Closed Thread
Old 12-07-2015, 10:20 AM   #2976
73737373
Re: What did you do to your truck today? Chapter II
"Restored" my driver side door on my 1970 GMC. Removed door panel. Washed out inside of the lower door w/Dawn, brush and rinse. Blow dry w/air hose. Remove upper/lower door trim, door handle, mirror, door lock and "custom" emblem. Wet sand door (lower inside and the entire outside) w/1500. Buff w/Wizard compound; wax, buff, wax, wax, buff... Clean up "Custom" badge, door handle and window roll up handle w/toothbrush and Barkeeper's Friend. Used Dremel to buff the door/key lock cylinder (sweet). Used heat gun to remove old woodgrain trim and replaced w/new...looks great. Had to hammer and dolly a couple of dents in it, also. Put it all back together except for the lower trim before it got too dark. Did not put the door panel back on because there's significant rust behind the vinyl covering...so looking for one of those. Found 3 metal passenger sides in the barn, but no driver.....Absolutely wonderful late fall day in OK, had Christmas music playing all day...was in a good place.
73737373 is offline
Old 12-07-2015, 12:53 PM   #2977
Bowtiguy
Bowtiguy's Avatar
Got my "custom" New Vintage 1939 series gauge cluster all wired up and installed. I'm MUCH happier with the LED backlighting of these gauges vs. their perimeter bulb back lit 1940 series with curved lens.
Bowtiguy is offline
Old 12-07-2015, 04:53 PM   #2978
kilrcady
wow really like it,$$$
kilrcady is offline
Old 12-07-2015, 04:53 PM   #2979
kilrcady
wow really like it$$$
kilrcady is offline
Old 12-07-2015, 05:18 PM   #2980
Bowtiguy
Bowtiguy's Avatar
They are actually a touch cheaper than Dakota digital VHX gauges ( which I really don't care for). Their smaller accessory gauges are much larger and easier to read in a C10.
They have several styles. Just make sure the style you like is the L.E.D. backlit Gen II.
http://www.newvintageusa.com/directfit.html
I had a long lunch so I went out for a drive. Love ColoRADo, 12/7 and I'll be driving the truck everyday this week while tweaking the suspension & EFi tune at night.
Bowtiguy is offline
Old 12-07-2015, 05:31 PM   #2981
slowcpe
slowcpe's Avatar
I like those gauges! Very nice.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline
Old 12-07-2015, 05:44 PM   #2982
Metaldoc
Metaldoc's Avatar
Looks great! and what's that cover piece under the dash, it hides part of the E-brake handle? Is that factory or made?
Metaldoc is offline
Old 12-07-2015, 08:23 PM   #2983
vidman
vidman's Avatar
Originally Posted by ekgguy View Post
Are those newer chevy seats that have been cut down?
They are out of a 2007 Tahoe. All electric, I removed the headrests and the air bags and the foam was replaced with foam from a 2005 Buick Rainier. he cut the foam a little here and there to kind of make them a somewhat custom set.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 12-08-2015, 06:51 PM   #2984
Synestran
Put my front bumper on to replace the 2x6s that the previous owner had on the front. Looks a lot better now =]
Synestran is offline
Old 12-12-2015, 08:44 PM   #2985
Possmguts
Possmguts's Avatar
Just seeing how some new shiny stuff is gonna fit..
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 12-12-2015, 09:01 PM   #2986
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Fits good. Yum.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 12-12-2015, 09:07 PM   #2987
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today? Chapter II
Installed billet E brake handle along with billet door locks!The little details!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 12-12-2015, 10:14 PM   #2988
XwalkerX
last night i was able to check a bunch of stuff off the list...
ring and pinion
diff bearings
diff seals
Eaton LSD
axle seals
brake shoes
wheel cylinders
front and rear sway bars with poly bushings
bled brakes
still have more stuff to take care of but im happy with the progress so far
she also got her first bath today...
XwalkerX is offline
Old 12-13-2015, 03:16 PM   #2989
BlacklandCamper
Wow. Done a lot that I haven't listed.
Got the oil pump sorted, engine is back together, ditched the flex fan and mounted some electrics, replaced the mechanical fuel pump with an electric, and got my YOM plates on.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Old 12-13-2015, 03:55 PM   #2990
DdowC20
I didn't do it today but earlier this week. About three weeks ago, the generator sheared a bolt and fell off my 70 C20. So, I upgraded the distributor to HEI and changed it over to an alternator. It's amazing how much better it runs. I think I need to rebuild my carburetor.
I ordered taillight buckets. The drivers side socket had come apart. Let's see, I have a rear wiring harness I got from LMC I am going to install when I get the taillight a bucket.
Now to line up the next upgrades. Always something.
DdowC20 is offline
Old 12-13-2015, 06:18 PM   #2991
88fordf150
88fordf150's Avatar
Started disassemble of my doors for sand blasting and skins.
Brad handshoe
88fordf150 is offline
Old 12-13-2015, 06:19 PM   #2992
88fordf150
88fordf150's Avatar
One more pic.
Brad handshoe
Old 12-13-2015, 10:04 PM   #2993
In The Ten Ring
I reasssembled the grill. *I wish I could get pics up, it looks really good.* I used the "rivet bolts" a fellow member suggested and those tightened right up.
I had to get help from dad with a punch to help align the holes for the replacement grill bracket but my old grill bracket lined right up. I hope the slight tweaking doesn't cause problems later.
I loaded up my car with all my remaining truck parts but I haven't taken those home yet.
In The Ten Ring is offline
Old 12-13-2015, 11:12 PM   #2994
Possmguts
Possmguts's Avatar
Stuck the doors and a fender on it so I have something to stare at while I collect more parts... I guess I can work on alignment and seams for now... Not sure I should even bother since I think Im gonna re-skin the doors. Skins are good thats on it but the inside of the doors need attention along with bottoms..
Old 12-13-2015, 11:56 PM   #2995
9teen69
9teen69's Avatar
That motor looks mean
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 12-14-2015, 12:01 AM   #2996
9teen69
9teen69's Avatar
Painted my wheel covers and cleaned the back side. They were pretty nasty. The SEM trim black paint is awesome, I used a small paint brush. New wheels and tires mounted also.
9teen69 is offline
Old 12-14-2015, 01:04 AM   #2997
In The Ten Ring
Could you park a little closer to your garage door?
I have to do with a small garage myself.
Old 12-14-2015, 09:59 AM   #2998
Possmguts
Possmguts's Avatar
Looks really nice bud...
Old 12-14-2015, 10:02 AM   #2999
Possmguts
Possmguts's Avatar
Thanks.. its just a small block but revs to 6000 rpm all day long. Cant wait to get it back in and fry some tires once again.
Old 12-14-2015, 10:10 AM   #3000
74baggedbug
Now I just gotta find the time to install these parts and a few others transmission related
74baggedbug is offline
Closed Thread
