03-12-2014, 10:57 AM | #276 |
"Where were you in '62?"
Re: Lets see some 1960 - 1966 engine bays
Fast Freddy Racing
The worlds fastest pick up with a 6.04 sec / 234,9 mph Biography Driver: Fredrik Fagerström Brand: Chevrolet Pickup Class: Pro Modified Car Built in: 1997 Built by: Bars Race Cars Chassis: Bars-97 update 2011-12 Body: Chevrolet C10 Color: Flames/Rust Painted by: Ray Hill Fuel: Metanol Poweradder: Blower Best ET: 6.04 Best speed: 378 Chevrolet Pickup Motor: BAE Volume: 521 cu Block: BAE Heads: BAE 6 Crankshaft: Briant Fuel pump: Waterman Clutch: Leanders 3 disc Gearbox: 3´växlad Lenco https://www.facebook.com/FastFreddyS.../photos_stream http://www.fastfreddy.nu/
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
03-12-2014, 03:41 PM | #277 |
1964 Long bed 292 that I plan on doing up, been looking hear and see plenty that I can do to make this a cool looking engine bay. Thanks For Posting your 6 cyl. Thanks Doc
03-12-2014, 09:51 PM | #278 |
03-12-2014, 10:05 PM | #279 |
Prepare for mass amounts of power and Torque!!!!!!!!…. Or maybe just my 305 V6…
03-13-2014, 01:17 PM | #280 |
2004 Silverado 5.3L Vortec w/ 4L60e
Doug Thorley Long Tubes
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
03-13-2014, 01:55 PM | #281 |
03-13-2014, 07:34 PM | #282 |
This is the engine in our 66 GMC short bed. 250 six offenhauser intake & valve cover - hedman hedder. powerglide trans.
03-14-2014, 10:34 AM | #283 |
engine in my 63 4x4 suburban. When I bought the truck, there was no motor and no front clip, but the truck was originally a V8. This is a 4-bolt 350 but is dressed to look as much like a 283 as possible. Uses a 1967 spread-bore 4 barrel intake with the correct-for-the-truck oil filler, (I added a PCV valve in the original 283 "script" valve cover, and added the bracket from the 350 for the dipstick) I used all the front accessories from a period correct 283, (short water pump, original PS pump, all original pulleys.) Also used correct original exhaust manifolds. Still need to find an original type air filter with a 4-barrel base. I know that the motor SHOULD be gray, but I went for the Chevy orange anyway. Where I come from, Chevy V8's are ORANGE! The truck was a factory 4-speed, but I replaced it with a 3-speed manual with overdrive, and column shift.
03-14-2014, 04:44 PM | #284 |
Here is the 283 in my 63 Burb. The original motor but has been rebuilt about 25 years ago I'm told.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
03-30-2014, 09:20 PM | #285 |
Modified air cleaner and cold air system sitting on top of a 355 in my '64.
03-30-2014, 11:11 PM | #286 |
My 292 in 64 truk, New braided lines and hoses, Spikes and more! I got finned aluminum sidecovers I still need to paint up and install, and need to finish the firewall paint so Ill post one later on too,
Have a good week.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp Last edited by 64chevtruck; 03-30-2014 at 11:33 PM. |
03-31-2014, 12:30 AM | #287 |
Hey 64 truck. Howd you set up that 2x1 Offy for the single barrels and link it to your gas pedal. That's a dilemma I'm working on and could use some advice.
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie. |
03-31-2014, 12:52 AM | #288 |
Howdy, those are progressive 2 barrel Holley Weber carbs, I used the stock bell crank? (thing on the intake) I just cut it up a little, the linkage from there to up to the carbs is a stock piece of throttle linkage too, Then I just took a 5 gallon bucket handle and made the piece that goes from the bell crank back to the arm on your firewall. Its a little cheesy but the geometry was good enough to make it work ok.
The linkage for single barrel carbs is on the other side and would be different I think. Not sure though.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
03-31-2014, 12:54 AM | #289 |
Ok I thought of that too but to hack it up and screw it up was the ice breaker. Truck is my daily driver so yeah. Lol. I'm about done just have to install everything.
03-31-2014, 01:12 AM | #290 |
Kool mon, Im no perfectionist as can be seen in my build thread, but it seems to get full range of motion with no binding,
I have spare stock parts so let me know if you try something that doesent work I can send em to you, I cant wait to see pics,
03-31-2014, 01:38 AM | #291 |
Here's what it's like so far. I'm navy and I'm on a stop in San Diego right now but as soon as I get back in April it's going 9 the truck.
03-31-2014, 01:59 AM | #292 |
Kool, Looks good, When my Pappy would run dual Rochesters he would build his linkage with small pieces of angle iron bolted to the main bolts that hold the carbs down, The angle would have a hole in each one that a shaft would run through, then he would mount arms to the shaft. His stuff was always on older trux but I can get a pic of a few of his setups if you want to look.
Dual carbs was always a must with Pappy, an headers, and dual points and,,, you get it.
03-31-2014, 02:25 PM | #293 |
That would be great if you could. Right now I'm trying to think/fab a bracket for my dual choke cable. Run it off the original but with a bridge link to both butterfly plates to work together in unison. I just need it to bolt onto the inboard side 9 the manifold and voila done.
03-31-2014, 03:39 PM | #294 |
Post Whore
D Rock...I'm diggin the dual carb setup.
Update picture of mine.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-31-2014, 04:07 PM | #295 |
I like the Blue and Black TJ. Cleeen.
Dillon, Id only run one choke, if you have 2 mounted up already you could hook the second one up like a Throttle adjustment like Old trux had, Manual ancient cruise control. Err unless its a 2 into 1 cable I mean.
03-31-2014, 10:49 PM | #296 |
Well it'd be one cable into two chokes. I'd use the single cable to pull a dual rod or something to pull both butterfly plates at the same time. I dig it TJ nice paint job and all. Same distributor I have as well almost. Lol
04-06-2014, 10:35 PM | #297 |
Here's mine
05-27-2014, 08:21 PM | #298 |
Bump..
05-27-2014, 11:11 PM | #299 |
lots of potential with the 6. heres how mine started & ended (for now), 6 cylinders of raw domestic american power! may not look like much, but shes the most reliable truck iv owned, gotta love chevy
05-28-2014, 07:20 AM | #300 |
Sold my 64, Just bought a 2004 GMC RST , Great truck so far. Thanks Doc
