Old 09-11-2017, 11:33 PM   #276
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 86 chevy crew cab 12 valve swap
Wow, great job on all of that! That sure was a lot of work but that should be a great side income for you to help off set this horrid dry no crop producing weather the entire western half of the country got. I thought about you last week when those fires were all out west hoping you were no where near any of them!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-27-2019, 01:22 PM   #277
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Hope this thread revives again, its a cool build. Any updates?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 07-08-2021, 12:25 AM   #278
Ford Assassin
Ford Assassin's Avatar
2.5 year bump....
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 07-14-2021, 05:12 PM   #279
84chevyguyid
Hey, still alive Havent worked on the crew cab for quite a while. I did blow up the two low tires on it recently. The next steps to do with it are pull the power steering pump off and see if I can get one that is the right specs for the hydroboost system so I dont blow the accumulator off the booster again, and replace the new booster that it blew apart. I need to get a muffler and finish the exhaust system off again. Cant decide if I should paint it while its somewhat apart or just let it ride for now, wouldnt take much to finish stripping the trim off at this point. Still have some wiring to finish, rear seat brackets to finish up. Wiring for the sound system to get in then I could get the carpet in. Need to pull the headliner and recover that then I can reinstall the back window. I was going to put that shark fin antenna on the roof but I think I might put a slide in camper on it one day so now I dont want anything sticking up on the roof. Still lots to do....
84chevyguyid is offline   Reply With Quote
Old 07-17-2021, 05:02 AM   #280
Dieselwrencher
I'm glad to see you're still around and kicking. How's my vette?
Ryan
Old 07-17-2021, 06:39 PM   #281
84chevyguyid
The vette is good, still adding a little excitement to passenger's lives one ride at a time.
https://youtu.be/ZL3rg_70W3o
https://youtu.be/UI_CxqlkfAI
Old 07-22-2021, 10:29 AM   #282
Dieselwrencher
Awesome! I'm glad to see you getting it out and tearing up the roads with it! My old vette got back out this year. There's a list of changes that need to get done so it can be driven farther and more comfortably. Just need more time.
https://www.youtube.com/watch?v=ZVcazK_hg-E
Ryan
Old 01-10-2022, 05:45 PM   #283
84chevyguyid
So been searching out a solution to my power steering problem. I did come across a place that would build a trw power steering pump to the gpm and psi I need for the chevy system but when I got it here the ports on it are in the wrong places and wont clear the frame/crossmember so going to try dropping the pressure on the ZF pump and see if it will work. I bought a new hydrobooster from a place in CA called Vanco. He says he ports them and will handle 4.5 to 5 gpm as compared to the stock chevy pump spec of 3.5. My pump puts out 4.5 so if I can get the pressure down to 1500 psi maybe it will work for me. Just hate to find out it wont and blow my new 600 booster apart like I did the last one.
