Old 07-22-2013, 06:32 PM   #301
c6_rob
c6_rob's Avatar
Re: How about some pics of bagged 47-59
Shes getting there. Staring to work in the cab now.
52 Chevy 3100
c6_rob is offline   Reply With Quote
Old 07-22-2013, 06:36 PM   #302
vince921
looking really good c6_rob loving the simple clean backhalf. really thinking about redoing the setup in the rear of mine!
vince921 is offline   Reply With Quote
Old 07-22-2013, 07:38 PM   #303
apache200
apache200's Avatar
c6_rob what air ride are you running on your truck? the setup is nice and clean
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 07-22-2013, 07:55 PM   #304
c6_rob
c6_rob's Avatar
Thanks, its a kit I got off ebay. Tank, 8 valves, 2 compressors and switch box. The brackets and mounting etc are all my own work.
PM me and Ill give you the guys info for the air ride kit.
52 Chevy 3100
Old 07-22-2013, 07:58 PM   #305
c6_rob
c6_rob's Avatar
Originally Posted by Sssingo View Post
Not quite up at the level of the previous posts but it is afterall on its way (down)
Torrance? Hey Neighbor !
52 Chevy 3100
Old 07-22-2013, 11:13 PM   #306
mknittle
mknittle's Avatar
Lookin good nice and not over complicated.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-23-2013, 07:37 PM   #307
lowroder
Awesome To The Above Trucks.... Wicked !
lowroder is offline   Reply With Quote
Old 07-23-2013, 07:50 PM   #308
vince921
I know the regular wood bed kits look awesome. But has anyone ever seen/or done a sheetmetal/LineX bed ?
I'm throwing around the idea think it would be pretty killer ?
Old 07-24-2013, 10:14 AM   #309
lowroder
C6 ... What Rim an Tire Size Are You running looks hot .. Doing a 49 .
Old 07-25-2013, 10:57 PM   #310
c6_rob
c6_rob's Avatar
Lowroder, im running a Coker G78-15 tire 3 1/4 whitewall. The rim is 7 or 7.5 wide with center backspacing. Based on my rough calcs this should almost touch the tops of the inner fender wells when slammed. The center backspacing should be ok in the rear with my chevy 10 bolt rear end. Your application may be different so choose the backspacing carefully. Im hoping that when I get together everything fits well (mainly speaking of width not height). It should if I measured correctly.
52 Chevy 3100
Old 07-26-2013, 01:20 AM   #311
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Cool tucks
LOW DOUGH is offline   Reply With Quote
Old 07-26-2013, 08:25 PM   #312
lowroder
Cool C6.... I Like The look..
Old 08-05-2013, 12:33 AM   #313
Marte_Mcfly
C6, that's awesome. Clean ride. Is that an s10 swap or original frame?
Marte_Mcfly is offline   Reply With Quote
Old 08-12-2013, 09:06 AM   #314
Sssingo
Sssingo's Avatar
Hey c6_rob. Thats a very tidy build. I am in the UK it's just my suburban is over at Starlite Rod&Kustom in Torrance having some work done before it comes to the UK shore
Sssingo is offline   Reply With Quote
Old 08-12-2013, 12:13 PM   #315
c6_rob
c6_rob's Avatar
Thanks guys. Its an original frame.
52 Chevy 3100
Old 08-12-2013, 08:19 PM   #316
broey
Square
broey's Avatar
I see that done all the time. Usually looks ok. Wood will always look better and be more valuable
Squarebody Syndicate
broey is offline   Reply With Quote
Old 08-21-2013, 08:56 PM   #317
slimneverdies
slimneverdies's Avatar
Originally Posted by PJF View Post
Wow. Very nice.
How big are those wheels?
If that's a 22's in front it will be the first time I seen one layed out. I need more info on this one please...
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 08-23-2013, 04:29 PM   #318
keithcorcoran
Someone mentioned the ability to bag an original frame?
Where would one find more info about doing it to a 47-53 frame?
keithcorcoran is offline   Reply With Quote
Old 08-24-2013, 11:28 PM   #319
Marte_Mcfly
keithcorcoran the info is definitely on this forum, just got to know what to look for. By what I've gathered here there are basically 2 main ways to drop your ride. One is bagged one is not. For not bagging and the cheaper route look up dropped front axle . the rear can be done by using lowering blocks to keep the original stuff. look up sids dropped axles and they have a write up on how to do it this way.If you want to go the bagged route you will have to go with an IFS (independant front suspension) of some sort. either a front clip or a weld in upgrade. and for the rear you would have to go c-notch and 4-link. here are some keywords to help- IFS original frame bagged original frame 1950 panel
Old 08-24-2013, 11:37 PM   #320
keithcorcoran
thanks for the info.
i almost feel like if you're going to do ans IFS up front and nothc the frame you might as well try to find a bagged s10 and do the frame swap.
that's probably because i don't know too much about it but if you're going to go that far with it.. might as well.
i DID see the drop axle writeup on sid's site.. that doesn't look too bad.
not quite as easy as hacking off a couple of turns on a coil spring but not too terrible.
thanks for the info.. i'll start doing some research.
Old 09-06-2013, 11:03 PM   #321
ddubbs
ddubbs's Avatar
If your looking to bag a 47-55 1st series Porterbuilt fabrication is coming out with a kit that's going to involve all c10 spindles. Nate posted a pick on Instagram last week that showed it might be a trailing arm kit in the rear and a dropmember up front. Top notch!!
LIFTED OR LOW THE ONLY WAY TO GO!!!!
Check out my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=517346
Projects
56 Chevy pickup Porterbuilt FR/RR dropmembers
ddubbs is offline   Reply With Quote
Old 09-16-2013, 09:12 AM   #322
Miayota
My bagged 3100:
"El Gordo 54"
This truck was left to die in a field for decades where it got the tender touch of Mother Nature. After getting it's fair share of bullet holes and broken glass my Builder rescued this beauty and gave me a call. 47-53 Trucks are common so that's why I decided to make this 1954 something special and uncommon. I'm planning on enjoying it for a few months and when the time comes it will be sold to the highest bidder on eBay. I will let the world dictate what this American Time Capsule is worth.
To see 40+ pics check me out:
Check me out on Instagram : Miayota
Website: miayota.blogspot.com
Youtube: Miayota
Features:
-73' Chevy C10 Frame swap
-Mega Wide Custom Fenders: We added almost 6" inches to each fender to give it a Wide Body look.
-15x12 Rear Wheesl (9" Lips) & 15 x 8's up front
-Chevy SB 350
-Automatic Transmission using the same 3 on the Tree original setup
-Reclaimed Tilt Wood Bed
-Full Air Ride Laying Side Steps
-Real Deal Bullet Holes from decades ago. "Damn Kids!!" LoL
-Currently working on a brand new interior
-All New Glass
-All Interior
Miayota is offline   Reply With Quote
Old 09-16-2013, 09:39 AM   #323
keithcorcoran
No mention on the site of his forum. I'll have to be patient.
Old 09-16-2013, 09:52 AM   #324
runpasthefence
runpasthefence's Avatar
Originally Posted by Miayota View Post
My bagged 3100:
"El Gordo 54"
Features:
As someone who's currently fighting track width issues because I'm using a 1969 frame under my 50, this is awesome.
runpasthefence is offline   Reply With Quote
Old 09-16-2013, 12:05 PM   #325
Rad's
Rad's's Avatar
OMG!!!
These wheels rules!
Rad's is offline   Reply With Quote
