Old 05-17-2010, 11:14 PM   #301
65BURB
Re: Post pics. Lets see how many 60-66 4x4 are out there.
The Suburban is mine and yes it is real. You don't think I would leave it looking like this if slid something newer under it and/or photo shopped it. HA. The crew cab is one that I almost bought last summer.
65BURB is offline   Reply With Quote
Old 05-18-2010, 01:15 PM   #302
Franks Fab Shop
Franks Fab Shop's Avatar
question; did these early 60-66 4x4 transfer cases have a low gear on top of the allready "granny gear" in the gear box?
are they the same in chevy and/or GMC?
Franks Fab Shop is offline   Reply With Quote
Old 05-18-2010, 01:26 PM   #303
justcuz
justcuz's Avatar
Yes they had a low range. With the low gear in the 4 spd trans and the 1.96 to 1 low range it approximately doubled the low gear ratio. The Rockwell transfer case was used in the Chevy and GMC 4x4's from 1960 to 1966 in the divorced application that you have.
justcuz is offline   Reply With Quote
Old 05-18-2010, 04:05 PM   #304
Franks Fab Shop
WOW! my buddy said his dad,as a kid, had the GMC (V-6) 4x4, that would "idle up the walls of the grand canyon" if you pointed it that way.
and i beleve him, cause my 2WD V-6 in 1st gear feels like that now!!
Thanks justcuz
Old 05-19-2010, 01:27 PM   #305
justcuz
justcuz's Avatar
Your welcome. The SM420 transmission has one of the lowest first gears of a light truck 4 speed, close to 7.0 to 1. So if you double that plus multiply it by your axle ratio ye get your crawl ratio. 7x2x3.73=52.22 to 1. That is rounded up except the axle ratio which should be 3.73 for a half ton unless it was ordered with something else.
Anything over 40 to 1 is considered pretty good.
Keep in mind the new NP 241 aluminum t-cases have a 2.72 to 1 reduction ratio. So a NP 241 behind your SM420 would net you a 71 to 1 crawl ratio!
Old 05-19-2010, 04:17 PM   #306
K-TEN
Can't speak to the later years, but the 60 and 61 K10's had a 3.90 rear ratio (3.92 at the front-they can't be numerically the same)
So 7x2x3.90 is 54.60
And the K-20's had a 4.56 rear
So 7x2x4.56 is 63.84
K-TEN is offline   Reply With Quote
Old 05-20-2010, 04:34 PM   #307
justcuz
justcuz's Avatar
^ Correct. I forgot that the 1/2 ton gear ratio changed in 1963 when they started installing 12 bolt rear axles. So if you had a corporate HO 33 with a dropout center section in the rear axle it was probably 3.90 and a 12 bolt would have been 3.73.
Old 06-29-2010, 03:29 PM   #308
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Here are more.
66Gilbert is offline   Reply With Quote
Old 07-01-2010, 12:24 AM   #309
Chevymaniac
You just can't beat the looks of some classic old iron?
Keep the pics coming.
Chevymaniac is offline   Reply With Quote
Old 07-03-2010, 01:54 AM   #310
1tonswb
1tonswb's Avatar
Its been awhile since I posted this truck up. Ive done a ton of work to it since the last postings.
1tonswb is offline   Reply With Quote
Old 07-04-2010, 11:18 PM   #311
wilkinst
Here's mine:
When I brought it home:
After a little paint for immediate gratification:
wilkinst is offline   Reply With Quote
Old 07-05-2010, 06:33 AM   #312
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
NICE LOOKING TRUCK YOU GOT. tHE STOCK LOOK IS REAL COOL.
Old 07-05-2010, 09:00 AM   #313
62 short step
62 short step's Avatar
Very nice!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 07-08-2010, 09:20 AM   #314
JTR
In the works build up here
Sold...1965 Chevy 3x4 ton 4x4, short bed step side
JTR is offline   Reply With Quote
Old 08-02-2010, 02:00 AM   #315
skokz
Well half of it is 60 - 66 and the other half is late 70s.
Will be more later when it finally gets home.
skokz is offline   Reply With Quote
Old 08-02-2010, 03:02 PM   #316
abebummy26
abebummy26's Avatar
here's one for sale semi local to me http://stlouis.craigslist.org/cto/1828611923.html
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 08-02-2010, 04:56 PM   #317
j.kirn
the suburban is sold
j.kirn is offline   Reply With Quote
Old 08-02-2010, 06:32 PM   #318
abebummy26
abebummy26's Avatar
Where are you at in MO?
-Lincoln
Old 08-03-2010, 07:16 PM   #319
j.kirn
St. charles next to st.louis
Old 08-03-2010, 11:21 PM   #320
abebummy26
abebummy26's Avatar
Sweet I graduated from Washington High School
-Lincoln
Old 09-12-2010, 07:08 PM   #321
brew8
A coupla of pictures of mine, almost ready to go,
brew8 is offline   Reply With Quote
Old 09-15-2010, 02:51 PM   #322
justcuz
justcuz's Avatar
Not sure if I posted these yet or not, my buddys 62, was an old Edison Co. truck.
Old 10-27-2010, 03:38 PM   #323
6722
Here is my '61. Its on a '78 frame.
6722 is offline   Reply With Quote
Old 11-10-2010, 10:41 PM   #324
ya it is a classic
what the heck! you guys run out of pics?!?! ill have to go snap a pic of my freebie 66 c10 4x4. theres a reason it was free though.
ya it is a classic is offline   Reply With Quote
Old 11-10-2010, 11:50 PM   #325
62 short step
I posted mine earlier in this thread, but now its painted! So here are some updated pics on mine.
1965 c-10
86 chevy c/k 20
k10 1960
