Closed Thread
Old 08-13-2011, 12:08 PM   #276
wilberweb
wilberweb's Avatar
Re: Show us your projects
Here is some of my photos of my 55 Chevy big cab project
its been a year since I started on my truck Ive had the truck for 5 years, its been sitting in the weather all that time before I was able to get it to a dry place to work on.
I have made a great deal of progress in a year it's amazing what you can do when its something that you love, I have been able to put a portion of my paycheck into my project every week that helps a lot.I just got my cab back the other day
I am going to install my bumper and radiator supports next so I can take my frame to get it powder coated.
-Larry
wilberweb is offline
Old 08-13-2011, 12:29 PM   #277
weaintscared
weaintscared's Avatar
Here it is, What you think?
[SIZE="5"] CHECK OUT MY BUILD THREAD [/SIZE
http://67-72chevytrucks.com/vboard/s...d.php?t=468622
weaintscared is offline
Old 08-27-2011, 06:26 PM   #278
Handfull 54
Handfull 54's Avatar
Re: My 54 Pro Street
This is my project. Since this picture I have added the bed and added the wheel tubs. Still have to install aluminum in the bed. Also needs interior, bumpers and rear glass as well as mount the tail gate and paint and install the hood. Blue tape is to protect the edges while I color sand and buff.
Handfull 54 is offline
Old 08-27-2011, 11:42 PM   #279
mknittle
mknittle's Avatar
looks nice
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 08-29-2011, 05:27 PM   #280
99 to Life
99 to Life's Avatar
54' love the truck. That rear looks like a beast. What are you running there?
also where did you get that thermostat housing with the temp gauge on it? Am I seeing that right?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline
Old 09-21-2011, 01:21 AM   #281
Coupeguy2001
Coupeguy2001's Avatar
this is my 57, a most willing participant.
an unsuspecting victim
Taking it apart
more
aligning the sheet metal after subframe welded on. Note the new front wheels
sitting on all fours, new rear end with all wheels the same. No engine or trans yet.
Coupeguy2001 is offline
Old 09-21-2011, 08:43 AM   #282
waybad
waybad's Avatar
love the slotted wheels!! great looking truck!
waybad is offline
Old 09-21-2011, 10:48 AM   #283
Coupeguy2001
They are up for grabs, unfortunately they are 6 lug, and I have converted to 5 on 5. I got em new in 1970. They are Carroll Shelby wheels, 15X8 with neutral backspacing. They lined up with the edges of the wheel well.
5 on 5 is what the new to me rear is, 72 chevy pickup 12 bolt, so I finagled a set of rotors that would work with the G body metric front spindles that are drilled for 5 on 5.
The tires are BFG 275/60/15.
I would have loved to keep em, I could have used spacers up front, but clearance is tight in the rear.
Old 09-21-2011, 12:41 PM   #284
waybad
waybad's Avatar
i'm 5 4/34 I have tried to find a way to get back to 6 5.5 and haven't found a reasonable way yet... I going to a 4x4 s10 chassis in the near future but again they are the same 5 4 3/4... what are you asking for them? just for kicks.. can't really use them
waybad is offline
Old 09-21-2011, 01:06 PM   #285
Coupeguy2001
If you used S-10 axles, the tires would stick in too far. With a 5 to 6 lug one inch spacer, you could space the hub out to look right and then use 6 lug wheels.
I would probably let them go for $100 each without tires. I had them polished, so they are pretty reflective. It's been 25 years since the polish job, but they've looked great the whole time.
Since the tires are pretty good, I guess $75 each for the tires.
They would come with lug nuts and locks and caps.
I couldn't find new carroll shelby cap stickers, so when I replaced the caps I just used American Racing stickers.
They would have to be rebalanced since I balanced them assembled with wheels, tires, nuts, locks, drums and hubs.
Those old original chevy drums are terrible for balance. With the overdrive, at 75 mph, you want em to not bounce.
Old 09-21-2011, 02:55 PM   #286
Coupeguy2001
In fact, there are a lot of things I can't use anymore. If you need something, ask, I might have it. drums, bearings, kingpins, engine, 3 speed, column shifter, etc. I have another perfect virgin dash as well.
Maybe I should buy a truck and put everything on that one.............oh well.
Old 09-22-2011, 09:24 AM   #287
AUSSIE54
AUSSIE54's Avatar
Here is the start of my project. Plans are for a four door crew cab, rear doors opening in the same fashion as the front, riding on the stock frame with a series II Jag IFS and a Holden Crewman 4:1 leaf sprung LSD rear. All powered by a 2007 4.2l Trailblazer inline 6, backed by a 2500 stall Turbo 350 trans. Low as legally allowed.
AUSSIE54 is offline
Old 09-22-2011, 02:51 PM   #288
Coupeguy2001
lOOKS LIKE A NICE PROJECT. i would change your trans from a 350 to a 700R4 for 2 reasons, 3.07:1 low gear and overdrive.
Don't know what your roads look like over there, but if you spend any time in your new hot rod, you will enjoy the gas mileage and lower sound levels, along with your engine lasting almost twice as long because it isn't turning as fast all the time.
Old 09-22-2011, 05:09 PM   #289
AUSSIE54
AUSSIE54's Avatar
Thanks Coupeguy, it will certainly be consideration for the future. I've had the 350 for a number off years now without using it so now is as good a chance as ever and the truck is being pieced together on a relative budget, and I already had that bit so it all helps. It will be interesting to see how long I last before switching it out though!
AUSSIE54 is offline
Old 09-24-2011, 03:09 PM   #290
Coupeguy2001
65 mph at 3800 RPM will cure you fast.
Old 09-25-2011, 10:12 PM   #291
Atommik
Atommik's Avatar
Just started my 51 chevy project this summer. Will be doing the S-10 swap. Cab floor and firewall are mostly done now.
I'm working on doing the bodywork the fenders. Planning on building my own bedsides, front panel and tailgate.
Atommik is offline
Old 09-26-2011, 05:21 PM   #292
mknittle
mknittle's Avatar
Looks good so far, I am looking forward to see how the bed works out.
Mark
My GMC build.
mknittle is offline
Old 09-28-2011, 12:56 AM   #293
Coupeguy2001
That truck has great patina. I would work with that since it is so natural......
Old 09-28-2011, 07:35 AM   #294
Atommik
Atommik's Avatar
I do kind of like it...one side is blue, the original color, and the side in the pix is almost green...unfortunately, there is way more of a rust coating than there is remaining paint. Since it will be a daily driver (April-Oct.) I will need to paint it!!
Atommik is offline
Old 09-29-2011, 08:54 PM   #295
ZR2RICK
ZR2RICK's Avatar
Here's mine.
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline
Old 09-29-2011, 11:40 PM   #296
jtwilson
jtwilson's Avatar
started w this
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to slide in sideways, totally worn out, shouting "Holy Sh!t, what a ride!"
as quoted by collin casey-off the hamb R.I.P. brotha and rip it up in the lil blue duece
jtwilson is offline
Old 09-30-2011, 12:04 AM   #297
wilberweb
wilberweb's Avatar
ZR2RICK Nice LS71 motor
I see you have the same camaro front in your truck as I have. With the wide frame in the front, here is what I did to taper my radiator supports. it took a lot of fabricating but I made it work I wanted the camaro year that had the level front and not so flared.You did a nice job.
-Larry
Old 10-03-2011, 07:10 AM   #298
Red Foreman
Red Foreman's Avatar
Larry, front frame horns have come up real nice, keep up the good work!
Red Foreman is offline
Old 10-03-2011, 08:44 AM   #299
wilberweb
wilberweb's Avatar
Red Foreman
Thanks, its a real joy to work on.
-Larry
Old 10-12-2011, 04:37 PM   #300
59weasel
wilberweb........from 1 oregon boy to the other, nice truck. finally getting the camaro clip put together this wknd. on mine. excited to finally start the ball rolling! heck who knows...by this time next year i might have a rolling chasis and the body on it.keep on truckin, you got a heck of alot more done than me!
'59 SWB (the money pit)
Camaro clip/5.3 LM7/700r4/10bolt rear/bagged/and some mild mods here and there.
'93 Jeep Cherokee with some stuff. (the toy)
'06 Silverado 2500HD (daily driver)
'12 Equinox (wifes ride)
'66 Chevy LWB (daughters ride)
59weasel is offline
Closed Thread
