Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 02-04-2015, 01:02 AM   #276
Crash'd Artwerks
Re: Camaro Caliper Brackets
Originally Posted by Captainfab View Post
The only rotor that can be used with these brackets without modification are the ones they are designed for.
The '93-'97 F-body rotors have a 5 x 4.65" wheel stud pattern, are smaller in diameter and a different height.
I have started on a different set of brackets for the trucks using the 5 x 4.75" wheel stud pattern, but I don't know when I will have time to finish them up.
Gotcha. I guess I'll just have to buy a pair of Impala rotors and re-drill the 4.75 pattern in between the 5" pattern.
Crash'd Artwerks is offline   Reply With Quote
Old 03-06-2015, 03:37 PM   #277
dan468
dan468's Avatar
How do these calipers adjust the parking brake for pad wear?
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 03-07-2015, 01:03 AM   #278
Captainfab
60-66 Nut
I just assumed they had some sort of internal ratcheting mechanism. Did you use new/rebuilt calipers or used?
Old 03-07-2015, 01:05 AM   #279
dan468
dan468's Avatar
They are rebuilt. The design does not have a ratchet. The Camero did though, have a ratchet built into the handle. But I'm unsure if this was to adjust the parking brake or simply keep the cables tight.
68 C-10
Build thread
Old 04-09-2015, 11:32 AM   #280
dan468
dan468's Avatar
Has anyone successfully tested this on a running truck? How's the P brake hold?
68 C-10
Build thread
Old 05-01-2015, 05:23 PM   #281
jadedbird
jadedbird's Avatar
jadedbird is offline   Reply With Quote
Old 05-01-2015, 05:24 PM   #282
jadedbird
jadedbird's Avatar
Do you make a kit to utilize a 98-02 camaro ls1 brake it? I have a 6 lug 64
Old 05-02-2015, 12:08 AM   #283
Captainfab
60-66 Nut
No I do not. I just have the two 6 lug rear disc brackets.
Old 06-25-2015, 10:57 PM   #284
ls1nova71
ls1nova71's Avatar
Not sure if this is the right place to ask this question, but what is everybody using these rear brakes using for a proportioning valve? I would really like to avoid using an adjustable one if at all possible.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-25-2015, 11:24 PM   #285
Captainfab
60-66 Nut
I do not know if there are any differences in the brake bias with the aftermarket fixed disc/disc proportioning valves.
Old 06-29-2015, 08:01 PM   #286
jeromio
I had interference with the e-brake lever arm on the caliper and the bottom of the back of the trailing arm. SO I installed these facing forward. But now I am putting airbags in the rear and the e-brake cable will interfere with the bag.
The main problem is the big rubber bushing that's on the e-brake lever arm. I don't know what that is for - harmonic dampening?
Any suggestions?
jeromio is offline   Reply With Quote
Old 06-29-2015, 11:47 PM   #287
Captainfab
60-66 Nut
I believe the 'rubber bushing' you are referring to can be removed. Do you have any pics of your installation. I just can nit picture how the e-brake lever could make contact with the trailing arm. I have been looking at the pics in post #184 and post #220.
Any suggestions?
Old 07-19-2015, 09:29 PM   #288
Tom
driving is in my blood
Tom's Avatar
I do not yet make any rear disc brackets for the '88-'98 trucks. I keep hoping to find the time to work on those, but with working 70-80 hrs a week every week, time is scarce. Does your truck have the 8.5" 10 bolt or the 9.5" 14 bolt?
The time has finally come and I check back to make sure everything is good and see this. So I re-read the thread and found you already said they won't work many pages ago. Dangit!! I have the 10 bolt. When I read 10 and 12 bolts I just assumed my 98's 10 bolt was the same.
Old 07-19-2015, 11:36 PM   #289
Captainfab
60-66 Nut
Sorry but I still don't have anything for the '88-'98 10 bolts, I'm still working 80 hrs a week every week. There are actually 2 versions of the 8.5" 10 bolts in the '88-'98 trucks which have different backing plate flanges both of which are different from the '87 and earlier 10 bolts. I assume one is a standard duty and the other is a heavy duty. Additionally the '88-'98's have a wider brake offset. I am still hoping to get to these one day.
Old 08-03-2015, 04:54 PM   #290
SouthernYankee
SouthernYankee's Avatar
hello there! Please tell me you are still making these?!
SouthernYankee is offline   Reply With Quote
Old 08-04-2015, 12:45 AM   #291
Captainfab
60-66 Nut
Yes all of my products are still available including these rear disc brackets. would you like them in bare steel or satin black powder coat?
Old 08-04-2015, 03:58 PM   #292
SouthernYankee
PM'd. Thanks!
Old 08-05-2015, 12:05 AM   #293
Captainfab
60-66 Nut
PM replied to
Old 08-10-2015, 04:15 PM   #294
claytonisbob
I PM'd you about getting some bare steel camaro caliper/impala rotor brackets.
claytonisbob is offline   Reply With Quote
Old 08-10-2015, 11:30 PM   #295
Captainfab
60-66 Nut
I replied to your PM from early this morning. I only have time to log onto the forum once a day, in the evenings after I get home.
Old 11-12-2015, 01:43 PM   #296
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Sent ya a PM for a set of brackets.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-13-2015, 01:12 AM   #297
Captainfab
60-66 Nut
PM replied to
Old 01-14-2016, 01:07 PM   #298
crakarjax
crakarjax's Avatar
After reading through this entire thread it's not clear -- has anyone found calipers that include the bracket and e-brake setup? Rock Auto has excellent deals but not all of their products have pics, so it's hard to say whether this stuff is included.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-15-2016, 08:32 AM   #299
rocknss
rocknss's Avatar
I picked up mine from an auto salvage yard and made sure they had the e-brake setup. I cleaned them up and are working great!
rocknss is offline   Reply With Quote
Old 01-15-2016, 03:32 PM   #300
crakarjax
crakarjax's Avatar
I'd rather find a new or reman set, never know what you're going to get with used calipers! On the other hand there could be useful connectors to be had along with the salvaged calipers...
