08-17-2022, 07:35 PM | #3051 |
Re: What did you do to your truck today.The 3rd chapter
Nice paint job
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
08-17-2022, 07:53 PM | #3052 | |
Could be I was going by the GM part number below the grommet in the photo. It may still work. I just recognized that one from to many years workin on those engines.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
08-17-2022, 07:54 PM | #3053 |
Turned out great!
08-17-2022, 07:57 PM | #3054 |
Who Changed This?
Took the roll pin out of the shift lever. It should be a press fit, but it's a slip fit now, and slides down over time and use. Going up to the hardware store to buy a new one. If that doesn't work I'll just put in a bolt with a smooth shank.
08-17-2022, 08:38 PM | #3055 |
My golden has a big cotter pin in the shift lever . Been that way for two years
08-17-2022, 08:44 PM | #3056 |
Ended up buying a Dorman Pcv grommet has the right measurements and looks like the one I took off . Says it’s for a 68 250 ci
08-17-2022, 10:08 PM | #3057 |
Who Changed This?
Yeah, this pin slides down and then the shifter doesn't work- can't get it into park. I don't think that I have a cotter pin that big in my assortment o'stuff, though. I need some other stuff from the hardware store, so it isn't a one-time trip for something that trivial.
08-18-2022, 12:13 AM | #3058 |
70+ ( Old Skool Club )
Got my finished small block loaded into my Suburban for transport to the installers place.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-18-2022, 07:58 AM | #3059 |
Motor looks great
08-18-2022, 08:29 AM | #3060 |
Agreed, the engine looks great, I couldn't help but notice the 'Princess Auto' box there then realized you're in Canada too.
I don't think I've seen a 12 point bolt on the crank before.
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
08-18-2022, 09:59 AM | #3061 |
Nice hope this one works for ya.
08-18-2022, 10:16 AM | #3062 |
Finally got the floor finished and added new wheel wells. Next step when I recover is prep for paint. This is my daily driver so I did the bed while on the truck
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
08-18-2022, 10:47 AM | #3063 |
the engine does look great,good ole Princess Auto,i think you can find some of the P/A stuff in just about every car guy's place in this country?don't know where we'd be without them.i bought a box full of those 12 point aircraft bolts at a local war surplus store.i don't use them in anything that requires the correct bolts but they sure are slick on the hot rods and stuff.it would be scary to know what the gov't paid for them originally when you can buy them for a couple bucks a handful at the war surplus store.
08-18-2022, 06:49 PM | #3064 |
Todays fun . Fixed the brackets and put it back together . Waiting on the new alternator this one the bearing is going and I don’t have the time to rebuild it and it’s a 37 amp model to boot. Never seen this before a red piece of plastic in the oil dipstick . Thought it was orange paint and I boggered it up a little with the wire wheel .
08-18-2022, 06:52 PM | #3065 |
Screen shot from a video of it running shame we can’t upload directly from a phone or computer on this forum . The plastic filter is temporary have a metal one coming. The upper bracket I clamped onto a heavy piece of metal to help avoid any warpage it worked
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 08-18-2022 at 07:06 PM. |
08-18-2022, 08:09 PM | #3066 |
Installed the fuel tank in this frame-off. It was the "hardest" thing I had left to do.
For tips perhaps, I installed Classic Heartbeats grommet. Slid it on the filler neck with dish soap. Installed the tank loosely, with my son's help. Tried dish soap to get the grommet through, failed, probably not the soap. My son kept a blow drier on it while I started it from the inside, finished from the outside, not bad at all. All with a ball-end tool, I swear by them for installing grommets. NOS fuel cap or was until today. 71 is a rare cap, but I found one on the cheap long ago.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-19-2022, 02:13 AM | #3067 |
Location: Herculaneum MO (20 minutes south of St. Louis
I'm trying to understand this statement. I don't know of any other way to post pictures except directly from my phone.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
08-19-2022, 04:23 AM | #3068 |
I believe its an ARP Bolt..
08-19-2022, 08:47 AM | #3069 |
Great reading guys, love all the pics n tricks and all ...........
08-19-2022, 09:11 AM | #3070 |
Videos .
08-19-2022, 05:25 PM | #3071 |
Cleaned up the bed for the next car show this Saturday.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-19-2022, 05:33 PM | #3072 |
Wow Ned, great looking wood, well done.... good luck at the show!
08-19-2022, 06:09 PM | #3073 |
Ned that quarter sawn looks beautiful.
Found why temp gage wasn’t working on the 68 stepper as I retapped the harness . Wasn’t the sender wire was brittle and had green corrosion where it exited the harness . New wire and spliced where it was still good in the harness used solder and heat shrink . I retapped the entire harness mainly looking for other bad wires found none . Took out the leaky heater core and found a huge mouse/chipmunk nest
08-19-2022, 06:32 PM | #3074 |
08-20-2022, 09:45 AM | #3075 |
Finished up the install of the S10 washer bottle and pump. Don’t think the squirters ever worked that good.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
