09-21-2012, 02:06 PM | #301 |
67cheby
Re: Cheap Tricks
cant believe i missed all this , great tips and tricks !
09-21-2012, 02:31 PM | #302 |
Florida Edition
Re: Cheap Tricks
With your mad skills I'm sure you have a trick or two up your sleeve. BTW I love the color of your 67
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
09-21-2012, 02:54 PM | #303 |
67cheby
Re: Cheap Tricks
LOL, my only tricks are do it three times to get it right !! LOL, and learn from my mistakes ! I would think you would like my color a little !!
09-21-2012, 03:19 PM | #304 |
Re: Cheap Tricks
I know we all have had problems with cooling system after filling a new engine or after changing a T-stat or water pump with getting the air out so what I do is drill a 1/8th hole in the flange of the T-Stat to help bleed the air out.
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
09-22-2012, 01:13 PM | #305 |
Re: Cheap Tricks
Brake fluid is great for stripping paint off of plastic parts.
09-23-2012, 12:33 PM | #306 |
Re: Cheap Tricks
A lot of t-stats come with a bleeder hole now. I never remember which manufacturers have it.
68 GMC C2500 - 305 V6 - 4spd |
09-24-2012, 05:17 PM | #307 |
Re: Cheap Tricks
Use apeice of paper shop towl inside of sockets to hold nuts or bolts into sockets when putting them into tite or odd angle places. It keeps them from falling out.
http://www.cardomain.com/id/jmcleek |
09-24-2012, 05:36 PM | #308 |
Florida Edition
Re: Cheap Tricks
You can check your tstat by putting it in a pan of water on the stove. Should open at whatever its temp is. Check the water temp with a meat thermometer.
09-24-2012, 07:38 PM | #309 |
Re: Cheap Tricks
If I have to check it, I'll replace it. They are too cheap to use a questionable one. Parts are cheap. Time is expensive. Save time, save money.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
09-24-2012, 11:29 PM | #310 |
Re: Cheap Tricks
I've done that but using a piece of a rag
09-24-2012, 11:34 PM | #311 |
Re: Cheap Tricks
use a metric socket on a rounded off SAE nut or bolt some times you need to persuade on a little
09-27-2012, 01:06 PM | #312 |
Re: Cheap Tricks
I picked up a 12v DeWalt drill from a garage sale with no battery.
I took it apart and ran wires from the metal tabs in the handle where the battery went. Wires are about 5 feet long and I put alligator clips on the ends. Since it was a 12v drill, now I can just clamp it to any car battery. |
09-30-2012, 01:48 PM | #313 |
Re: Cheap Tricks
If you need to test an electrical component (Electric fan, Power window or seat motor etc.) at a junk yard or swap meet I use the battery from my Cordless Drill - It has enough power to test a Lincoln Mark VIII fan. Either strip back the wires and touch the terminals or use a couple of small jumper wires.
09-30-2012, 08:56 PM | #314 |
I am a Referee of life.
Re: Cheap Tricks
Tape also works,but a bussiness card magnet can be cut to fit inside the sockets and will hold well unless you're working with stainless.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-03-2012, 01:15 PM | #315 |
Suppose to be workin........
Re: Cheap Tricks
You can also use a water/vinegar mix in a spray bottle to keep ice from sticking to your windshield. Mix at a 1 part water to 3 parts vinegar solution. Spray on at night before going to bed. Sure a lot easier at 8:30 a.m to not have to scrape, and the neighbors appreciate not hearing the truck idle for 20 minutes!!
Brent '68 C10 '70 C10 '72 LeMans "03 Trailblazer "Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown |
10-07-2012, 08:06 PM | #316 |
Re: Cheap Tricks
love this thread! ive used a battery drill battery to roll up my friends' power windows up.....it was raining in his show truck! he had a problem and didnt have time to diagnosis it yet.
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
10-07-2012, 09:16 PM | #317 |
Florida Edition
Re: Cheap Tricks
Great post, thanks
10-11-2012, 12:50 PM | #318 |
Re: Cheap Tricks
For ice on the windshield in the morning and you dont want to use hot/warm water(which can freeze back if its cold enough outside) and you forgot to put you cardboard on the windshield...take an old spritzer bottle and fill it with Rubbing Alcohol, spray it on the ice and it melts it away. Have the windshield wipers running at the same time and no more ice.
10-11-2012, 11:58 PM | #319 |
78K & 79C Jimmys
Re: Cheap Tricks
windshield ice.....sprinkle table salt....go finish your coffee
but i like rainex too ,summer tho,now teflon wipers work well have an auto start,don't want to leave the key but want to run in to the store with it running,in park,push the start button,(some have audible click)remove key,auto start timer kicks in incase you forget to go back another defroster tip,turn the hot air to the dash vents if you have AC,heat the cab up quicker,back to fefrost before driving removing an engine.....hate dribbling antifreeze it's pet poision....I use rubber plugs ,same from pool winterizing I drink a lot of coffee.....must have 100+ large coffe tins around Maxwell house used to have a lip,on a solid tin can,(not anymore) great for sockets,parts etc....can fit 12 in the large tupperware tubs for carrying got deck off cuts of 4X4s and 6X6,tire wedges or lowering the gas tank onto I carry rubber gloves in the glove box,lots of uses,from emerg repairs to pickin up dog poop when you put used buckets in,see if you can switch left for right,change the wear patterns I always carry a lighter in the winter, cheap water fire extinguisher ,keep a two liter bottle of water handy with a pin hole in the cap rusty manifold studs?use brass nuts,might need two for the lock,cover the stud can't say ive used the dishwasher to clean but i did use the oven to soften new snowblower tires enough to get on the rim,had to put tubes in,who'd a thought plastic rims leak in the cold before i got a real exhaust lovered fan installed,in the shop door(renting I installed my own door and cut a hole init)when we were sanding in the garage,we put a box fan pointing down and dropped furnace filters (3-4) over the back of the box fan,cut down on dust and paint garage doors can sometimes be defeated and access gained,i put sliding bolts,in the track keeps the wheel from moving need bedroom storage space,consider building a bedbox built two boxes ,the two fit together queen size,stained and cleared to match the headboard,dressers heck i even recleared everything,higher gloss and now more protection for the kid
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-12-2012, 03:23 PM | #320 |
Florida Edition
Re: Cheap Tricks
^Wow, you sir are a genius! That is exactly why I started this thread, to tap into the knowlege it took years and years to learn. Thank you very much for taking the time to post this.
10-12-2012, 04:12 PM | #321 | |
Re: Cheap Tricks
kidding, good post motornut
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
10-16-2012, 09:50 PM | #322 | |
78K & 79C Jimmys
Re: Cheap Tricks
and my pics didn't even load.... door locks, look 3/4 up the door, small pic is the right side, closeup ez and cheap
10-16-2012, 10:22 PM | #323 |
78K & 79C Jimmys
Re: Cheap Tricks
ok something for the hotter states,or sometimes hotter state
we (northern folk) put window shakers in for the summer humid season well i thought a couple of years back and make a "fake"window basicly take your average sliding window,with a stationary side remove the stationary side,make a shelf for the unit and build around it, to replicate the stationary side replace and use the sliding part ,as norm,ours opens over half way most people i see do a sad job sealing the unit in,when thats when they take out only the slider anyway,or leave it in leaving a glass gap the other side(red line) I also removed side casement window (1 of 3)to put another unit in allows the middle window to function normally (windows replaced for winter) prob need pics for this lol,found some might help
10-17-2012, 07:00 PM | #324 |
Old member
Re: Cheap Tricks
Well I don't know about cheap but since I already had them I put them back to use.
My wife wanted new lights for the fire place and kitchen so I made use of these in the garage for when I'm working on the truck. Just used some old drop cords that the ends were no good and straight wire them to the lights. I use this one under the truck and it want burn u like a shop light. These I mounted on the garage door rail. When my garage door is up the ceiling light's had no effect so I mounted these.
10-17-2012, 07:59 PM | #325 | |
What?
Re: Cheap Tricks
It ended up causing a fault in the system, and had to be replaced with a standard Tstat. So for the people with computerized systems, this old trick may backfire on ya. Just a heads up.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
