Old 07-02-2020, 12:43 AM   #276
joedoh
joedoh's Avatar
Re: Starting a 52 Chevy 3100 Project.
gorgeous!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-02-2020, 08:05 AM   #277
8man
Looking very nice!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 07-02-2020, 08:42 AM   #278
Desert1957
Desert1957's Avatar
I love this build. Your build has saved me a lot of time planning my project , Thank you for such detailed post.
I have been amazed between You , Joedoh , Hussey , Skymags , what you have contributed to this forum.
Desert
Desert1957 is offline   Reply With Quote
Old 07-02-2020, 11:44 AM   #279
layinrocker65
layinrocker65's Avatar
What headliner did you go with and how was the install?
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 07-02-2020, 11:56 AM   #280
Tempest67
Tempest67's Avatar
looks really good
Tempest67 is offline   Reply With Quote
Old 07-02-2020, 01:28 PM   #281
28TudorAZ
28TudorAZ's Avatar
Originally Posted by joedoh View Post
gorgeous!
Thanks!!!!
Originally Posted by 8man View Post
Looking very nice!
Thanks!!!!
Thanks!!!! They have all helped me as well.
I went with the stock cardboard one. It only took an hour to put it on. I called around to upholstery shops and the cheapest I found was $300 to do a headliner. It was around $65 because I had to buy the center support but if you have that its only $35. You cant beat that. It would not be difficult to glue some upholstery to it as well. I didn't need anything fancy.
Originally Posted by Tempest67 View Post
looks really good
Thanks!!!!
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
28TudorAZ is offline   Reply With Quote
Old 07-03-2020, 08:10 PM   #282
Desert1957
Desert1957's Avatar
Originally Posted by 28TudorAZ View Post
So everything works as expected when I swapped the wires. I already tested everything. Its going to be a huge pain to pull the fuse panel and swap the wires. Oh well its gotta be done.
Sorry, can you guys explain this wiring problem? Which aftermarket fuse boxes come wired backwards?
Desert
Old 07-03-2020, 11:48 PM   #283
28TudorAZ
28TudorAZ's Avatar
The flasher was not working and would just stay on when I used the turn signals. I am using the EZwire wiring harness with the flasher unit that hooks directly to the fuse block. The wires for the flasher must be switched on the fuse block. I don't think this would usually matter but I am running all LED lights. I also have the flasher unit for LED lights.
Old 07-04-2020, 10:55 PM   #284
28TudorAZ
28TudorAZ's Avatar
Happy 4th of July!!!!! Thank you to all that have fought for our freedom.
Old 07-05-2020, 10:35 PM   #285
28TudorAZ
28TudorAZ's Avatar
Wired up the stereo and the 6x9 and powered 10" sub woofer. The 6 1/2 speakers in kick panels will hopefully be there this week. Sounds pretty good considering it is missing the 2 front speakers. I guess my next task is the door windows. I am not looking forward to that task.
Old 07-05-2020, 11:03 PM   #286
joedoh
joedoh's Avatar
looking good! I bought a set of QM MB Quart speakers that are 1/8th a sphere enclosed I figure I will put in the kicks of a truck some day. I had two sets and like a dummy I sold one set, I dont even remember to who! They only made em for a minute, and you never see them for sale any more.
I bet your truck sounds good, thats a fine looking 4th of july pic too!
Old 07-06-2020, 07:40 AM   #287
gigamanx
Does the truck only have classic rock stations?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 07-06-2020, 08:22 AM   #288
8man
I do like your dash. The vents and radio worked great.
8man-aka Robert
Old 07-06-2020, 01:35 PM   #289
28TudorAZ
28TudorAZ's Avatar
Funny how as you get older you cannot find stuff that you really like 5 years later. It sounds pretty good but definitely needs to the front speakers. I bought a powered 10" subwoofer for $100 and it sounds pretty good.
I will since its going to my dad but while channel surfing some bumping might have been coming from my garage.
I almost did a newer style double din stereo but glad I did not. I am pretty happy with it. When I put the vents in I tried to mimick the gauge placement. I actually plan to go vintage air so there will be 4 old style matching knobs next to the ignition under the Chevrolet.
Old 07-06-2020, 06:16 PM   #290
twinshadows
Hi 28Tudor . . . . 1st off - - - a Very Nice Truck .
Great build from start to Driving ; and for one of the best "Causes"...…
your Dad , good on you.
Ok . . . this is just info : I have installed all LED lights on my
Nova ; installed a 'NAPA flasher # 262 , it made my lights work.
But, they would flash 'kinda slow' . . . then, I found this Flasher :
….. AUDEW LED flasher (and its adjustable - rate)
https://www.amazon.com/dp/B011BTMDQM...novasitecon-20
(better that adding 'load resistors' , to your lights) . . . and, for my LED's
it solved my issue - - - could work for you also, and may be just that simple , as changing your flasher (instead of messing with your wires).
Then, it's cheap enough . . . (was # 12.00 , when I bought it).
Here's my point - - - works great - - - and, I never adjusted a thing
just install . . . like 2 years ago . (I like things that work as
advertised) .
again , very nice truck & . . . . . MAN, it was HOT in Scottsdale on th'
4th . . . . Have a nice day & stay safe …………….
jim
twinshadows is offline   Reply With Quote
Old 07-06-2020, 07:45 PM   #291
28TudorAZ
28TudorAZ's Avatar
advertised) .
jim
Thanks!!! As far as the flasher it works great with the wires switched. I would assume it would still have the same issue with an adjustable one. I will probably just swap the wires at some point but thanks for the info.
On another note I took it to be aligned today. They said it was near perfect and did not need to be aligned and did not charge me. I aligned it with a tape measure. The did say the idler arm is bad though. It is brand new so I guess I will be swapping that out.
Old 07-23-2020, 12:14 AM   #292
28TudorAZ
28TudorAZ's Avatar
I created the mounts for the rear bumper. 3 inch square tubing.
Old 07-27-2020, 08:54 PM   #293
28TudorAZ
28TudorAZ's Avatar
Here is the final bumper mounting.
Old 07-27-2020, 08:56 PM   #294
28TudorAZ
28TudorAZ's Avatar
I also mounted the A/C controls. I like the way this turned out.
Old 07-27-2020, 09:53 PM   #295
joedoh
joedoh's Avatar
great work! i like how the dash came out
Old 07-27-2020, 11:20 PM   #296
oldman3
oldman3's Avatar
Both came out great...Jim
oldman3 is offline   Reply With Quote
Old 07-28-2020, 07:10 AM   #297
Zippi
Zippi's Avatar
Just love the Patina look of your truck. Can't remember if you said or not but was there any other lettering on the door besides what looks like an eagle?
If you can't fix it with duct tape, it's an electrical problem.
1949 5 Window 3100
https://zippi6.wixsite.com/adtruck
Zippi is offline   Reply With Quote
Old 07-28-2020, 09:25 AM   #298
Tempest67
Tempest67's Avatar
wow, both the dash and the rear bumper looks excellent.
I am not sure what to do with a rear bumper on mine, but you have me thinking....
Thanks for the pics, and great looking truck
Old 07-30-2020, 01:38 AM   #299
28TudorAZ
28TudorAZ's Avatar
Thanks. I am pretty happy with it. Definitely worth the extra $50 in knobs. Cant wait to get the actual A/C installed.
Thanks!!!!
Thanks!!! Yeah I was torn whether to put a bumper on or not but I am glad I did. I have a receiver hitch I am going to put on but have to get the exaust moved a little toward the front for it to not to hit it.
Thanks!!! It says Eagle spirit. I would eventually like to find an artist to paint it the way I really want it. Here is a pic.
Old 08-08-2020, 12:58 PM   #300
28TudorAZ
28TudorAZ's Avatar
Took these the other day.
