Old 11-09-2015, 08:23 AM   #276
craneboy72
craneboy72's Avatar
Re: Softop installation no Holes
Pm sent
craneboy72 is offline   Reply With Quote
Old 11-09-2015, 09:31 AM   #277
tp85
PM sent
tp85 is offline   Reply With Quote
Old 11-09-2015, 09:43 AM   #278
colgad
colgad's Avatar
PM Sent
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 11-09-2015, 11:23 AM   #279
timski69gmc
timski69gmc's Avatar
PM Sent
timski69gmc is offline   Reply With Quote
Old 11-09-2015, 06:42 PM   #280
jaybirdk5
PM Sent
jaybirdk5 is offline   Reply With Quote
Old 11-09-2015, 07:09 PM   #281
Minnz
Minnz's Avatar
Pm sent
72 Ochre Blazer
69 Camaro Z28 Garnet Red
48 Willys (rolled)
Minnz is offline   Reply With Quote
Old 11-10-2015, 01:08 AM   #282
71swb4x4
71swb4x4's Avatar
PM sent
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-12-2015, 02:17 PM   #283
CTENTA1
Registered 1971 K5
PM sent.
CTENTA1 is offline   Reply With Quote
Old 11-13-2015, 03:34 PM   #284
niceguy678us
PM Sent.
1970 Datsun 240Z
1972 K5 Blazer Highlander
1972 Chevelle
1959 Apache 3100 SWB Fleetside
2006 VTX 1800f
Build thread:
http://67-72chevytrucks.com/vboard/s...ght=highlander
niceguy678us is offline   Reply With Quote
Old 11-13-2015, 03:43 PM   #285
robs71k5
K5drive
robs71k5's Avatar
I was brought to my attention that there aren't any photos that demonstrate how they might look ,fit or function on your Blazers Thanks to the individules for pointing that out to me and hope it brings some clarity to you regards Rob
robs71k5 is offline   Reply With Quote
Old 11-13-2015, 03:44 PM   #286
robs71k5
K5drive
robs71k5's Avatar
Old 11-16-2015, 06:59 PM   #287
robs71k5
K5drive
robs71k5's Avatar
Header installation step one
1. Place header on top of windshield
2. Hold each side down snug untill the flat section where the bolt at the sunviser mount on each side has made contact with mating surface. Step three will provide info if not able to and another person to hold it down snug would help immensely
3 . In the event you cannot make the surface mate. You will notice that the clearance issue is at the rain gutter on the outside. You will need to provide clearance by sketching with a pencil while in place you can accurately give clearance by transcribing a new line that follows the rain gutter. (Refer to picture below "A"). This area was left a little long so you can get as closely trimmed as possible as it seems to be a water entry point on my Blazer. it just made sense trim it a closer while on the individual Blazers as close as possible . I would very much like feed back on how much was trimmed on yours if possible . It may serve as good info for the door windows weather proofing
Old 11-16-2015, 07:01 PM   #288
robs71k5
K5drive
robs71k5's Avatar
Header installation step two
And then proceed to sand or trim the edge to mimic that line on the Header . Once you have provided clearance you should be able to bolt it down with out being hung up on the rain gutter and you will also not introduce cracking around the 5/16 bolt holes at the flat mounting surface in above picture "A" just above the "A" by torquing in down while it hangs up.
The bottom picture shows the hardware that was made for me (5/16 bolt 1 inch grip length and a taped piece of aluminum stock about 1 1/4 inch long with a groove turned into it so the visor will rotate around it .
The seal from your hard top is designed to fit into the upper bulged section of Header which might serve to seal out the elements . Be mindful of the hole sizes on each side of the header being different from the four centre holes
3A. Picture Below is to explain that you need to wait till the Header is seated on the mating surfaces before you trim the flange to the same foot print of the corresponding door seal . Be careful not to cut this off too much as it may reduce you eligibility to incorporate a pending door seal application planned but not yet developed due to Header development and distribution. But we love to hear your ideas and suggestions on this project lName:  image.jpg
Old 11-16-2015, 07:05 PM   #289
robs71k5
K5drive
robs71k5's Avatar
Header installation Step three
4. After you have located the outer bolts and provided clearance for the outer surface and drilled the bolt holes. You can locate the two centre holes in pic "C". It's a bit of
a toss up weather you use two bolts on each bracket or just one which I find is plenty .
Old 11-16-2015, 07:14 PM   #290
robs71k5
K5drive
robs71k5's Avatar
Size:  33.1 KBHeader installation step four
5. Once you have located and drilled all the holes you require you can move to laying out the snaps for you softop.
6. Softopper provided me with a aluminum strip with snaps installed that gives one lots of info for the spacing . For my self I used another method . I got a piece of material and stapled a piece of 1"x 2"a couple ft forward so I could reach a pull from the front of the truck as it stretched across the width of the truck then scalloped the material to cut out every other snap and installed mating snap in the material at the centre and then did every other snap so I could get a good pull on the canvas while stretching it across evenly but I took a sharpy and put a dot at every snap location while the snaps on the softopper leading edge where right over the location (poor illustration below)
When you pick up your snaps . I try to find the ones that come as a stud with what looks like a flat washer (far left in lower pic )They work great for the thickness of the leading edge flange but I have a hard time finding these
Old 11-16-2015, 07:20 PM   #291
robs71k5
K5drive
robs71k5's Avatar
Header installation step five
7. The rear bed rail (square tubing provided by softoppers) installations needs to be flush with the inside of the quarter panel. I drilled the holes myself but my understanding is they will send the rails pre drilled . I cannot provide details on the hole locations because I asked them to ship me u drilled holes. But with my conversations with Bob at Softopper . I would have no reason to suspect any miss alignment and you might save yourself a chunk of work by confirming with Softopper those whole locations based on the hard top your blazer came with .
I think the softopper is a great product and with the Header it really makes the up and down efforts simplified. I gave even run around as a "t" top configuration The part is easily removed with nuts or I had a friend turn down and tap out aluminum shaft and knurled the end and he made a clearance cut to provide clearance of the visor arm coming into contact.( Picture below)
Old 11-16-2015, 07:24 PM   #292
robs71k5
K5drive
robs71k5's Avatar
The snap parts i used to install on Header leading edge Name:  image.jpg
Hope this everyone's install came out as nice as mine or better
Old 11-16-2015, 07:54 PM   #293
CTENTA1
Registered 1971 K5
Originally Posted by robs71k5 View Post
The snap parts i used to install on Header leading edge Attachment 1467967
Did you get my PM about buying one?
Old 11-17-2015, 04:27 PM   #294
robs71k5
K5drive
robs71k5's Avatar
Yes I certainly did. I believe the next batch that comes in your name on one. As I said before it's slow but these parts are individually hand laid but I do hope to have one for everyone that has requested. I also have a second mold nearly developed. So we can meet the demand.
Old 11-18-2015, 12:36 PM   #295
timski69gmc
Package received in good order. Thanks Rob.
Wish I wasn't waiting until spring to install it.
Old 11-18-2015, 08:37 PM   #296
CTENTA1
Registered 1971 K5
Ok, Thank you!
Old 11-19-2015, 02:28 PM   #297
PGG
What is the cost and how long would it take for me to get one?
How do we pay etc? Thanks PG
PGG is offline   Reply With Quote
Old 11-21-2015, 01:02 AM   #298
colgad
colgad's Avatar
Not sure I understand what you are trying to explain here. Could you post a picture of where you are using it.
thanks
Dave
Old 11-23-2015, 01:25 PM   #299
CTENTA1
Registered 1971 K5
Payment sent.
Old 11-23-2015, 08:35 PM   #300
smbrouss70
smbrouss70's Avatar
I received mine today, the part looks very nice and had no damage, but one end of the shipping tube was completely open when it got delivered. I just wanted to let you know so that maybe the ends of the tube can be secured a little better so that nobody gets a broken or missing piece.
Thanks again for doing this for us Rob, I know it puts a huge burden on you, but I am so glad that I don't have to drill into my perfect original paint windshield frame!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
