Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 02-02-2013, 10:48 AM   #301
Hazieview
Building Dreams out of Dimes!
Originally Posted by Captainfab View Post
Right now I can't think which of my custromers that have bought these brackets are using the Eldorado calipers.
I can not get a set of the D122 pads until tomorrow, but I did put a set of the D52 pads in a Eldorado caliper today. With the piston all the way retracted, there is 1.312" (1-5/16") between the pads. The pads I used were each about 9/16" thick. I'll check again tomorrow when I get the D122 pads.
Cadillac rotors are 1.22" thick. Astro rotors are 1.29". After looking at several different places I simply can not find any D52 pads that are thin enough to work. If you happen to find some that will work please let me know as soon as you can. If D52 pads will not work with these calipers please pm me.
Hazieview is offline   Reply With Quote
Old 02-03-2013, 12:06 AM   #302
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
I got my D122 pads from O'Reilly's this morning. I put a set inside a caliper and the Astro rotor fits with a little room to spare. The D122 pads are noticeable thinner than the D52 pads. I didn't get a chance to try a set of D52 pads with the rotor as I had a bunch of work to do today. I'll try and check the D52 pads tomorrow.
Old 02-03-2013, 01:08 AM   #303
Hazieview
What are the d122 off if?
Old 02-03-2013, 01:16 AM   #304
Captainfab
60-66 Nut
The D122 pads are for the '76-'78 Eldorado. The only difference I can see in them at this point, is that they are a little thinner.
Old 02-03-2013, 06:54 PM   #305
Hazieview
Old 02-04-2013, 12:41 AM   #306
Captainfab
60-66 Nut
I checked out the D52 pads today and the Astro rotor fits with those pads also. It is a little tighter, but they do work.
I'm not sure what is going on with your calipers and pads Hazieview.
Old 02-04-2013, 07:43 AM   #307
Hazieview
Do you have a part number for the D52 AND THE D122 pads you purchased? I will just go buy the exact same ones and hope for the best.
Old 02-05-2013, 01:08 AM   #308
Captainfab
60-66 Nut
I bought both sets of pads from O'Reilly's. The Brake Best part numbers are MKD52 and D122
Old 02-07-2013, 08:44 PM   #309
Hazieview
Alright Capt! I got it!!! The brake calipers I bought at Autozone were around 1/4" too narrow. I got the right set from Oreillys. Thanks for the help man!
One more question.... Did you put 'clips' on your brake pads? Mine didn't come with any... Just wondering if I needed some. Thanks!
Old 02-08-2013, 12:37 AM   #310
Captainfab
60-66 Nut
The D122 pads did not come with any 'clips' and I don't think the D52 pads I have did either. I'd have to look at the D52's again to be sure.
Old 02-08-2013, 07:06 AM   #311
Hazieview
I got the d52 pads. From what I read, anyone using the Cadillac Eldo brake calipers, needs brake pad clips before using the parking brake. I guess it is a safety factor because the clips hold the pad in place and align it where it needs to be.
Old 02-13-2013, 07:10 PM   #312
Hazieview
Any news on the Eldorado parking brake brackets?
Also...
My drivers side rotor did not clear the brake pad and is touching the rotor. Any idea how to fix it? I thought about just letting of score itself down...
1981 Chevy short/wide.
SB400 350th
Old 02-14-2013, 12:14 AM   #313
Captainfab
60-66 Nut
The cable brackets have been on a laser cutting order along with some parts for my regular business parts. But that order got bumped a couple times for an urgent order. Unless something comes up again, I should have those pieces on Monday.
There have been 2 other customers with the rubbing pads issue, but neither has provided me with the measurements I asked for to determine what the issue may be. That is strangw that you are having that issue on just one side.
Do you have a way to either grind or sand the metal part of the pad to gain some clearance?
Also...
Old 02-20-2013, 03:54 PM   #314
azkid602
am gonna buy the rear disk brake bracket setup for my 69 c10 and was wondering if you know of any performance slotted and or drilled rotors thatll fit in place of the factory style astro ones that u set it up to use ,like how you said that itll accept oem D52's or wilwood D52's.. ithere an upgraded rotor available that you know of?
azkid602 is offline   Reply With Quote
Old 02-20-2013, 05:17 PM   #315
truckzilla
truckzilla's Avatar
Just go to someplace like brakeperformance.com and get the same rotor you're looking for but with the added slots, or holes, etc.
truckzilla is offline   Reply With Quote
Old 02-20-2013, 11:20 PM   #316
Captainfab
60-66 Nut
Any place that sells drilled and slotted rotors will have them for the Astro/Safari vans.
Take a look here.....several to choose from
http://www.summitracing.com/search/p...stro/year/1995
Old 02-25-2013, 05:08 PM   #317
82ZZZR
New to this whole thing, so I need these bracket and some Wilwood D52 calipers and Im good to go?
82ZZZR is offline   Reply With Quote
Old 02-25-2013, 11:25 PM   #318
Captainfab
60-66 Nut
You will need these brackets, any D52 caliper or the Eldorado calipers, the Astro rotord, some hoses, a disc/disc master cylinder, and a proportioning valve either for disc/disc, or an adjustable valve. There is a parts list that comes with the brackets for all the parts to install the brackets on your differential.
Old 02-25-2013, 11:46 PM   #319
woodwright
Enjoying left field
woodwright's Avatar
Hey Cap'n, you got a part number for a disk/disk MC?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 02-27-2013, 12:18 AM   #320
Captainfab
60-66 Nut
Mid 70's Vette
Old 03-15-2013, 12:18 PM   #321
JointTech
JointTech's Avatar
sorry i cant go through 11+ pages of this thread.
Do you have a set for 8 lug?
Do you have a kit including the wilwoods and rotors? or a complete kits with everything? Or at least a list of part numbers in one place?
If I put wilwoods on that means I cant ever have an ebrake? I have to use a special ebrake caliper?
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 03-15-2013, 11:14 PM   #322
Captainfab
60-66 Nut
Sorry but no, I do not make any rear disc brackets for 8 lugs. There are several others that make them. Here are two of the best.
http://www.ruffstuffspecialties.com
http://www.diy4x.com
Old 03-16-2013, 12:17 AM   #323
JointTech
JointTech's Avatar
thanks for the links. ill check them out. i thought this was going to be easy. but my wife says my jobs always take 3x as long and double the budget.
72 C20 Long Bed
Old 03-17-2013, 09:04 PM   #324
blazins10
blazins10's Avatar
Can u can pm me payment info on these brackets for 1972 c10 12 bolt
blazins10 is offline   Reply With Quote
Old 03-17-2013, 11:27 PM   #325
Captainfab
60-66 Nut
PM sent.....
