Old 01-17-2020, 12:57 PM   #276
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: 1971 Stepside LS Build
ou've got to be getting very close to "drive" time on this build???
Good observation fine sir. I have to finish the following:
1. Complete brake line bending and install
2. Bleed brakes
3. Brake pedal install and modification for booster attachment
4. Gear oil put in rear end
5. Drive shaft painted and secured
6. Complete steering wheel install
7. Check all steering torque settings (really everything under the truck)
8. Hope it all works
I made this list since you got me thinking about it. Wonder what I am missing. Oh, I need good weather for sure. Probably be April before I actually get to do the maiden voyage at the pace I'm going.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-22-2020, 11:08 AM   #277
1971Stepside
Almost Satisfied
Shifted gears to work on the bed wood. The shop I bought the wood from is going to CNC the bed strip grooves in it this week.
Old 01-22-2020, 11:42 AM   #278
MDPotter
MDPotter's Avatar
What kind of wood and finish are you going with?
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 01-22-2020, 01:16 PM   #279
1971Stepside
Almost Satisfied
It is hard maple. I will do a poly finish on it to keep it light in color.
Old 01-24-2020, 12:16 PM   #280
1971Stepside
Almost Satisfied
A few more items to keep me busy this weekend.
Old 01-24-2020, 12:31 PM   #281
MDPotter
MDPotter's Avatar
Here we go with the Vintage Air install!
What compressor bracket and belt did you end up buying?
Let us know how it goes!
Old 01-24-2020, 01:24 PM   #282
1971Stepside
Almost Satisfied
I used Dirty Dingo Sanden 508 bracket kit for the compressor. If you are using the larger alternator it takes the Gates K061120 belt. If you are using a stock small alternator or other configuration look on the Dingo website for this kit and look at the installation instructions. It list all the part numbers for the belts.
Old 01-27-2020, 10:19 AM   #283
1971Stepside
Almost Satisfied
Had a full weekend to work on the truck. Spent Saturday at the wood shop cutting the boards for the bed floor. Real happy with the way they turned out. Used hard maple that I will simply put poly on after it is all sanded. On Sunday, we worked on brake lines. Feels like I'm getting closer.
Old 01-27-2020, 10:21 AM   #284
1971Stepside
Almost Satisfied
more pics
Old 01-27-2020, 10:36 AM   #285
MDPotter
MDPotter's Avatar
You'll enjoy looking at your bed knowing that you did the woodwork yourself.
Are those the nicop lines? They look nice! What did you use to make the flares?
Old 01-27-2020, 11:34 AM   #286
mcm1209
mcm1209's Avatar
Awesome build. I'm about to start on my dream truck my-self. But starting with a frame and go from there. Keep up the good work!!
mcm1209 is offline   Reply With Quote
Old 01-27-2020, 12:45 PM   #287
1971Stepside
Almost Satisfied
Yes, Nicopp lines. Real easy to work with and flare.
Thank you. My advice for you is to have a good plan and lots of money
Old 01-27-2020, 03:08 PM   #288
TA_C10
TA_C10's Avatar
Looking great man. The vintage air kit really is easy to install. My only advice(if someone asked) is to read all the instructions before you begin. Then put out on paper (especially the wiring) because there are some things you may want to customize/integrate instead of going VA route. I wish I would have known about the piping going through firewall. I would have rather gone with the bulkhead unit instead of VA stock using grommets.
Wood looks awesome. Ready to see the finished product!
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 01-28-2020, 12:35 AM   #289
sprint_9
sprint_9's Avatar
Great looking work.
Judging by some of your garage decor you probably wont get much done on the truck this Sunday.
sprint_9 is offline   Reply With Quote
Old 01-28-2020, 10:11 AM   #290
1971Stepside
Almost Satisfied
It's Tuesday and I am already nervous for the game! It's crazy to finally have the Chiefs in a Super Bowl. Hope they can bring home a win. No work will be done on the truck all weekend and especially Monday after...
Old 01-28-2020, 01:36 PM   #291
TA_C10
TA_C10's Avatar
"It's only money".
Old 01-28-2020, 03:46 PM   #292
1971Stepside
Almost Satisfied
This AC puzzle is going to be fun (insert sarcasm). I bought the unit for the interior in 2005. It is the cable version VA offered and uses my stock AC controls. The downside is making connections from the evaporator to the firewall is going to be a challenge for room. I bought the VA hose kit, but I am finding that very few of the fittings will work for what I need to do. I'm not sure I like the compressor fittings and the service ports. Going to be a lot of trial and error.
Old 01-29-2020, 12:49 AM   #293
TA_C10
TA_C10's Avatar
Yeah I feel your pain on this. I ended up heading down to the hose supply and rummaging through their parts bins to finally find the angles and fittings I needed to make it all work. Still wasn't how I would have done it if I went full custom but it's gonna be just fine for a daily. But as nice as your doing your truck, if I may, I would go buy my own hard lines and bend them just the way I wanted them. Then do the fittings just how I wanted too.
I've seen some pretty nice setups on here, hidden and not hidden. Good luck sir.
"It's only money".
Old 02-04-2020, 06:57 PM   #294
1971Stepside
Almost Satisfied
First off....GO CHIEFS!!! Amazing experience to have your team finally make it and then win.
I said I wasn't going to work on the truck, but as I paced the garage waiting for the game to start I decided WTH, let's drill holes in the firewall. I have been holding out on this because I was a little nervous about getting the location right and trying to make all the interior hoses fit. I have a brand new Vintage Air evaporator...but it is from 2005!! So, it isn't like the new ones. So, with a good stout in one hand and a drill in the other I went for it. Got lucky! It all fits.
Old 02-04-2020, 06:59 PM   #295
1971Stepside
Almost Satisfied
I took the day off yesterday to recover from my Super Bowl experience. I ended up working on the front brake lines. Have some more tweaking to do, but will do that once the body comes off for paint.
Old 02-05-2020, 09:50 AM   #296
mcm1209
mcm1209's Avatar
Is that a bolt and nut holding the clamp for the brake line? Or a nut rivet?
Old 02-05-2020, 10:09 AM   #297
1971Stepside
Almost Satisfied
A nut and bolt
Old 02-05-2020, 02:05 PM   #298
KMC3420
KMC3420's Avatar
I assume you are going to just run one brake line down from the Wilwood prop valve to a T, then to both front calipers. The prop valve has provisions for running individual lines to both front wheels, but I'm unsure why it would be better than running a single line?
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 02-05-2020, 04:25 PM   #299
1971Stepside
Almost Satisfied
I ran two lines. One for the rear and one for the front. The front line hits that t-block you see in the above picture. It then runs to both front lines from there. That first pic is a little tricky in that the line to the passenger front brake is not installed yet.
Old 02-05-2020, 05:13 PM   #300
MDPotter
MDPotter's Avatar
Those brake lines look great. You must have had a pretty good day Sunday!
