Old 05-06-2011, 03:11 PM   #301
Strodder
Daring to be Different
Strodder's Avatar
Re: Daverods 52
Not a bad price. I'll have to check with my guy to compare.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 05-06-2011, 04:23 PM   #302
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Daverods 52
Yeah that's not a bad price at all. The lub should be for your lifters and cam since your rebuilding it yourself.
My 350 for the 64 was about $1600 10 years ago, but had major head work and bored 40.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 05-06-2011, 09:57 PM   #303
Strodder
Strodder's Avatar
Re: Daverods 52
Don't forget to add break in oil additive.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 05-07-2011, 10:30 AM   #304
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Yep. I guy tried to sell my a bunch at 8 a qt? Guess today is engine build day. Well I might put my crank in. I'm not a real mechanic. I have to read a lot and look at pictures.
daverod is offline   Reply With Quote
Old 05-07-2011, 11:01 AM   #305
Strodder
Strodder's Avatar
Re: Daverods 52
Lube, lube, lube on assembly. Keep it clean, and torque to specs. Don't over tighten where there is gaskets. Have fun
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 05-07-2011, 01:39 PM   #306
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Ok maybe I'll do more than just put my crank in. just jokin.
Old 05-07-2011, 01:44 PM   #307
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Get my rear end kit monday. Got some airline and braided hose today. Only sent me one hose.hosers
Checkin the gaps. I pushed the ring about 1/2 way in with the piston. The one in the picture is just for show and tell. Keepin track of who goes where.
Old 05-08-2011, 04:34 PM   #308
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Like a dumb a$$ I just dumped the rings out of thew box then I looked on the box and on the side tabs it tells what rings go on top. The box was divided into compartments. I'll have to wait till tomorrow to see what the machine guy says. The top ring has a bigger bevel on the inside that faces up. The second ring has a smaller bevel on the inside facing down. I think????Da
Old 05-08-2011, 04:38 PM   #309
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Found a 700r4 on craigs for 100. Could'nt pass it up even if it's no good. Of course they said "It ran good when we pulled it"
Old 05-09-2011, 09:20 PM   #310
Strodder
Strodder's Avatar
Re: Daverods 52
Nice find. I hope it's a good one.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 05-09-2011, 09:49 PM   #311
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Cleaned and painted the trans. Put my pistons in.Brown truck guy dropped off my rear end parts. Whats the plug for on the trans.
Old 05-09-2011, 09:58 PM   #312
Strodder
Strodder's Avatar
Re: Daverods 52
Check with these guys. They're the best. They are about 4 miles from me here in Hesperia. They might have a modification for you.
http://www.bowtieoverdrives.com/index.shtml
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 05-09-2011, 10:00 PM   #313
Strodder
Strodder's Avatar
Re: Daverods 52
This one you might need.
http://700r4.com/tech/tcc/index.shtml
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 05-09-2011, 11:51 PM   #314
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I'm guessing shocks in back of the axle panhard in front?
Old 05-10-2011, 11:12 AM   #315
ruffrida2005
Re: Daverods 52
This is how it's done.
Paul
Old 05-10-2011, 11:15 AM   #316
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I don't see a panhard bar? I thought the shocks went in the rear. Just wierd the bar is in the front?
Old 05-10-2011, 11:23 AM   #317
Strodder
Strodder's Avatar
Re: Daverods 52
Pan hard in the rear. Some stock chevy trucks have one shock in front and one in the rear. Wouldn't matter as long as you have full travel. And install them at an angle. Not straight up and down.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 05-10-2011, 01:55 PM   #318
99 to Life
99 to Life's Avatar
Re: Daverods 52
I like that set up for the s-10, how much was that?
did you check your end play for the crank? also check your clearances with
plastigauge, it would be a mess tearing that all apart because something doesn't check out. If you are checking ring gap, seems like you are being cautious enough.
loving the build
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-10-2011, 02:41 PM   #319
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
The kit was 593 to my door. I did'nt check the end play. Checked it now .003.
Old 05-10-2011, 08:16 PM   #320
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Got alittle done on the rear. Went pretty good. Still need to fill it in. Guess when they said they would supply the flat bar to fill it, in they lied.
Old 05-10-2011, 10:13 PM   #321
ruffrida2005
Re: Daverods 52
That's BS, Dave are you gonna raise up your gas tank so it wont drag? Also from the eye hole of the bushing, how far back is the lower bag plate?
Paul
Old 05-11-2011, 12:13 AM   #322
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
9 7/8 to the center of the bag plate.
Old 05-11-2011, 12:16 AM   #323
sweet70beast
sweet70beast's Avatar
Re: Daverods 52
If the 700r4 doesn't work out let me know, I have 3 of them laying around. They "ran when pulled" but they will NEED a rebuild.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 05-11-2011, 12:24 AM   #324
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Fun man. Thats what I'm thinking about this one. For now I just want it to get everything where it needs to be. The cores gotta be worth 100? Who knows it might work.
Old 05-11-2011, 02:56 PM   #325
MrDude_1
Re: Daverods 52
dave, i hate to be the barer of bad news, but that bag kit isnt going to work well for you.
the bags are not centered over the bars... by having them off to the side, it puts a "twist" into the bars.
you're only going to get a few thousand miles before you need new bushings on the lower control arms.. the twisting makes them prematurely wear.
if you overload the truck, and drive it like that, you can even twist the arms.
I really wish jackasses would stop selling people kits like that... they NEVER work out well, and it ends up costing people money.
if you modify it so the bag is directly over the bar (meaning you'll have to sink a bag mount into your frame) it will work great... not hard, but you shouldnt be forced to modify a kit like that.
in anycase, it needs to be fixed.. atleast you didnt weld the upper bag brackets on yet.
MrDude_1 is offline   Reply With Quote
