Old 03-20-2016, 10:23 PM   #3201
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Valarius_Starchaser View Post
That ARP thread sealant will be good for any water jacket application and anything up to 550 degrees and is even good on fuel fittings
worth the few extra bucks to not send coolant into your engine "ask how I know"
thanks unfortunately I believe the tube was opened and is 80 years old so I just tossed it and will go with the Permatex high temp stuff, but it pays to know
Gregski is offline   Reply With Quote
Old 03-20-2016, 10:54 PM   #3202
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Originally Posted by Gregski View Post
lots of good info here, please elaborate on the "exhaust fasteners" comment, do you mean exhaust manifold bolts, or bolts further down like header collector bolts
All of the above. Exhaust bolts especially.
I use it on Spark Plug threads and on wheel lugs.
Be aware that torque specs in your service manuals are DRY not lubricated.
Torques need to be derated for anti-seize lubricated nuts and bolts. Permatex has charts for this.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-21-2016, 06:43 AM   #3203
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
Yes, use it on exhaust manifold/header bolts, collector bolts, spark plug threads, and especially any bolts threaded into your aluminum intake, thermostat housing bolts for example.
Jake Wade is offline   Reply With Quote
Old 03-21-2016, 09:13 PM   #3204
Troy Sr
Troy Sr's Avatar
Re: Restoring Rusty
You WILL be sorry if you don't replace all of the freeze plugs!!! They will let loose at the most inopportune time leaving you stranded or worse over heating your engine cracking your new heads. It's not worth it for a few bucks!!!
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 03-22-2016, 01:36 AM   #3205
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
picked up some white vinegar on the way home from work today and decided to use it to flush out the block from all the coolant rust, not sure if it was worth the $3.00 dollar investment, used boiling hot water and vinegar to do so
Old 03-22-2016, 01:38 AM   #3206
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
used painters tape to block off the cylinders to prevent vinegar and or water from splashing down upon them, then I was super careful
Old 03-22-2016, 01:40 AM   #3207
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I was literally replacing another freeze plug when I got your text in the garage, lol, but I must admit just as I expected this one was solid, there was absolutely no need for me to extract it
Old 03-22-2016, 01:47 AM   #3208
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
all in all, it was pretty much an all to do about nothing type a day, I worked my butt off but had not much to show for it
I cleaned bolts and washers and more bolts
1. oil pan bolts
2. timing cover bolts
3. water pump bolts
4. intake manifold bolts
5. valve cover bolts
6. crank gear bolts
7. fan bolts
8. fly wheel bolts
9. pressure plate bolts
10. bell housing bolts
I cleaned the oil pan, it may need a little touch up paint
I cleaned the timing cover, its ready for paint and a new seal
I Mickey Moused with the thermostat gasket on the new Vortec intake manifold with a razor blade, until no one was looking, then I called in the heavy artillery
trying to decide weather I clear this thing or paint it Cast Iron to match the heads and the block, its pourous and a pain to clean, I can only imagine it being a dirt and grime magnet in the truck
hey I cleaned my workbench.... again
Old 03-22-2016, 02:01 AM   #3209
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
So the plan is to put the engine back together on Saturday (that's 4 days from now), the original plan for March Madness was to have the engine back in the truck by then ie all in one month, but then I had my set back(s) with the Vortec heads, so I'm sure you'll forgive me for falling behind
so here's what's left to do in the crunch time
0. chase / tap all the bolt holes in the block
1. paint engine block
2. paint timing cover
3. paint valve covers
4. paint or clear coat the new(er) Vortec intake manifold
5. assembly the new(er) Vortec heads
6. gather up all the odd ball this and thats (expansion plugs, water pump gaskets, thermostat gasket, thread sealer, gasket maker, etc.)
I don't want to rush, but at the same time I don't want this engine sitting in two dozen pieces for eternity, I'm sure you know what I mean.
Though I work hard and do the best that I can, at 43 I learned that I rather have something completed at 80% quality, than strive for 100% perfection and never complete it!
Old 03-22-2016, 02:10 AM   #3210
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
saw this Lucas Engine Break-In oil Zinc additive at AutoZone today while buying new belts, seems like they don't carry engine break in oil any more, neither does Oh'Reallys
The GM Start-up and Break-in Procedures, Specifications 19210008 only say use 10w30 motor oil (non-synthetic) and nothing about Zinc
Old 03-22-2016, 07:55 AM   #3211
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: Restoring Rusty
That's because when GM made your engine the knuckle heads at the EPA didn't remove the zinc from our oil yet. You want something between 1000-1800ppm of zinc in your oil or you will wipe a cam very quickly. I simply run Rotella T6 diesel oil it has a naturally higher zinc content still at around 1100 and has been proven by third party hobbies the like us with oil analysis tests sent in to labs. It costs a little more then normal 5w30 but it sure beats trying to track down zinc additive and then trying to explain it to the kid behind the parts counter as you melt his brain trying to explain it to him.
Keep in mind though if this were a full rebuild you would want some straight 30 weight to help seat rings on first start up and to reduce initial bearing wear.
"Steps off soap box"
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 03-22-2016, 09:01 AM   #3212
enaberif
Re: Restoring Rusty
Not sure if its available in the US but up here in the great north we have a company who makes specialized oil for old vehicles and bikes. It is a 10w40 oil which is good for most cars and motorcycles but it contains large amounts of ZDDP to help the wiping of critical engine components.
http://www.camoils.com/
enaberif is offline   Reply With Quote
Old 03-22-2016, 09:01 AM   #3213
enaberif
Re: Restoring Rusty
** Duplicate **
Old 03-22-2016, 09:33 AM   #3214
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
True, but I am refering to the modern specs from the 350 HO Deluxe Engine (19210008) Specifications, revised on May 28th, 2014. That's why I posted that info, cause it surprised me.
Glad to hear another proponent of Rotella, as I hear arguments for and against it these days, I think rumors are they are fandangling with the formula, maybe at least in California. Well the Rotella T is on sale, and I had my heart set on it, not quite T6 but it might could work.
oh my god, did you have a camera on me this last time I was talking about just that with the pimple faced youth at Oh'Reallys, ha ha, nice kid, but inexperienced, he'll get there though, very open minded
you can step up on it as many times as you like bro, you are always very helpful, but next time I expect a mic drop when you do Step Off! and if this thing granades I'll know who to blame, jk, ha ha
Old 03-22-2016, 09:36 AM   #3215
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by enaberif View Post
** duplicate **
exterminate!
Old 03-22-2016, 10:17 AM   #3216
blazer2007
Re: Restoring Rusty
Joe gibbs have a good brake in oil,is it not sold in Cal.?
blazer2007 is offline   Reply With Quote
Old 03-22-2016, 10:45 AM   #3217
79sierra
79sierra's Avatar
Re: Restoring Rusty
All flat tappet cam engines need ZDDP oils, I use Royal Purple HPS 10W 30 in mine.
79sierra is offline   Reply With Quote
Old 03-22-2016, 11:02 AM   #3218
jwilson645
Re: Restoring Rusty
Brad Penn break in oil is what I'm using. Supposed to have the required ZDDP from what I've read and I've read A LOT on it.....
jwilson645 is offline   Reply With Quote
Old 03-22-2016, 12:39 PM   #3219
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
I will 3rd the Rotella. That is what I used for the engine in the Jeep last year.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-22-2016, 12:59 PM   #3220
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
I've been running synth since after break-in. Mobil1 10W30 with half a bottle of this added each oil change.
Amazon.com: ZDDPPlus ZDDP Engine Oil Additive... Amazon.com: ZDDPPlus ZDDP Engine Oil Additive...
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 03-22-2016, 12:59 PM   #3221
Valarius_Starchaser
Re: Restoring Rusty
That surprised me so much so that I looked in my GM performance book and it even says it comes with a flat tappet cam 24502476 I was hopefull it would be a roller COME ON GM
So I made a call to the GM machine and hopefully the right people will be contacted on the issue
"steps down drops mic"
"Orange Crush"
Old 03-22-2016, 04:49 PM   #3222
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
my buddy who used to run it in his old GTO said couple guys at two different shops said don't do it cause Diesel motor oils contain harmful detergents for gasoline engines, so the plot thickens
Old 03-22-2016, 04:52 PM   #3223
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
now I also heard you don't want to use a multi weight oil for the break in but should run a 30 weight instead, The Greg's head is about to explode
Old 03-22-2016, 05:19 PM   #3224
Valarius_Starchaser
Re: Restoring Rusty
Well your only breaking in the came so its not as "crucial" I have heard of guys with good success doing none straight weight 30 in a tight spot with fair results but I have never messed with it as I have always had it available and never have seen a need to risk it I found an alternative for you by the way greg if this one does "blow up" due to my attempted help
GM part number 19201333 I will cut you a deal buddy
"Orange Crush"
Old 03-22-2016, 05:49 PM   #3225
enaberif
Re: Restoring Rusty
Don't let your head expode. Just run 10w30 or 10w40 and let er run hard for 20 minutes
