Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-03-2016, 02:30 PM   #276
stevenbear72
stevenbear72's Avatar
Re: 1973 K20 Build Thread
Nice build
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 06-17-2017, 04:51 PM   #277
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
I've had a Champion aluminum big block radiator laying around for a couple years and finally got around to installing it. A bit wider and taller compared to my original 350 sbc radiator. Shroud will have to be cut/modified to fit. I'll have to fab/buy some brackets. Will use without for now. Pics will follow.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 06-17-2017, 04:59 PM   #278
TheWhiteElephant
God is good!
Here are the pics...
Mando
Old 06-17-2017, 05:42 PM   #279
TheWhiteElephant
God is good!
Mando
Old 11-01-2017, 11:05 AM   #280
MofoG23
MofoG23's Avatar
This has been a great thread to follow.
I have a 76 K20 and plan to address many of the items you covered here.
1976 K20 350/205/465 - "Big Red"
2010 VW GTI
2013 VW Touareg
MofoG23 is offline   Reply With Quote
Old 01-06-2018, 12:23 PM   #281
duallyjams
duallyjams's Avatar
2018 bump
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-04-2018, 01:11 PM   #282
6BT 56
6BT 56's Avatar
Ya . Bump. I have always liked this build . Quality of work on a nice truck. Not a over top will it ever run build . Love the stance aswell. I wish my k20 was one colour. Lol.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 04-10-2019, 03:16 PM   #283
CustomDeluxe1980
Anything new
CustomDeluxe1980 is offline   Reply With Quote
Old 07-20-2019, 01:30 PM   #284
70inbville
where did you go? we need more!!!!!
70inbville is offline   Reply With Quote
Old 10-31-2019, 08:43 PM   #285
El Dorado Jim
Originally Posted by TheWhiteElephant View Post
So I got everything buttoned up a few weeks ago. I got the exhaust installed, went with super turbos with turn-downs right before the rear axle. I'm pretty surprised at how quiet it is. I will post many more pics of what happened between the installation of the rear brakes/booster/master.
Right now I just have to tie up a few loose ends to go and get it inspected. Still haven't resolved the E-brake issue as I will now have to modify it due to the lift, but I've driven the truck around the block a few times, got a little cocky and drove it to the gas station, too.
I tossed the idea around on what tires to get for months. I did not want the run-of-the-mill 33X12.50 BFG "standard issue" tire. I wanted my truck to look a little different, and I wanted a skinny, not-too-tall tire. I have always liked the look of the old Ford Hi-boys and that is the look I wanted to duplicate all along. I wanted some room between the wells and the tires.
I really like the Firestone Transforce A/T in a 235/85/16 size (about 32 inches), so that is what I eventually got. I love the way it looks...
Attachment 783479
Attachment 783480
Attachment 783481
Attachment 783482
Attachment 783483
awesome rig, any updates?
El Dorado Jim is offline   Reply With Quote
Old 10-31-2019, 08:50 PM   #286
El Dorado Jim
Thanks, Tony. I read this, too. I looked all over the place and couldn't find these sources. One of the Bronco sites is making them for the internal hubs, though. All I did was buy an extra set of the plastic ones from Dennis Carpenter. I'm not going to wheel this thing so I "should" be okay.
there is a guy, "GMCGRIM" on this site that is making these out of aluminum, I bought a set from him, they great
Old 10-31-2019, 08:54 PM   #287
El Dorado Jim
I installed the alternator, power steering pressure line, and spark plug wires. I was having second (and third, and fourth) thoughts about the non-subtle, super bright blue plug wires but they've grown on me in the past few hours. I'm going to route them underneath the manifolds for a clean look.
I put in new fuel lines from the pump along with a glass fuel filter. I'm a big proponent of glass filters. Very helpful when diagnosing. You can also see a new intake heater hose fitting I got from the good ol' "Help" section @ Oreilly's for $5.49. Much better than the $11.59 they want for it from Classic Industries.
do not use the glass fuel filter, seems like a good idea, i used them too until i had one split down the side and was spraying gas like a fan all over the engine, dont know how it didnt catch fire, i will never use another one
1973, 1973 k20, ball joint, ball joints, rough country
