Old 02-25-2009, 08:45 AM   #301
pgf545
pgf545's Avatar
Re: 52 Project
Originally Posted by OrrieG View Post
Ben, you are SO right, best do do the worst side first, then at least the second seems easier.
Well I did it backwards but I have good reason...I can build confidence from the easier side and not get so frustrated...lol. I think it will be ok but the prefectionist in me is coming out and I need to get over that...I have to keep telling myself that I am not building a 100 point show car. But we do want a nice driver that we can be proud of. Dad keeps telling me that it is fine but I want it nicer. Anyway I will get it the way I want before it gets painted.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 02-25-2009, 09:29 AM   #302
bensimmons_05
bensimmons_05's Avatar
Re: 52 Project
I know what you mean about the perfectionist part. In my build I kind of have to take a lot of time on everything or I will be stuck with nothing to do until I save up more money. So in a way I'm glad I'm not able to have all the parts at my disposal. keep up the good work, and if your going to do it, why not do it right like you have been, if you dont fix it like you want you will regret it later
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 02-25-2009, 10:04 AM   #303
b00sted
b00sted's Avatar
Re: 52 Project
Nice build....
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 04-15-2009, 08:20 PM   #304
pgf545
pgf545's Avatar
Re: 52 Project
Well not much going on in truck land. I have been busy doing all sorts of other stuff and haven't had a lot of time to work on the truck. I did get the cab corners done and dad bought a new door and I got that fitted pretty nice. He also ordered new chrome and hardware stuff for the door so I will install that after paint. I put the cab back on the frame last weekend so that I could get the steering column mounted and figure out what we are going to do for seats. My mom bought some seats out of an Explorer but dad doesn't really like them but I think we are still going to use them. They will have to be cut down to look right. I ran a battery to them and gave them a "test" drive...lol. Anyway here are a couple of pictures from last weekend.
Bernie
Old 04-15-2009, 10:25 PM   #305
Daniel U
Daniel U's Avatar
Re: 52 Project
Good to hear from you. Thanks for the update! Looks good.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 04-16-2009, 06:13 AM   #306
solidaxel
solidaxel's Avatar
Re: 52 Project
Bernie, is that a NEW, NEW door !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-16-2009, 01:16 PM   #307
pgf545
pgf545's Avatar
Re: 52 Project
Yep that is a New New door...That made my day....thanks Solid.
Old 04-16-2009, 01:21 PM   #308
tim21391
tim21391's Avatar
Re: 52 Project
that 572 is going to purr so nicely.. once you get done post up a video so we can hear it
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-16-2009, 02:58 PM   #309
pgf545
pgf545's Avatar
Re: 52 Project
Well it is not actually a 572, I think it is a 468. My dad liked those valve covers so he bought them...lol. Maybe after we get it going we might build a 572 but for now that is what we got. It should still run pretty well. It has Edelbrock heads and a hydraulic roller cam. We didn't want to get to crazy cause we want to drive it. I will post a video once we get it running....may be a while though.
Bernie
Old 04-19-2009, 08:54 PM   #310
pgf545
pgf545's Avatar
Re: 52 Project
I got a little done today. I got the steering column in and also the throttle pedal. The steering column needs a little detail stuff but it is in. Now we can order the u-joints and shafts. Here are a couple of pictures.
Bernie
Old 04-19-2009, 09:25 PM   #311
50adrod
50adrod's Avatar
Re: 52 Project
your truck is looking good, nothing beats a big block I have a tweaked 454 in my 71 vette there is no mistaking a big block sound. here are a few pics of my steering setup. we have the same firewall and steering column and MII steering but mine is located a little to the left to clear my 5.3 maybe you can get some idea on the universals. I used a universal at the rack with built in shock absorbing to act as a rag joint, also I had to add a support to make things smooth. they recomend one anytime you use a 2 u joints or a double u joint. good luck
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 04-21-2009, 10:53 AM   #312
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 52 Project
Hey Bernie, Your making some good progress on the truck and it's really coming together well! Have you and your Dad picked a color yet?
CAL 58 GMC is offline   Reply With Quote
Old 04-21-2009, 02:06 PM   #313
mylow53
mylow53's Avatar
Re: 52 Project
nice bernie your steering seems to fit in well i like your headers. whats the plan for the trans shift? lots of guys are having issues with it clearing the brake arm. mine seemed to work out well with a simple bend in the linkage to clear. looks to me like your steering it a bit farther over than mine. you might want to think about a shift cable.
keep up the good work!
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 04-21-2009, 04:35 PM   #314
4DSEVEN
4DSEVEN's Avatar
Re: 52 Project
Looks great!
Thanks for sharing the pic's it helps with my own project.
4DSEVEN is offline   Reply With Quote
Old 04-21-2009, 09:46 PM   #315
pgf545
pgf545's Avatar
Re: 52 Project
GT
Greg...one step ahead of ya...lol. This column has the shift linkage already built in for the cable. The shift arm on the bottom of the column has an adjustable arm on it. There are 4 little screws that hold it onto the column so I can index it. Then it can with a Lokar shift cable setup, so hopefully everything will work.
Thanks for the compliments they are what keeps me going. If our truck comes out half as nice as yours I will be thrilled.
Bernie
Old 04-21-2009, 09:49 PM   #316
pgf545
pgf545's Avatar
Re: 52 Project
Originally Posted by 4DSEVEN View Post
Looks great!
Thanks, Hey I lived off other peoples pictures on here, and I asked questions. If there is anything that you need more detail of I have lots more pictures or I can take what you need. I am starting to feel like I am seeing the light at the end of the tunnel and it's not that damn train...lol.
Bernie
Old 04-21-2009, 09:52 PM   #317
pgf545
pgf545's Avatar
Re: 52 Project
Thanks, It is going to be some sort of red....ok I don't know the exact color but it is kinds like a dark candy red. He bought a little bit to spray and see if he likes the color on a panel. It looks almost maroon in the garage but lightens really nice in the light. Once we get something sprayed I will take some pictures.
Bernie
Old 04-22-2009, 12:35 AM   #318
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: 52 Project
Bernie
Is that a universal ididit column? and what length is it?
Looks sweet in your truck. I hope to have mine mocked up this weekend. Where do you plan to get your U joints and shaft from?
IvelDesigns is offline   Reply With Quote
Old 04-22-2009, 08:11 AM   #319
c10addict
c10addict's Avatar
Re: 52 Project
NIce work! Can not wait to see it all come together!!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 04-22-2009, 11:22 AM   #320
pgf545
pgf545's Avatar
Re: 52 Project
c10, Thanks and I can't wait for it to come together.
I will have to get the dimensions this weekend, we are going to get our u-joints from Ididit...me and my brothers got my dad a gift certificate for Christmas from there. It was just easier to go back to them. There are several places you can get them through though. I did some research last year and most places are about the same price....some a little higher and some a little lower. I decided that since we already had their column that if I ran into any problems it might be easier to get everything from the same place.
Bernie
Old 04-22-2009, 01:57 PM   #321
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 52 Project
Bernie
Cool!! I can't wait to see some color!
Old 04-22-2009, 04:51 PM   #322
4DSEVEN
4DSEVEN's Avatar
Re: 52 Project
Bernie can you tell me what the length of your steering column bracket is if you recall?
Thanks.
Mark
Old 04-22-2009, 10:21 PM   #323
pgf545
pgf545's Avatar
Re: 52 Project
Mark, I am going to have to take a look at it this weekend. The truck is at my dads and I usually only go down there on the weekends. I will measure it for you. I am thinking it is about a 4 inches. Are you looking for the center of the column to the mounting flange? I made the rectangle block to adapt the mount to the original holes on the truck. One thing I noticed was the original column cutout is not centered between the gauges so when I put this column it is in the same location as the original but it was comfortable with where I have the seat located. I thought about centering it but wasn't sure if it would be to far over. Anyone else done that?
Bernie
Old 04-23-2009, 06:39 AM   #324
4DSEVEN
4DSEVEN's Avatar
Re: 52 Project
I think they are measured to length from end to end.
Old 04-25-2009, 07:30 AM   #325
4DSEVEN
4DSEVEN's Avatar
Re: 52 Project
My mistake it looks like it is measured to the center of the drop.
