11-13-2022, 02:16 PM | #276 |
Proprietor of Dale's Corner
Re: project "C10 Fever" (68 factory black 396 swb)
Looks great
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
12-25-2022, 08:01 PM | #277 |
Made my seat track connecting rod today welding up a couple 3/16" rods. Tried to duplicate the factory setup as close as possible...
Should get the seat installed tomorrow, and start installing the fenders and grille.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
12-25-2022, 08:19 PM | #278 |
That black and red looks so sharp. Almost wants to make me paint mine that way instead of red on red. Nice work.
12-26-2022, 04:17 PM | #279 |
I agree. GM did some great things back then.
07-30-2023, 08:48 PM | #280 |
This truck deserves more attention than I’ve been giving it. I just ran out of steam.
My 11-yo daughter is really wanting to drive it when she turns 16, so we decided we would work together to get it across the finish line. It’s sooo close… Today we installed the headlamps, wipers (OEM from the board that I buffed up), and bumper brackets. More to come soon hopefully.
07-31-2023, 01:36 AM | #281 |
I got the inner fenders loosely installed.
Then I remembered this problem with the lower fender mounts. I am thinking I will try and see if I can redo what I removed. If anyone has any advice, I’m all ears. It’s the same on both sides. I know the correct repair is to replace the pillars, but I am not ready for that project. Before I disassembled the front end, it had these large concave washers installed by the PO, something like below.
07-31-2023, 01:39 AM | #282 |
I do have these, I could try to carefully cut through just the outer layer of sheet metal, just wide enough to bolt these in. I think that will be a better interim solution.
09-01-2023, 11:44 PM | #283 |
I got the fenders and grille bolted up loose today. I think the body lines will be ok for now without shimming the body and core support mounts.
10-15-2023, 06:05 PM | #284 |
10-15-2023, 09:35 PM | #285 | |
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
10-16-2023, 05:32 PM | #286 | |
Active Member
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
10-16-2023, 06:12 PM | #287 |
Love it!! The fact that your daughter is wanting help, even better!
10-17-2023, 01:46 AM | #288 |
Thanks guys
10-17-2023, 09:20 AM | #289 |
Sounds good!
10-17-2023, 09:30 AM | #290 |
Potato potato potato.....
10-20-2023, 09:02 AM | #291 |
Sounds like it wants to beat up a F@rD!!!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
10-22-2023, 11:41 PM | #292 |
Sounds good. I like the SS caps. What wheels did you use?
10-23-2023, 12:16 AM | #293 |
Thanks. These are 15” wheel vintiques series 62, custom backspace.
04-13-2024, 10:54 PM | #294 |
Love this truck! Nice job
And awesome to see you involving your kids.
1969 C10 Shortbed Wanted (pm me): - Pair of 275/60/15 tires |
04-13-2024, 11:47 PM | #295 |
Thanks!
04-26-2024, 02:09 AM | #296 |
Your interior looks nice! Now I know what mine will look like since it also came from the factory in the same colors but mine did not have AC and mine will have cloth inserts in the bench seats.
Good job! |
04-26-2024, 02:25 AM | #297 |
Thanks!
Mine came with fawn interior originally but I like the red much better. I decided since I’m not going 100% factory I would make the seat match the door panels rather than the cloth inserts.
04-26-2024, 09:46 AM | #298 |
I'm assuming you had to lengthen the front wiring harness to run the headlight wiring inside of the front fender? Did you just splice them in or replace all wiring new? I've been thinking about doing this, it's a much cleaner look.
Nice work on your daughters truck! Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
05-04-2024, 01:12 AM | #299 |
New goodies…
05-04-2024, 01:14 AM | #300 | |
Nope the harness is good as-is, other than I need to add in side marker lights
