Old 05-31-2011, 10:23 PM   #301
nebdrummer
nebdrummer's Avatar
Re: Project "49 No Buck$"
sounds real helthy!
love the truck.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 06-01-2011, 02:44 PM   #302
kustombrad
kustombrad's Avatar
I have 3" blocks with TCI rear springs. The carb is a 3310 750 Holley that I took the stock rear (non-adjustable) jet plate off and put a standard plate for jets. Now I can fine tune it and make it work good! Thanks for all the compliments guys, I really do appreciate them! It's getting closer to being a driver...
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 06-08-2011, 12:35 PM   #303
kustombrad
kustombrad's Avatar
Seat Belts! I found some 3 point belts on Ebay for $80 and here's how I installed them. The first thing I did was drill a hole in the flat area between the quarter window and the door jamb. I went about halfway up (I sat in my Blazer and used that mount height from where I sit) and drilled my hole. Next I took the flat mounting plate they give you and drilled a hole in the end. The hole is to hook a piece of wire to and then lower it down from inside the top area (it fits perfect) until you see it in your drilled hole. It's a little work, but once you get the bolt about halfway in you can pull the wire out and tighten it up Now I used the back plate/rail area behind the seat to mount the retractable part of the seatbelt. Next I made a couple of mounts from 1 1/2" x .125" angle, drilled some holes and mounted these to the floor. I used another set of plates that I had (like I used in the door jamb) and used it under the floor to hold the bracket in place After I finish the carpet and seat, I'll paint the brackets and then it'll look finished.
Old 06-08-2011, 02:28 PM   #304
65Pickup
65Pickup's Avatar
Nice work and report, I've been wondering how these systems install. I thought the shoulder harness wouldn't look factory. Thanks for the insight, the install looks great, I'll be looking to add this come winter. Great project and teaching.
But could you show and explain a little more on positioning the shoulder plate. Is there a hole above to plug? I'm not visualizing it well. Thanks
65Pickup is offline   Reply With Quote
Old 06-10-2011, 11:41 AM   #305
playinsafe44
Do you think you are going to have the annoying problem of those retractors locking up on you randomly? It looks like your mounting the retractor 90 degrees from the the way it was mounted from the factory. I'm just curious because I'd like to do this in the future. Your build is great!!!
playinsafe44 is offline   Reply With Quote
Old 06-10-2011, 01:03 PM   #306
kustombrad
kustombrad's Avatar
This little trick I learned from a friend of mine who did a lot race car prep. Put a jackstand (or something kinda heavy) at all 4 corners. Now I used 1/16" nylon rope/twine tied it to the stands and then set the height where the string is going though the rear axle and front spindle centerline Slide it as close as you can get it to the body without touching. Now take a straightedge and measure the leading (front) edge of the back wheel and then measure the back edge. Slide the stand until the string is dead even square on the wheel. Do BOTH sides the same way! DON'T MOVE THE STANDS! Now your string is a perfect 90 degrees with the rearend! Make sure your steering wheel is where you want it and then check your measurement same way on the front wheel. Adjust your tie-rods or cross link until the front wheels are perfect with the string. Once it's even on BOTH sides, you've now squared the front and rear together! I'll still take it and get the alignment done (caster/camber) but this will give you a really good idea of where you're at!
Old 06-10-2011, 01:11 PM   #307
weaintscared
weaintscared's Avatar
Cool ride
My build http://67-72chevytrucks.com/vboard/s...d.php?t=468622
weaintscared is offline   Reply With Quote
Old 06-11-2011, 01:12 PM   #308
kustombrad
kustombrad's Avatar
As far as mounting the seatbelts that way, that's how the retractable part mounts. These aren't factory so don't go off of other ones. If I laid it flat it would want to bend the mount up during lock up instead of pulling evenly. I messed around with it and I don't think they'll lock up randomly.
Old 06-12-2011, 12:18 AM   #309
ratty 46
I dig the hose idea along with the late model gm under hood add on.
Sounds great too.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 06-20-2011, 10:32 AM   #310
kustombrad
kustombrad's Avatar
Alternator mount... Took a stock, late model mount I had laying around and decided to clean it up a bit. Used masking tape to mark where I'd cut then put it on to see how it will look (it's bare metal in the pic) Hey, I'm still doing cheap and simple!
Old 06-20-2011, 10:44 AM   #311
kustombrad
kustombrad's Avatar
This little deal was just to make driving a bit easier. Anyone with AC on a carburated vehicle knows it can be kind of a pain. It idles high when the AC is off or dies when it's on and the idle is set too low. I grabbed an idle solenoid off an '81 Malibu with a Quadrajet trimmed the bracket to fit around the accelerator pump and bolted it to the carb stud When I finish wiring the truck, this will be inline with the AC system. When the AC is turned on, the solenoid will push the throttle just enough to raise the idle (easily adjustable) so the engine won't die. Pretty inexpensive (nearly free!) and it works well!
Old 06-20-2011, 11:36 AM   #312
daverod
SSN 706
daverod's Avatar
Lots of good cheap ideas. Just what I need, cheap.
daverod is offline   Reply With Quote
Old 06-20-2011, 11:55 AM   #313
OrrieG
OrrieG's Avatar
Something I had not even thought of since I haven't driven an old car with AC for so long. Will add it to the list for my next junk yard run. Also, public thanks for the pulley! Patrick
OrrieG is offline   Reply With Quote
Old 06-20-2011, 09:25 PM   #314
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Man you've really done some great work! Thanks for sharing!
ChuckDriver is offline   Reply With Quote
Old 07-05-2011, 02:51 PM   #315
kustombrad
kustombrad's Avatar
Didn't want anyone to think I've been slacking, but I actually have been getting stuff done! Put new window channel, rubber and felt (what a major pain!), rebuilt and painted the factory heater (I'll show pics after it's striped) and finished my AC and power steering mounts! I've been busy on it! Sunday, Alex came over and started laying out the wiring (I hate electrical and he's THE man!!) and I will say it'll be way nice! I took the old windshields out to put new glass and rubber in and finished up the striping on the dash now that I could get my hand up there! I then decided to have a little fun... I bought a little Tiki guy, cut the base off of him and put him on a surfboard made out of 16 gauge steel and some bondo. I then shaped an old striping brush drenched in catalyzed clear, painted the surfboard, glued the brush on to my little guy and TA DA.... Surfer Tiki Striper! When the truck is finished, he will be the final touch!
Old 07-05-2011, 03:26 PM   #316
VA72C10
VA72C10
VA72C10's Avatar
That's cool! Will be a neat touch!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-05-2011, 03:47 PM   #317
xpickup
xpickup's Avatar
I like that very much. That is cool how you made the Tiki guy personalized and the stripping brush line up with the stripe. Very cool.
Shannon
xpickup is offline   Reply With Quote
Old 07-05-2011, 05:01 PM   #318
52 Rat
52 Rat's Avatar
Now that is original; thinking out of the box! Nice touch!
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 07-05-2011, 09:25 PM   #319
ChuckDriver
Very COOL!!
Old 07-13-2011, 11:11 AM   #320
kustombrad
kustombrad's Avatar
Now it's getting to the time consuming parts! Doing the wiring at the moment and trying to hide everything! My friend Alex had a great idea for hiding the wiring in the intake area, so I fabbed up 2 looms out of some bar stock and a cut in half 40"x3/8" fuel line. I'll put black shrink wrap over the wires so the colors don't jump out so much. The only other wires you see, is where these come out of the lower toe board from the interior and that's only if you really look for them. I also brought the hot wire for the coil from inside the cab, so the engine compartment is very clean. That ugly HEI is going away soon too! Cleaned up the heater, blasted and painted it then threw some lines on it. I think I need to add some blue and green to tie in with the dash
Old 07-13-2011, 12:52 PM   #321
VA72C10
VA72C10
VA72C10's Avatar
Love the heater box and the wiring looks really clean!!!
Old 07-13-2011, 01:19 PM   #322
Kabwe
Certified Car Nut
Kabwe's Avatar
Everything looks great and it was really nice meeting you last weekend. You and Alex are really cool guys.
Kabwe is offline   Reply With Quote
Old 07-13-2011, 04:39 PM   #323
chevyrestoguy
chevyrestoguy's Avatar
You showed the world my wiring idea (the tube) before I could copyright it. My lawyers will be calling and issuing a "cease and desist" order.
It's always so cool to go over to the shop and see how much more you've gotten done. You're getting close!!!!!!!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 07-13-2011, 07:48 PM   #324
ChuckDriver
Hey, that was my idea! Nice work!
Old 07-14-2011, 04:00 PM   #325
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Thumbs up
LOW DOUGH is offline   Reply With Quote
