Old 03-19-2020, 11:11 PM   #276
Fatherof3
Fatherof3's Avatar
Re: My 66 Service Truck Build Thread
Originally Posted by LostMy65 View Post
Hey, the plan changed again. I got this beat up bed for free, so I'm installing it. The main goal for this 66 is to use it for truck stuff so I can finish all I want to do with my 65.
Dana 60 with Truck Arm mounts. I'm jealous.
I have the Eaton in my 65 C20 you can't do anything with.
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 03-19-2020, 11:29 PM   #277
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Actually, it's a 79 GM 14-Bolt with 4:11 gears.
I think the Eaton I had in it before was 4:56
66 C20 Service Truck:
Old 03-20-2020, 07:12 PM   #278
LostMy65
LostMy65's Avatar
Rebuilt my first carburetor a couple weeks ago.
The one on my 66 acted weird. The truck would backfire when I hit the gas, it would also bog.
Put the rebuilt one on it today. Man does it run nice.
Old 03-21-2020, 09:23 AM   #279
Fatherof3
Fatherof3's Avatar
Any idea the width difference between the two?
Old 03-21-2020, 11:40 AM   #280
LostMy65
LostMy65's Avatar
I'll guess 3/4 inch wider each side for the 14-bolt. 1-1/2" total.
That's what I think I've read.
You might find an answer in one of these two threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=550878
http://67-72chevytrucks.com/vboard/s...highlight=Bolt
Old 03-21-2020, 11:12 PM   #281
LostMy65
LostMy65's Avatar
Installed a barden bumper and mocked up the tailgate.
Old 04-01-2021, 08:19 PM   #282
LostMy65
LostMy65's Avatar
Been having trouble with it running rough and backfiring when I rev it up.
Idles really nice though.
I've swapped out the distributor, I've checked the timing, and I've swapped the carb to the fitech from my 65, and still acts exactly the same.
Next I'm going to check if the timing chain hasn't skipped a tooth.
Old 04-01-2021, 11:30 PM   #283
cwcarpenter98
cwcarpenter98's Avatar
You've probably already checked, but I did a stupid thing twice on my truck. First time was when I first changed the plug wires. I had two wire right next to each other on the cap switched. Idled fine but couldn't drive it over 1500 rpm because of it backfiring a ton. Second time that happend was after the engine swap and putting an HEI dizzy in. Swapped two plug wires again and had a heck of a time figuring it out because I was certain that I had wired it correctly
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-01-2021, 11:56 PM   #284
LostMy65
LostMy65's Avatar
Yes, I did check that, but I'll check again. Thanks
Old 05-13-2021, 01:07 PM   #285
LostMy65
LostMy65's Avatar
Moved it into our other barn.
I'm going to tinker on the motor some more and see if I can get it to run nice. It's no fun reaching over to access the motor. Maybe I'll build some scaffolding around the front . But I'll start with doing a compression test and then a leak down test. Depending, I may just pull the front clip off to make tinkering on the motor more enjoyable.
I don't mind on my 65 because it's a lot lower.
Old 02-08-2022, 02:52 PM   #286
LostMy65
LostMy65's Avatar
Okay, digging in to this backfiring again. I want to sell it or trade it for an old StarCraft boat.
Taking it back down to my house today and will pull off the front clip so I can get access to everything and step through everything again. Not even going to bother with the carb at this time. The Edelbrock runs great on my 65. I even tried my fitech. I've switched distributors. Still the same issue.
I'll start with cranking it up to TDC on the compression stroke and see where the distributor points to.
Then probably pull the timing cover to make sure it hasn't skipped a tooth.
After that, I'll pull the valve covers and make sure all the valves fully open and close.
Old 02-09-2022, 04:00 PM   #287
LostMy65
LostMy65's Avatar
Engine is still a clean engine.
Old 02-09-2022, 04:09 PM   #288
cwcarpenter98
Always good to see no sludge when you open one up
Christian Carpenter
Old 02-10-2022, 07:57 PM   #289
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Weak valve springs can cause backfire
Just sayin'
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 05-10-2022, 07:43 PM   #290
LostMy65
LostMy65's Avatar
Did a compression test. #6 is about 10 psi less than the others.
I squirt some oil in there and it's still the same. Sounds to me like a valve issue with #6.
I put all new plugs and wires on as my last check for the back fire issue.
But it makes no sense to dump money into gm Goodwrench heads, so I'll either pull them and try some lapping or buy a nicer set.
Old 05-11-2022, 08:42 PM   #291
LostMy65
LostMy65's Avatar
With the new plugs and wires it fired right up. Dialed in the timing and very smooth running. I revved it up to about 1500 and not an issue.
I'll probably check the compression again on #6 to see if running it for awhile changed anything. The motor had been sitting for awhile without running.
Old 05-13-2022, 10:49 PM   #292
LostMy65
LostMy65's Avatar
Installed a Carter P4070 inline electric fuel pump as a primer pump.
I was looking for an electronic pump to prime my edelbrock 1406 carb so i wouldn't have to crank and crank just to fill the bowls before it would start.
Turn it on just long enough to fill the bowls.
Start the motor and turn it off.
Works great.
Old 05-13-2022, 10:51 PM   #293
cwcarpenter98
So the new plugs and wires fixed the backfire issue completely, yes?
Sounds like your starter is going to be happier too
Christian Carpenter
Old 05-13-2022, 11:00 PM   #294
LostMy65
LostMy65's Avatar
Yes, runs great now.
Old 05-13-2022, 11:50 PM   #295
cwcarpenter98
Good deal! Glad you were able to figure it out
Christian Carpenter
Old 05-14-2022, 03:43 PM   #296
LostMy65
LostMy65's Avatar
Saving this for later.
DIY Alignment
http://67-72chevytrucks.com/vboard/s...d.php?t=399479
Old 06-18-2022, 05:03 PM   #297
LostMy65
LostMy65's Avatar
If any of you have been following this thread and my 65 thread, you'll know that I change directions a lot.
I have had my 65 back for I think 10 years now and I still haven't got all the upgrades I wanted to do to it done. So, my latest direction is to move my 65 cab and front clip over to this 66. The 66 already has power steering, power disc brakes, a 14 bolt, and a low mileage 350.
The whole downside to the 66 is how bad of shape the cab was in.
That is my goal for this weekend.
I'll load up some pictures a little later.
Old 06-18-2022, 07:17 PM   #298
LostMy65
LostMy65's Avatar
Got 65 my cab off my 62 frame and on to the 66 frame.
From this point forward I'll be posting in my 65 thread any further progress.
