, 12:01 AM   #295
Captainfab
60-66 Nut
Yes you could stitch weld the plate to the frame, and not use the tubes. However, you will still need to cut holes in the inner flame web to unstall the bolts into the steering box.
The installation instructions do show you how to re-use the original flange from the end of the steering column shaft. However that does require the use of a drill press and a welder. If those are not available, the tube and flange that I sell is a simple solution.
Old 02-19-2013, 05:36 PM   #296
skooks
Hello
I am interested in purchasing one of your power steering adapter plates. I have a 1961 Chevy c10. Also what pitman arm did you use? I am new to this Website and not sure how we make our transaction. Thankyou
Skooks
skooks is offline   Reply With Quote
Old 02-20-2013, 12:50 AM   #297
Captainfab
60-66 Nut
Hello and welcome to the forum
My power steering adapter plates are designed to be used on the '63-'66 C series frames, as well as '68 and earlier K series frames. They can be used on the '60-'62 C series frames, but you will need to make up your own tubes to go between the inner and outer frame webs, and possibly a little other fabricating. Let me know.
Originally Posted by skooks View Post
Hello
Skooks
Old 02-20-2013, 10:34 AM   #298
skooks
Hello and thank you. Are you referring to tubes through the boxed frame, to give strength to the steering box bolts? If so, that is not a problem. I would still like to purchase one of your adapter plates. I have a 79 C10 steering box. Will that pitman arm work? Thank you for all your help.
Old 02-20-2013, 11:08 PM   #299
Captainfab
60-66 Nut
Yes I am referring to the tubes between the inner and outer frame webs to keep them from collapsing when you tighten the steering box bolts.
I do know that the '73-'87 pitman arm will fit the '63-'66 draglink, and according to a parts comparison, the stock '60-'62 and the '63-'66 pitman arms are interchangeable. So even though I have not done what you are asking, it should work.
I'll send you a PM with payment info.
Old 02-21-2013, 11:55 AM   #300
skooks
Sent you a pm about payment
