Old 08-12-2013, 05:52 PM   #276
noonzor
Re: 69 c10 -- first project!!
got a delivery from ups today, lots of goodies!! got some days off starting tomorow, lets see what i can get done. cant wait!!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 08-13-2013, 08:41 PM   #277
Notch1988
Notch1988's Avatar
I have mixed feelings on this... glad you got a shipment of goodies, sad it came by UPS. LOL
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 09-29-2013, 07:02 PM   #278
noonzor
gotten lots done, just havin issues getting pictures to upload. anyways, to the current issue at hand. ive relocated my motor dropping it a bit and pushing back a few inches, however in doing so has landed my oil pan as the lowest hanging piece which doesnt have my super excited. looking at either slicing a bit out of my current pan or going with one of these....http://www.summitracing.com/int/part...4617/overview/
ive got the rear notches welded in, a new tubular rad crossmember, trailing arm crossmember welded in, new motor mounts in the works to work with my dropmember, just waiting for my wheels and tires to get delivered and ill have a rolly polly front end. anyways, ill get some pics up in the next cpl days to show some progress.
Old 09-30-2013, 03:42 PM   #279
noonzor
pictures pictures pictures.
Old 09-30-2013, 03:47 PM   #280
noonzor
and how im playing with moving the motor, quite obviously not a final design, just a rough cut out. still not sure if im going to do it though.... we'll see... maybe.... after a test fit.... possibly haha
Old 09-30-2013, 03:58 PM   #281
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the chassis. Keep the pictures coming.
mcbassin is offline   Reply With Quote
Old 10-13-2013, 03:18 PM   #282
noonzor
Didnt like how the new mounts turned out, i like the engine back but after a better look its not worth the extra work. So itll sit on the regular pb mounts the dropmember came with. More work and pics to come!
Old 10-15-2013, 03:35 PM   #283
noonzor
Working on the rear suspension. Jus cut some steel to the installed length of coilovers. Jus mocked up, tape n tack welds. Needing to think more 'budget minded' so cheaper routes will be taken from now on haha.
Old 10-15-2013, 04:55 PM   #284
tubbedII
needs more $$$
tubbedII's Avatar
I hate when reality kicks in...looks good though!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-15-2013, 08:32 PM   #285
noonzor
flipped.
Old 10-26-2013, 11:54 AM   #286
noonzor
Billet housing ends? Check!
Old 11-24-2013, 03:52 PM   #287
noonzor
For s's and g's. far from final assembly but these look better on the truck then in the bulky boxes.
Old 12-06-2013, 11:40 AM   #288
noonzor
Thank god for heated and insulated garages!
Old 05-18-2014, 12:48 PM   #289
noonzor
wowza, been a while. well, settled a contract, retro pay on its way. wedding is now 100% funded! time for some garage time, in the next month.....
- finish welding suspension pieces (panhard bar, anti-roll bar, rear crossmember/fuel cell mounts)
- blast and prime frame
- order...
- coilovers, axles, nod. centre, carrier, yoke, wheels, tires.
should have a rolling chassis by the fall. i know i know, pics or gtfo.... stay (patiently) tuned!!
Old 10-27-2014, 01:05 PM   #290
noonzor
Nothing wrong with trading a case of beer for a parts truck.
Old 06-22-2015, 04:33 PM   #291
noonzor
man its been a while, time for updates glorious updates. well the truck is fully suspended, some things here and there to finish. I have to weld some cover pieces for the openings in the tubes. I had the panhard bar bent so it would sit where i wanted it then welded a piece of 1" steel and drilled/tapped it to accept the bolt from the rod end. next ill be assembling the rear diff, then hopefully wheels and tires will be on order after next pay day. then its officially a roller!
anyways, till next time.
nooner out.
Old 06-22-2015, 11:01 PM   #292
Notch1988
Notch1988's Avatar
Nice to see this progressing... don't give up man.
Link to my build:
My GMC Project
Old 06-25-2015, 04:55 PM   #293
noonzor
wouldnt even dream of it. just getting more comfortable with the fact this trucks gonna take YRS to build haha.
Old 08-14-2015, 09:38 PM   #294
noonzor
diff cleaned up n painted.
Old 08-14-2015, 09:54 PM   #295
noonzor
front brakes assembled. the passenger side is being a *****. the bottom bolt hole for mounting the caliper is off, seems the angle the threads are at in the current hole is causing misalignment. ill be contacting cpp and wilwood for their thoughts. right now im thinkin redrill it and helicoil. well see.
Old 08-14-2015, 09:57 PM   #296
noonzor
juuuust a bit off.
Old 08-24-2015, 08:45 AM   #297
mcbassin
Still Learning
mcbassin's Avatar
Nice progress on your chassis. What's going on with your rotor/caliper?
Old 12-18-2015, 01:18 AM   #298
noonzor
the spindle was crap. the mounting holes were improperly drilled/threaded the mounting bolt for the caliper wouldnt line up. i took it to my machinist and he was gonna fix it, but when he started drilling in the casting was falling away like sand. ended up salvaging it but ive got new spindles now, so all is well. ill keep the shotty ones for another project.
new news.........chassis is painted, por15 it looks pretty decent. sprayed it and it didnt end up as glossy as ive seen. ive got to stop and grab some new nuts so i can reassemble everything and pick up some wheels n tires to get it rolling. well see what santa brings this year and ill update with pics soon.
merry christmas!
Old 12-18-2015, 02:26 AM   #299
tk-mpl
tk-mpl's Avatar
Looking good man!!! Piece by piece it's coming together!
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
Old 03-24-2016, 09:58 AM   #300
noonzor
its taken a looooonnngg time to get to this point.
