Old 06-02-2011, 07:14 PM   #301
Kim57
Kim57's Avatar
Re: Ben Jammin's 1955 Chevy/GMC Project
Originally Posted by watahyahknow View Post
cleco's are temporary rivets basicly i know wat you want though , they call them buttweldingclamps :
http://www.georgia-market.com/Warner...-auto-body.asp
I've used them and they work pretty good. The biggest problem is they do leave a gap.
Harbor Freight carries them pretty cheap.
When I replaced the rear quarter on my brothers 54 I made some tabs out of 3/16" steel and just screwed the new metal on. It was a tight fit and the holes were easy to fill.
Here's a pic.
Kim
Kim57 is offline   Reply With Quote
Old 06-02-2011, 11:38 PM   #302
Dan in Pasadena
Dan in Pasadena's Avatar
Yes, those are exactly what i meant but I wrote Clecos - DOH! See, clueless but well intended. Are you guys using those butt weld clamps or just eyeballing a small gap....seems like it wouldn't be THAT critically off by eyeballing it. Maybe I'm wrong.
Dan in Pasadena is offline   Reply With Quote
Old 06-03-2011, 12:54 PM   #303
Russell Ashley
Russell Ashley's Avatar
I bought a set of those butt-weld clamps from HF thinking I would use them when I repaired the bottom of my door, but didn't use them at all. They haven't been as useful as I thought they would be. The problem is that you have to have access to both sides of the work, and the work piece has to be almost completely flat to use them. Then when you get ready to remove them you have to have some way to get the square bars that go behind the panels out.
Am I overlooking something simple? Wouldn't be the first time, LOL.
Russell Ashley is offline   Reply With Quote
Old 06-03-2011, 01:35 PM   #304
watahyahknow
watahyahknow's Avatar
i would think you can drill a small hole in one side of the square bar and hang some metalwire from it , then you can pull the bar out remotely , that small flat iron with metalscrews idea from kim looked pretty good too and its prolly cheaper and eazier to use
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 06-07-2011, 01:04 AM   #305
oldman3
oldman3's Avatar
Ben, finally got the time to look at your build from the start. Man you've been thru a lot, both in the build, and in personal issues. Truck is coming along nicely, will be with you till the end......Jim
oldman3 is offline   Reply With Quote
Old 06-07-2011, 07:21 AM   #306
bensimmons_05
bensimmons_05's Avatar
Thanks a lot, Jim. I definitely have a LONG way to go! Life is kinda like a truck build, lots of hard work, bumps and bruises, highs and lows, some things you wish you could do over, but you still wouldn't change it for the world. For me its not getting to the finished project, it is the trip to get there... then, of course, modestly bragging about it when it is done, lol.
That is my 6:20 a.m. insight for the day!
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 06-07-2011, 09:47 AM   #307
oldman3
oldman3's Avatar
At 6:20 a.m., I turned over and snozzed till 7:30 a.m. and then got up, being retired has some rewards. Now I'm sitting here drinking my and posting ....Jim
Old 06-16-2011, 07:58 AM   #308
bensimmons_05
Got my pitman arm on Yesterday, Got it adjusted about right. I'm a little bit worried about clearance once I have 1,000 more pounds on the springs and a big bump... I'll just have to see what it looks like then.
Old 06-16-2011, 08:15 AM   #309
57ToyBox
57ToyBox's Avatar
Lookin good...
and that's all I have to say. I still haven't finished my coffee
57ToyBox is offline   Reply With Quote
Old 06-16-2011, 01:26 PM   #310
OrrieG
OrrieG's Avatar
Looks good but check your bumper bracket for conflict, I had to modify mine because the box covered the mounting hole. I made it so the bracket takes the place of the front steering box mounting shim between the box and frame. I will post a photo on my build.
OrrieG is offline   Reply With Quote
Old 06-16-2011, 03:26 PM   #311
bensimmons_05
Thanks for the input, I'll check that out for sure.
I'm out in the shop now, video is going if yall feel like stoppin by.
Old 07-05-2011, 04:17 PM   #312
bensimmons_05
working on some patch panels today ↓↓↓↓
Old 07-20-2011, 07:46 AM   #313
bensimmons_05
I have been slowly but surely welding and grining on my patch panels. Before I started welding my lower hinge pocket on I wanted to weld the lower hinge pillar. I have been using rivets to hold the pieces tight together and then welding up the holes, It seems to be working well.
Old 07-20-2011, 07:51 AM   #314
bensimmons_05
I am still making more replacement panels where I can. They have come out good so far the best I can tell.
I have learned something new about these trucks. Early 1955 cabs had different hinge pockets than the later ones!
To make up for the difference I made a filler piece to connect the new hinge pocket panel and the piece I recreated.
Old 07-20-2011, 07:55 AM   #315
bensimmons_05
Sometimes you just get lucky, this little piece I made fit like a glove!!
I'm really not too proud of my welding on this one, had some blowouts, got it a little too hot. I discovered my welder wasn't feeding very consistent so I adjusted it and it works SOOOOOOOO much better now!
Old 07-20-2011, 08:01 AM   #316
Russell Ashley
"Early 1955 cabs had different hinge pockets than the later ones!"
I've wondered about that also. From pics I've seen it looks like some of the outer hinge covers were square on the bottom but mine looked like the patch panel you have.
Old 07-20-2011, 08:09 AM   #317
bensimmons_05
Yes sir, that was the difference! The ones on this cab were square at the bottom and boxed in with a flat piece of metal like the one I made.
On my other cabs they are cut out like the replacement panel, and inside is what looks like a stamped piece of metal. If anyone ever tries to redo this on mine way in the future they are going to have FUN haha!
Old 07-20-2011, 10:38 AM   #318
Kim57
Kim57's Avatar
Nice job on the patches. Looks like your making good progress.
Kim
Old 07-25-2011, 08:09 AM   #319
bensimmons_05
Thank you, Kim.
I started welding in the big piece! It is most of the way in, I wanted to get in in and lined up before I cut the cab corner off so I would have a good reference. Im planning on welding a bunch on the bottom after I finish both sides and flip the cab.
I helped my dad put a motor together and install it back into a 91 silverado this weekend so I only worked on the 55 a little bit.
Old 07-25-2011, 01:12 PM   #320
watahyahknow
;ooks good , i would testfit the door first and check the gaps allround , you can still tweak it a bit at this stage if it needs it
Old 07-27-2011, 11:03 AM   #321
bensimmons_05
Watahyahknow, I will definitely do that! Thanks for the input.
Old 11-28-2011, 09:46 AM   #322
bensimmons_05
I have been dormant for a while. Buying a house and moving definitely takes up truck time!! I had some time over the Thanksgiving break and was able to do what I love to do! I moved my parts truck from my old property to the shop. I pretty much just put some hubs on the front and My Dad, Uncle, and I pushed it up on the trailer.
It is now just waiting to be used and abused.
Old 11-28-2011, 09:48 AM   #323
bensimmons_05
I had the opportunity to work on the cab all day yesterday. What most of you could do in a matter of hours, I spent all day doing, haha.
I cut out the old cab corner and got to fitting and trimming the new one.
Old 11-28-2011, 09:52 AM   #324
bensimmons_05
I had some dents in the area to work with, but I think it came together pretty good. I have some small spots left to weld and all of the grinding still. I am nearly complete with the passenger side. Next: Driver's side!!!
These are small victories, but it is ONE STEP CLOSER (or one corner closer in this instance)!!
Old 11-28-2011, 11:36 AM   #325
oldman3
oldman3's Avatar
Ben, the cab corner looks good. I wouldn't worry about how long it takes to get it done, as long as it fits good and everything lines up. We all have our own pace (most of the time mine is slow).....Jim
