Old 08-04-2014, 11:09 PM   #276
amueller454
amueller454's Avatar
Re: 61K10 build
man this thing is getting cooler and cooler. love it man
1960 short bed fleetside factory 4x4
1960 panel 454 NV4500 Daily driver
1961 Short Bed BBW Fleetside 5.3 th400 swap in process
amueller454 is offline   Reply With Quote
Old 08-07-2014, 01:01 PM   #277
61K10
61K10's Avatar
Re: 61K10 build
been doing little stuff. changed my pitman arm back to the stock 4x4 one as the droped one was hitting the spring ft clamp. there is only about 1" difference anyway. put on a steering stabilizer like the one that came with the tk--old school type.
remounted my CB farther back under the dash--looks better now.
still no seat? I guess i shouldn't have said i wasn't in a hurry lol!
have to get back on my bed bolts
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-07-2014, 05:03 PM   #278
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Mighty Fine, Mighty Fine...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-08-2014, 12:07 PM   #279
61K10
61K10's Avatar
Re: 61K10 build
Thanks Randy. Glad to see you have your eng up and running again. you're getting there.
1961 chevy K10
Old 08-08-2014, 09:57 PM   #280
Jeff La
Re: 61K10 build
Interior looks great, truck is getting close.
Jeff La is offline   Reply With Quote
Old 08-12-2014, 01:51 PM   #281
bhc41051
bhc41051's Avatar
Re: 61K10 build
First let me say your truck is looking awesome! could you have a look at your rear parking brake cables? are they similar to this one? or does the cable mount to the brake backing plate with two bolts?
bhc41051 is offline   Reply With Quote
Old 08-13-2014, 01:42 PM   #282
61K10
61K10's Avatar
Re: 61K10 build
bhc---here are pic's of my old one's. they have the clip's on the backing plate end. my old ones were frozen, couldn't get them free after soaking them in diesel. so inline tube made some new ones. and the one in your pic looks like mine.
1961 chevy K10
Old 08-13-2014, 03:39 PM   #283
bhc41051
bhc41051's Avatar
Re: 61K10 build
Thank you for the reply and pics, would you have the part number from Inline tube? I tried for three weeks to have them make me a set, they told me they were having trouble in the custom cable department and would not be making anymore custom cables. So I called Metro Cables. I've been calling and emailing them for six weeks. All they have been able to do is charge my credit card $187 and tell me they would ship the cables in the next day or two. If I had the cables I could finish the rear brakes, bleed the brakes and clutch and my little project would be drivable.
Old 08-13-2014, 03:53 PM   #284
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
http://www.ebay.com/itm/370622308584...84.m1423.l2649
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 08-14-2014, 10:26 AM   #285
bhc41051
bhc41051's Avatar
Re: 61K10 build
Wow.. Thanks Mitch! I've really been struggling trying to find these cables. I guess I couldn't see the forest for all the trees.
Old 08-14-2014, 10:35 AM   #286
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Hey Kimble.. Where's that seat at?
'62 Chevy K10
Old 08-14-2014, 01:31 PM   #287
61K10
61K10's Avatar
Re: 61K10 build
BEATS me. I am waiting till the 26th that will be 2 months. if not done will find someone else. working on my bed, bolts are a killer doing them by your self. defiantly harder than it looks. went and bought some longer bolts that helped a bunch. probably get the tailgate on when my wife's brother comes at the end of the month. Maybe the hood???
1961 chevy K10
Old 08-14-2014, 01:34 PM   #288
61K10
61K10's Avatar
Re: 61K10 build
bhc--they are cheaper on e-bay also. of course i didn't find out till after i bought mine. are long and short beds different length wise? mine were about 40 or so inches long.
1961 chevy K10
Old 08-16-2014, 01:49 AM   #289
bhc41051
bhc41051's Avatar
Re: 61K10 build
My truck is a short bed and my cables are around 40 inches, But the ends bolt to the backing plate instead of inserting like yours. As far as I can tell my truck was made up from a GMC and a Chevy both 4x4s. My rear end was a Dana 44, But my axles were really worn and the Dana drums are next to impossible to find. So I had to use a 12 bolt out of a 79 K10, I ground off the shock mounts and moved the spring perches out 1/2 inch. I knew my parking brake cables woudn't fit. I just assumed all of the trucks of that era used the same backing plates and I would have to have a custom made cable. That started two months of emails and phone calls to Inline tube and Metro Custom Cables trying to have a set made. Metro charged me $192 that included a 10% discount.
Old 08-16-2014, 09:41 AM   #290
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 61K10 build
The radio looks good in there!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 08-16-2014, 12:18 PM   #291
61K10
61K10's Avatar
Re: 61K10 build
bhc--did all 12b have the bolt on cables? maybe a find a different backing plate?
1961 chevy K10
Old 08-17-2014, 01:42 PM   #292
61K10
61K10's Avatar
Re: 61K10 build
fixed my brake hose problem. just drilled out the 3/8's threads and re-taped to 7/16-20.
1961 chevy K10
Old 08-17-2014, 09:04 PM   #293
bhc41051
bhc41051's Avatar
Re: 61K10 build
My cables came yesterday, fit perfect. I installed the rear brakes today. Very nice job on the wheel cylinders. Are those pipe threads or regular bolt threads? Do the hoses need those copper crush washers? I'm almost ready to start pouring brake fluid in this thing.
Old 08-17-2014, 09:32 PM   #294
61K10
61K10's Avatar
Re: 61K10 build
bhc--yes they do need the copper washers. I used a 7/16 reg tap. bolt threads.
1961 chevy K10
Old 08-19-2014, 01:41 PM   #295
61K10
61K10's Avatar
Re: 61K10 build
my truck is famous--lol
1961 chevy K10
Old 08-19-2014, 09:42 PM   #296
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 61K10 build
Lol!!!!!!!!
Old 08-20-2014, 12:32 PM   #297
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Are you or have you considered puting the cab marker lights on it, since it was a service truck? Just curious...
'62 Chevy K10
Old 08-20-2014, 12:38 PM   #298
61K10
61K10's Avatar
Re: 61K10 build
Mitch--no! I fixed so many holes on this tk I'm not making any more holes--lol
1961 chevy K10
Old 08-20-2014, 01:19 PM   #299
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
ha! I know what ya mean there. the p.o's sure like sheet metal screws, on these trucks.
'62 Chevy K10
Old 08-20-2014, 09:22 PM   #300
bhc41051
bhc41051's Avatar
Re: 61K10 build
I'm not a big fan of the 60-66 cab lights but here's four NOS on ebay http://www.ebay.com/itm/four-4-1960s...af5e5e&vxp=mtr
