Old 03-16-2012, 01:53 PM   #276
McMurphy
McMurphy's Avatar
Re: Mesquite 1966 C10 - LS3 W/Air Ride
Where did you get your transmission support cross member?
I am going to need one I think.
Othewise you are looking good man!!!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 03-16-2012, 11:11 PM   #277
66ChevyMax
66ChevyMax's Avatar
I got it from CPP Item #CP9427 - $79.00. Thanks Murph!
http://www.classicperform.com/Store/...uck/CP9427.htm
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 03-16-2012, 11:13 PM   #278
66ChevyMax
66ChevyMax's Avatar
looks great! i'm happy to see you making more progress...and i agree, i like this warmer weather...not sure about there, but already Hi's in the low 80's here
Same here 80's and the wind has died down some thank goodness.
Originally Posted by OLDIRON69 View Post
I saw my first copperhead yesterday so it is officially spring!
Bolt a seat on that thing and drive it!
The thought has crossed my mind
Craig
Old 03-16-2012, 11:27 PM   #279
66ChevyMax
66ChevyMax's Avatar
Finished mocking up the exhaust, now lots of practice with the TIG, got my first shock tonight . I know it's not exactly professional but it's my creation
Craig
Old 03-17-2012, 02:03 AM   #280
Pop's C-10
Pop's C-10's Avatar
Nice work on tha pipe...is that universal kit?
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-17-2012, 07:54 AM   #281
Notch1988
Notch1988's Avatar
Looks awesome! Wicked build and some great talent being displayed.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 03-17-2012, 11:24 AM   #282
66ChevyMax
66ChevyMax's Avatar
It's a magna flow kit made for this truck. But it's for full length headers and stock cross member and I don't have either. It came with a X member but I couldn't find a way to make that work up inside the frame.
Thanks Notch
Craig
Old 03-17-2012, 12:26 PM   #283
shrunken66stroker
shrunken66stroker's Avatar
Are you going to put turn downs after the mufflers and dump towards the ground in front of the rear axel? Or are you going to try and go over the axel and dump out the rear?
shrunken66stroker is offline   Reply With Quote
Old 03-17-2012, 02:13 PM   #284
66ChevyMax
66ChevyMax's Avatar
Not sure yet, but I think in front for now
Craig
Old 03-18-2012, 10:35 PM   #285
66ChevyMax
66ChevyMax's Avatar
Spent the weekend getting use to tig welding. Lots of really ugly welds but finally got the hang of it. Welded the stainless exhaust pipe. I really like tig no smoke and no splatter.
Craig
Old 03-19-2012, 01:55 AM   #286
Fleet '66
Active Member
Fleet '66's Avatar
Fantastic build! Clean..clean..clean. Lots of quality work and excellent photo documentation. Keep up the great work. Love the shop too. Can't wait to get the new shop completed so I can start on several builds here.
Fleet '66
'66 C-10 SWB 350 w/3 spd OD 4:11's - driver/project...future T-5 trans upgrade
'64 C-10 LWB BBW near future project - "The Wife's Ride"
'58 "Apache"Stepside BBW w/'75 K-10 4x4 conversion 331 w/350TH and NP 205 transfer 3:73's - occasional driver/ show
Fleet '66 is offline   Reply With Quote
Old 03-19-2012, 08:29 AM   #287
duallyjams
duallyjams's Avatar
JMO run tail pipes if you can it will make a big difference in the cab.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-19-2012, 09:04 PM   #288
66ChevyMax
66ChevyMax's Avatar
Thanks fleet!
I agree if I can find a spot for the tail pipe to exit I probably will, don't really want the droooooan. Not a lot of room as I see it right now
Craig
Old 03-31-2012, 12:43 AM   #289
66ChevyMax
66ChevyMax's Avatar
Made some progress tonight. Got some temporary wiring hooked up. Dakota Gauges are hooked up. Turned the motor over to prime it and had oil pressure
The bad, radiator has a small leak at the bottom, power steering hose (pressure side) leaks like crazy.
Tomorrow will power up fuel pump and check for leaks there. Don't guess I can start until the power steering hose leak is fixed.
Craig
Old 03-31-2012, 12:50 AM   #290
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Just minor setbacks, tomorrow will be a better day. You still made some progress.
Alan's Classic is offline   Reply With Quote
Old 03-31-2012, 07:45 AM   #291
duallyjams
duallyjams's Avatar
Check and double check just part of the process.
James
IG duallyjams
Old 03-31-2012, 11:03 AM   #292
66ChevyMax
66ChevyMax's Avatar
It was good, no oil pressure would have been really bad.
That's why I'm doing this now. The frustration was the radiator is brand new and the leak is at the bottom tank joint. And the power steering leak was at the new swivel joint that the hose shop installed.
Craig
Old 03-31-2012, 07:41 PM   #293
66ChevyMax
66ChevyMax's Avatar
This candle is lit
Craig
Old 03-31-2012, 08:35 PM   #294
y5mgisi
Second Chance Program
y5mgisi's Avatar
That gets me all sorts of horny!
y5mgisi is offline   Reply With Quote
Old 03-31-2012, 09:48 PM   #295
allaboutchevelles
allaboutchevelles's Avatar
WOW, sounds good!! Congrats to you! All that work has paid off now.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 03-31-2012, 09:59 PM   #296
66ChevyMax
66ChevyMax's Avatar
Here is a longer HD version.
Craig
Old 03-31-2012, 10:21 PM   #297
Alan's Classic
That's got to be an awesome feeling!!
Old 03-31-2012, 11:42 PM   #298
66ChevyMax
66ChevyMax's Avatar
S H A W I N G....
Thanks it was a big day
It was great, no error codes (woohoo). Will patch hole in radiator tomorrow and get power steering hose fixed Monday. Need to do some research on how to get the Dakota Gauges Tach to work.
Craig
Old 04-01-2012, 01:46 AM   #299
Captainfab
60-66 Nut
That sounds awesome
Even with a couple minor issues, that has to still be a good feeling.
Gotta get me a LSx engine one of these days......
Old 04-01-2012, 06:52 PM   #300
65Custom
Always nice to fire up an engine for the first time, Sounds nice!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
