Old 11-25-2015, 11:51 PM   #301
robs71k5
K5drive
robs71k5's Avatar
Re: Softop installation no Holes
Thanks for reporting that smbrouss70 and good luck with the install .
Take your time and it would be very Helpfull to have help during some phases of the install in order to optimize appearance and function .
I will also soon pay more attention here but between regular life and these things it's very busy. I hope the reward for me will be in the way of pictures from all your installs. Regards Rob
robs71k5 is offline   Reply With Quote
Old 11-26-2015, 01:59 AM   #302
robs71k5
K5drive
robs71k5's Avatar
For those that haven't yet received information on how to aquire your Header please check your pm inbox for instructions . Otherwise please pm me your name, complete address including a phone number . I will not be shipping any Headers after the 2nd of Dec until early in the new year .please refer to this thread.
For those that have already picked up their Header I hope you a satisfied with the product and can't wait to see the resulting pics of your installs. Most of you will likely be enjoying a more complete installation than mine at this point as my Header is the first one made not as nice as the ones being shipped and hoping to get one for myself . Lol
Also before I forget a Happy Thanks Giving.
And again I may not have a chance to wish absalutely everyone including and most importantly refugees a swift relocation and a very Merry Christmas .
Cheers Rob
Old 11-29-2015, 04:05 PM   #303
Blazerowner
Blazerowner's Avatar
This is a pretty sweet setup. Any thoughts of making one out of steel?
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 11-29-2015, 09:15 PM   #304
robs71k5
K5drive
robs71k5's Avatar
Yes that was my second thought.When I first mentioned to someone years ago here about making these out of plastic. I think I was the but end of the joke. I then swung over to thinking steel but didn't like the idea of a steel part rolling around the truck scratching things so I went back to the fiberglass idea and just did one for myself and posted the picture. It really sucked that I had to build it from fiberglass cause I hate working with it as I did this for many years before I retired . But I think they will end up being a fixture in the Blazer world for some time.
Old 11-30-2015, 06:07 AM   #305
tristan
Payment and PM sent.
tristan is offline   Reply With Quote
Old 11-30-2015, 05:44 PM   #306
Blazerowner
How tough is the fiberglass? Is it fairly ridged and what is the thickness?
Kirk
66 Nova
Old 11-30-2015, 09:18 PM   #307
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
My hats off to you and the design. Always love to see custom parts available to us forum members. Soon as i get a soft top, the header will be my next purchase
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 12-01-2015, 01:11 AM   #308
JackB
Payment sent...Cant reply to your PM mailbox its full Thanks Jack
JackB is offline   Reply With Quote
Old 12-01-2015, 04:44 AM   #309
robs71k5
K5drive
robs71k5's Avatar
The fibre glass thickness is strategically variable through out to Header to keep cost down and the strength where it's required. I've been running around with mine now for a few years and it's one of the lightest ones I've made and have not experienced any cracks or other damage what so ever .
The part does require some fitting and trimming out of the box . I think I'm finally getting close to a workable trim template that resembles the bulk of the Blazers . It's difficult because I only have my Blazer and it had work done to the windshield corners so I wondered how close was my efforts resembled the factory design. Then after building the first one I knew I have to add more beef to them but there was no evidence that it required more beef at that point.
As they come now they are gel coated inner and outer surfaces but I tend to sand the roughness on the upper side a little and much of the gel coat is sanded off . A way to remedy that would to give it another coat of gel coat and sand again . Maybe repeat till you get desired smoothness.
I would like if I could build both sides smooth but we're talking some pretty fancy equipment . I have aquired some of it just not all of it yet. But I'm also not keen on vesting myself to heavily into this as I'm supposed to be retired. But I'm busier now than I was when I was working
I'm guessing the thickness might be 1/4 -3/16 thickness maybe as thin as 1/8 in places .
As I said before they are each hand layed per a strategic map and each one goes through my hands before seeing your hands.
I do take pride in these parts and each one is built as if I where to use on my own Blazer.
A keen eye to body work will go along way to your finish .
Trim and fit each end till you get the each ends forward edge so it's not in the bottom of the rain gutter untill the mating surfaces at the 5/16 bolts at each end of the Header are touching before drilling the 5/16 holes Reason for this is two fold . Torquing the bolts down before trim and fitting could crack the fibreglass at the 5/16"bolts and the seal will not leak when installed properly . Then eye ball the leading edge for its contour and sand as required to give it a flowing radius across the trucks windshield. If you take your time I know you will be impressed with the install and if done correctly you will not notice the part even with your top down . Hope your questions where answered . Regards Rob
I
Old 12-01-2015, 10:30 PM   #310
robs71k5
K5drive
robs71k5's Avatar
Update : Ok I really need to do something about the inbox being jammed up all the time . If your interested in the Headers. Please send your queries to my personal email account at srpenner@hotmail.com . I will try to organize this info and process from there. I've now noticed some requests that are a year old and unanswered and that must be frustrating for those trying get get in on one. But hair pulling on my end cause I would rather not have people pissed at me If I can help it.
Old 12-02-2015, 11:26 PM   #311
Gibber1967
Hi Rob,
At long last I have my header in my hands, it is exactly as expected. I really appreciatte the effort you put to posting the mounting instructions on here...it's not on yet, but I'm not to worried about it now.
Thanks again!
Gibber
Gibber1967 is offline   Reply With Quote
Old 12-03-2015, 09:17 PM   #312
CTENTA1
Registered 1971 K5
Hey Rob
Just got home and the first thing I see is my soft top header. It looks great and did a quick fitment check. Seem's fine, very well done. My top windshield frame sections is actually "NEW OLD STOCK" I bought it from a guy who posted it here and then Ebay. There is no way I could drill holes to it. Im glad you make these because now I can work on ordering my softop. Much thanks again!
CTENTA1 is offline   Reply With Quote
Old 12-07-2015, 09:47 AM   #313
Minnz
Minnz's Avatar
Rob,
Received my strip the other day, very nice. Thank you very much for your efforts.
Lee
72 Ochre Blazer
69 Camaro Z28 Garnet Red
48 Willys (rolled)
Minnz is offline   Reply With Quote
Old 12-11-2015, 03:45 PM   #314
tristan
Thanks Rob, mine arrived safely yesterday and looks great. I also appreciate the camo look you provided free with the headers. Hopefully someday I will actually have a convertible top to use with it!
Old 12-16-2015, 04:53 AM   #315
robs71k5
K5drive
robs71k5's Avatar
Glad to see the parts finally showing up . Now If you want a nice smooth finish on the out side I would recommend simply adding another layer of gel coat or two and sand before you add your color paint . I would really like to see some pics of the installs. Someone might have been trying to call me last week but I was out of town and roaming calls are very expensive so if that was someone from here I invite them to try again . I would like nothing less than everyone getting premium results to their installs . Regards All and again a Happy Holidays
Old 12-27-2015, 12:05 AM   #316
swyfor5
swyfor5's Avatar
Sent you a PM. Don't know if you got it, but I want one . Let me know if you did not recieve my address info, thank's, Bryan.
swyfor5 is offline   Reply With Quote
Old 01-21-2016, 03:08 PM   #317
robs71k5
K5drive
robs71k5's Avatar
Just want to let you all know I'm back from holidays and here for anyone doing your installs for support. Does anyone know if you can upload video here ? I would love to park a short video to explain the preparation needed on the corners of the Header to show how easy it is for a proper mount but I also have much confident with those of you I talked with so not too worried
Old 01-21-2016, 10:25 PM   #318
colgad
colgad's Avatar
Upload your video to youtube and put the link here using the InsertLink Icon.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 02-08-2016, 07:40 PM   #319
PGG
I am ready to order I can't remember cost or time to receive etc.
How do we pay and how much?
I will private message you also.
Thanks PG
PGG is offline   Reply With Quote
Old 02-15-2016, 11:37 PM   #320
el tesoro
Hey Rob, I sent a message to your email inquiring about availability and confirmation of cost. Looking forward to getting one of these.
el tesoro is offline   Reply With Quote
Old 02-16-2016, 11:54 AM   #321
PGG
Thanks PG
I sent an email also will resend today didnt see a response would love to get it before the spring heats up. Thanks PG
patrick grissom @ M S N (DOT) com
Old 02-21-2016, 09:15 PM   #322
Gibber1967
Hey Rob,
I'm planning to try and get my header and soft top on next weekend? Any luck posting the video? Also, where did you get the rivet on snaps? Nothing at Lordco or crappy tire, so I was going to try a boat cover place tomorrow.
Thanks,
Gibber
Old 02-21-2016, 09:59 PM   #323
lyrikz
PITbut
lyrikz's Avatar
I also sent an email and im. I would like to order one.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-27-2016, 07:58 PM   #324
robs71k5
K5drive
robs71k5's Avatar
Gibber. I have had luck finding rivets at canadain tire just aluminium pop rivets. But if you want a stronger rivet look for solid rivet. Possibly a boat hull manufacturer or aircraft parts supplier. I had trouble finding these things a well and found a friend that worked at an airline and was able to get me some solid rivets. The part no wa something like 2117ad 4-7 and I had to cut the length of the rivet down wich was betther than not having it long enough. I will will to find out where one can get these rivets in public
Old 03-03-2016, 12:39 AM   #325
damholl
I will buy one if you can ship it up the b.c. Canada.
damholl is offline   Reply With Quote
