Old 05-21-2015, 07:56 AM   #276
FamilyBowTie
Re: S10 Swap how to
When mocking up the cab and front sheet metal how much further can the cab be moved forward?
I have my cab at 2.1/8" as instructed but the wheels are too far forward in the front fenders. I would like to move the whole cab/front clip fwd about 1.5-2" to center the wheels. Are there any drawbacks to moving it fwd that much?
49 5 window on s10
http://67-72chevytrucks.com/vboard/s...d.php?t=671706
FamilyBowTie is offline   Reply With Quote
Old 05-21-2015, 08:22 AM   #277
T-P Auto
Re: S10 Swap how to
Familybowtie;
Do you have your motor set in place:
Then move cab forward till you have1.5 inch of clearness on the dist.
If useing a dist engine.
T-P Auto
T-P Auto is offline   Reply With Quote
Old 05-21-2015, 08:25 AM   #278
FamilyBowTie
Re: S10 Swap how to
Originally Posted by T-P Auto View Post
Familybowtie;
T-P Auto
Motor (5.7L)is in but needs to be moved back about 4-5". Wanted to see if there was any issues with moving the cab fwd. I haven't cut the front frame horns yet.
49 5 window on s10
Old 05-21-2015, 01:35 PM   #279
steve aleve
Re: S10 Swap how to
FamilyBowTie, Do you have any pics of the front wheels in the fenders? I think I am having the same issue but mine may not be as bad as 2" I can't tell. The reason I think this is because of how crowded the front of the tire is to the fender. hmm maybe its just because it's lower than before. Thoughts?
steve aleve is offline   Reply With Quote
Old 05-21-2015, 01:53 PM   #280
FamilyBowTie
Re: S10 Swap how to
Hey Steve,
This morning I measured with a piece of tape across the fender and a plumb bob and it was 1-3/8 to 1.5" fwd of center. I just came in from taking off the cab, grinding the tacks and moving the mounts fwd 1.25".
On 15" tires it looks like yours, not too bad but with 20" it really showed so I ended up just moving the mounts fwd. If I have any issues it should only be the rear end but I plan on a 4 link so I can adjust that pretty easy - I hope.
49 5 window on s10
Old 05-21-2015, 06:12 PM   #281
T-P Auto
Re: S10 Swap how to
Familtbowtie;
Have you cked the turn clearness also?
You look very low on your wheels.
I have like a 3.5" clearness from wheel to fender at top of fender.
I'm running 14" wheels.
CK out the "Frankenstine" build.
I also had my cab set 2" above the frame,but had to add 1.5" spacer to front cab mount to ge the fenders n hood to line up.
I was also like 4" back on my cab from the eng dist.
T-P Auto
Old 05-21-2015, 06:31 PM   #282
Garyhenrich
Re: S10 Swap how to
Skymags, just a reminder to confirm that the front of the front fenders is higher than the rear of the front fenders.
Garyhenrich is offline   Reply With Quote
Old 05-21-2015, 08:20 PM   #283
FamilyBowTie
Re: S10 Swap how to
Familtbowtie;
T-P Auto
Not my pics, those are SteveAleves. Mine looks like it is sitting too high but I haven't put the drop spindles on yet. I will try and get some pics this weekend once I get the front sheet metal in place.
49 5 window on s10
Old 05-21-2015, 08:43 PM   #284
SkeeterBilt
SkeeterBilt's Avatar
Re: S10 Swap how to
Stevealeve, truck looks good
SkeeterBilt is offline   Reply With Quote
Old 05-22-2015, 10:27 AM   #285
skymangs
skymangs's Avatar
Re: S10 Swap how to
Hey guys, sorry, I was out of the net till yesterday. Steve, how tall are your front tires? On Cecil I had time run New wheel spacers on the front to get turning clearance. I also radioed the front fenders a bit. The wheels won't be perfectly centered in the opening, but look good (like yours do)
Be careful moving the cab forward, with a small block the motor clearance is awful tight for a puller fan as it is. Bowtie, if you could send a pic that would be helpful, 20's are a ***** to get to fit right, but can be done. Also, put the grill on with a couple of bolts, the fenders spread a little, and make the wheel center look farther back. It is a noticeable difference! I should have brought that up earlier in this thread (sorry).
Gary. Will snap a pic and a measurement today.
skymangs is offline   Reply With Quote
Old 05-22-2015, 11:06 AM   #286
steve aleve
Re: S10 Swap how to
Thanks!! I am running P225 70 R15 in the front and P235 70 R15 in the rear. I think the front tire measures about 27.5 inches in diameter and just under 6.5 inches wide. I have 2 inch spacers on them and once I have the hood on I will be able to align the fenders properly to check my turning. Fingers crossed. Do you have any pics of the radiused fenders? I may have to go this route.
Old 05-22-2015, 05:36 PM   #287
Garyhenrich
Re: S10 Swap how to
Thanks Skymags. I have been pushing the radiator up and down to see what looks good. It appears that using your body mount spec's the front and rear of the front fenders should be about the same height off the ground, but just wanted to confirm if yours are even also. I'll weld mine in place if it is close to matching yours.
Old 05-22-2015, 09:05 PM   #288
FamilyBowTie
Re: S10 Swap how to
I got the front sheet metal on the cab using SkyMags mount measurements but I looks high to me. I don't have the drop spindles on yet I am hoping that will bring it down. Thoughts please.
49 5 window on s10
Old 05-22-2015, 10:51 PM   #289
SkeeterBilt
Re: S10 Swap how to
did you use the plans to make the running board parrell with the bottom of the frame? im doin the same.
Old 05-23-2015, 09:43 PM   #290
Sim6
Sim6's Avatar
Re: S10 Swap how to
Is the motor and trans in?
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 05-23-2015, 11:10 PM   #291
Steveareno
Re: S10 Swap how to
Hey Skymangs,
This may have been asked already and if it has I apologize for wasting your time with it again, but have you measured or eyeballed a newer Colorado or Canyon chassis for this mod? Excellent write-up, many thanks for your time and trouble.
Steveareno is offline   Reply With Quote
Old 05-23-2015, 11:15 PM   #292
FamilyBowTie
Re: S10 Swap how to
Motor is but needs to be moved back 4-5 inches, trans is out and will go back in next time I remove the cab.
I got the bed on today but it needs to be dropped 2 inches, I will get a pic tomorrow.
49 5 window on s10
Old 05-23-2015, 11:33 PM   #293
Sim6
Sim6's Avatar
Re: S10 Swap how to
Ya, sorry about that, I just saw your earlier post.
Old 05-25-2015, 08:34 PM   #294
skymangs
skymangs's Avatar
Re: S10 Swap how to
Yes, front fenders should be about even. Maybey a smidge higher depending on how much rake you have in your suspension.
I haven't looked into the Colorado chassis. Never even considered it. May have to experiment at a future date.
Old 05-25-2015, 08:55 PM   #295
FamilyBowTie
Re: S10 Swap how to
Here is a pic with the bed on, its not mounted yet but it will drop another 1.5" when I do. Seems high but there is no weight other than the motor.
Started my build thread also.
49 5 window on s10
Old 05-26-2015, 01:22 AM   #296
skymangs
skymangs's Avatar
Re: S10 Swap how to
Looks pretty good. Even when you have all the weight on it, the suspension will sink another 1/2" or so after a couple weeks of driving it. That seems to be a pretty reliable figure. 15 or so of these builds so far, and you get to know how much drop to expect.
Old 05-26-2015, 05:23 PM   #297
T Hilde
Re: S10 Swap how to
Front track width looks close stock and has rack & pinion. I couldn't find one cheap enough at the time.
T Hilde is offline   Reply With Quote
Old 05-27-2015, 08:59 AM   #298
skymangs
skymangs's Avatar
Re: S10 Swap how to
Nice, what kind of wheel base do they have?
Old 05-27-2015, 01:07 PM   #299
T Hilde
Re: S10 Swap how to
Per wikipedia,
Regular cab 111.2 in
Extended cab 126 in
Crew cab 120 in
Old 05-27-2015, 01:42 PM   #300
burger
Re: S10 Swap how to
Does anyone have experience doing this with a 4x4 S10?
burger is offline   Reply With Quote
