03-20-2017, 10:22 PM | #301 |
Re: Captain America 68 short/fleetside
I love seeing the work on the cab. Glad it's coming along.
My son in law is looking for a 67-68 hood if you happen across one let me know. I can't find anything down here.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
03-20-2017, 11:07 PM | #302 | |
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
03-21-2017, 10:10 PM | #303 |
While replacing the driver's side rocker panel, the driver's door wss giving me trouble. It wouldn't latch properly and nothing was lining up. I tried to remove the latch, but the screws stripped out and i had to drill them out. The more stuff I tried to remove, the more stuff broke. I ended up taking the dir assembly off the 68 cab. With the new door in place, i got everything lined up and welded.
Then I worked my way forward, patching the air box for the vent. - Josh
06-03-2017, 10:16 PM | #304 |
After countless hours of sanding and priming, i painted the roof and back of the cab today. It's metallic charcoal with satin black below the body line. The separating pinstripe is gm light metallic blue. It'll all make more sense once i swap the cab onto the frame. I just wanted to update my build thread.
-Josh
06-03-2017, 10:30 PM | #305 | |
06-23-2017, 08:30 PM | #306 |
I bought a bed liner kit and coated the floor of the new cab from the firewall all the way back to where the fuel tank sits under the rear window. I d/a sanded the whole floor with 80 grit and wiped everything down with lacquer thinner. It looks cooler than i thought it would. Supposedly it takes 5 days to fully cure, so I'll be looking for other stuff to do in the mean time.
-Josh
06-24-2017, 09:37 AM | #307 | |
I have been putting together a 5.3 for my Blazer using the new FiTech port Fuel Injection it's pretty cool as you can tune the engine from inside the cab with a controller. It comes with an intake and fuel rails new injectors and wiring harness with the computer too. But you can get it with just the computer and harness so you can use the oem intake and injectors.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour Last edited by colgad; 06-24-2017 at 09:40 AM. Reason: typo |
06-24-2017, 10:40 PM | #308 |
The SEM kit comes with everything you need. They have red or black. There's 4 individual quarts of bed liner, one quart of catalyst, a measuring cup and a spray gin on the kit. Instructions tell you how much catalyst to mix and what psi to spray. I used three of the four quarts on mine.
-Josh
06-25-2017, 03:47 AM | #309 |
Looking great glad to see the progress, love the color choice as well
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
07-02-2017, 08:44 PM | #310 |
I disconnected everything and pulled the original cab off today. The plan is to clean up and paint the Frame and check for any problems before putting the new cab on. I already found the trans dipstick grommet is torn and leaking, so I'll fix that and look for any other issues.
-Josh
07-07-2017, 06:57 PM | #311 |
I put the 67 cab on today after work. I was waiting on a trans dipstick grommet to come in so i could replace it while it was easily accessible.
To install the cab without removing the doghouse, I put jacks and jackstands under the back of the front fenders. I strapped the jig across the front, just above the windshield to keep it from sliding backwards because of the angle it's on. I got the top rear fender holes to line up with the mount holes on the cab and put two bolts in there to help line everything up as i lowered the cab. I used new polyeurathane body mount bushings and bolted everything together. Now there's room in the garage to work on the bed. -Josh
07-07-2017, 08:14 PM | #312 |
Great way to put a cab back on with a lot less work!
07-09-2017, 10:14 PM | #313 |
I like this thread. I remember reading about captain america truck when I first joined here.
07-17-2017, 07:30 PM | #314 |
I got my other led headlight in today. I had to trim the back of the headlight bucket for clearance, but i like the look.
I don't have battery power to the lights yet, but I'll post pics of the daytime running lights, low and high beams. -Josh
07-31-2017, 09:12 PM | #315 |
I replaced the battery today, so i got some decent pictures of the new headlights lit up. I haven't hooked up the daytime running lights yet, but the low and high beams are pretty cool. They're very bright! I also started the truck for the first time since i pulled the old cab off.
-Josh
08-14-2017, 11:26 PM | #316 |
I got the interior and the shifter installed this past weekend. I even wired up the power bucket seats.
Today, i wanted to see if i could turn a 69-72 fender into a 68 fender. The only difference i can see is the leading edge of the fender around the headlight. If i were a machinist, I'd make left and right end caps, but I'm working with what I've got. - Josh
08-16-2017, 05:40 PM | #317 |
Here's the finished passenger fender. It's going to be flat black, so it doesn't have to be perfect.
-Josh
08-16-2017, 06:42 PM | #318 |
That looks good!
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
08-16-2017, 11:02 PM | #319 | |
08-24-2017, 09:16 PM | #320 |
I got home from work today and filled the badge holes in the new passenger front fender. Then i scuffed the doors, fenders and hood with 400 grit sand paper and sprayed my outline color for the scallops and flames i plan to do on the truck. I'm hoping for decent weather this weekend so i can mask of and stripe out the design and get the flames painted and masked off.
-Josh
08-25-2017, 09:25 PM | #321 |
I got my scallops laid out in 1/4 inch masking/ pinstripe tape.
-Josh
08-25-2017, 09:28 PM | #322 |
The flames coming from behind the scallops are laid out with 1/8 inch pinstripe tape.
-Josh
08-25-2017, 09:32 PM | #323 |
After cutting the tips off the flames and establishing the dominance of the flames over the scallops, I faded the flames as best i could using the light from my cell phone since the sun called it a day.
-Josh
08-25-2017, 09:45 PM | #324 | |
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
08-26-2017, 06:42 PM | #325 |
I masked off the flames so i could paint the scallops black along with the front of the truck and below the body line.
-Josh
